(unknown member)
Forum Member
G1 X ii - excellent go-anywhere camera
My new "go everywhere" camera. I love it. it is like a G12 on steroids. It is a bit bigger, but has a similar layout of controls, a faster higher quality lens, two control rings on the lens, a pop-up flash and a great EVF. Unfortunately the EVF is an expensive extra but at least it is removable so not likely to be damaged in transit. In any case the old optical finder on the G-series was next to useless. The rear screen is large, clear, tiltable and touch sensitive. THe only feature that the G12 had that the G1Xii lacks is the fold-out and swivel feature of the screen, but that is no bad thing as it was a weak point of the G12 and often resulted in the connections failing, which meant sending the camera back to Canon for repair.
The 1.5" sensor is only fractionally smaller than APS-C and delivers top quality images of 12+ megapixels (size varies depending on the image format). Reviews compare the high-ISO performance unfavourably with Sony and other MSCs, but it is more than good enough for me. 1600 ASA is almost as good as 100. Only at 3200 does noise become objectionable, but with Noise-Ninja the images can be repaired, and even 6400 and 12,800 become usable with careful composition and post-processing. I am, of course, referring to Raw files. The out-of-camera JPEGS I don't consider acceptable, as even at low-ISO they show halos and other artefacts when printed larger than A4.
The only drawback (for me) is that I cannot get support for the new version of Canon's raw files (.CR2) in LightRoom or other Adobe tools unless I "downgrade" my Mac from the excellent OS X 10.6.8 to any of the inferior versions of OS X (10.7, 10.8, 10.9, 10.10, 10.11) that have followed it!!
Fortunately a version of Iridient is available for Snow Leopard that does recognise the files and does a better job than LightRoom 4 of the basic demosaicing. I can choose to process the images completely in Iridient, then import them to a Lightroom catalogue for management, or I can just convert to TIFF in Iridient (it has batch processing option) and then both work on them them and manage them in Lightroom.
You would not buy this camera if you want something really tiny and lightweight. It is only a pocket camera if you have very big pockets, like on a winter overcoat. But I wanted images comparable in quality to those from my DSLRs, and a tiny compact can only deliver that in excellent light.
