Circular vs Linear Polarizer on m4/3 Camera
Started Jun 7, 2016 | Discussions
Charley123 Senior Member • Posts: 1,166
I know (or think I know) that a mirrorless camera can use either type of polarizer. Is that correct?
Is it the linear or circular that is rotated to polarize? I don't recall.
Which would do a better job for image quality on a mirrorless camera?
Could I rotate a polarizer on a lens that has a bayonet mount lens hood?
JDLaing
JDLaing Veteran Member • Posts: 6,426
Re: Circular vs Linear Polarizer on m4/3 Camera
Linear polarizer is more along the lines for rangefinder where you are not looking thru the lens. Recently, live view has cured that on digital rangefinder bodies.
Circular polarizers rotate to increase or decrease polarization. They are infinitely adjustable.
I would use a circular polarizer on a mirror less body. A good quality one too.
 JDLaing's gear list:JDLaing's gear list
Leica D-Lux (Typ 109) Leica M8.2 Olympus OM-D E-M5 Leica M Typ 240 Sony a7 II +17 more
apathyman Veteran Member • Posts: 4,154
Yes.
Both do.
It shouldn't matter as long as they are good quality filters.
Yes - if it has a filter thread as well. Depending on the lens, you may have to remove the hood to use the polariser but you could buy a third party hood to screw into the front of the filter.
Cheers
Brian
Len_Gee
Len_Gee Veteran Member • Posts: 9,880
Makes no difference.  Just make sure it's of good quality.
Good luck. Report back your findings.
Lena
Like others here, I suffer from chronic GAS.
Gear Acquisition Syndrome.
a few hundred nautical miles SW : 17º 52S, 149º 56W
 Len_Gee's gear list:Len_Gee's gear list
Olympus PEN-F Olympus OM-D E-M10 IV Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital 17mm F1.8 +4 more
dontfret
dontfret Senior Member • Posts: 2,341
8
I beg to differ JDLaing:  both linear and circular polarizers rotate to change polarization plane - you must be looking through them to observe the effect (like seeing the blue sky get darker/lighter as you turn the filter).  The difference between them has to do with DSLRs that use a split prism mirror for focusing, they can only use circular polarizers.  A good quality polarizer should have no effect on image quality, but a bad or poorly coated one will - like any cheap filter.  For mirrorless cameras there is no difference lin/circ, having said that, high quality coated linears are getting harder to find.  I am a huge fan of them, still using the ones I had in the Pentax SLR days if the filter size or using a step adapter fits.  My best trick is doing max neutral density range for HDR by crossing two stacked polarizers and taking a picture at each ~10 degrees rotation from lightest to opaque, then merging them:
Rich
Take many pictures - a few are keepers, the rest are are lessons.
 dontfret's gear list:dontfret's gear list
Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-G5 Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +12 more
jpig Contributing Member • Posts: 556
So do linear polarizers. In this respect there is no difference. You can use either type on a mirrorless camera. There is no particular reason to prefer one over another, although good quality linear polarizers do seem harder to find these days.
I have a Marumi circular polarizer and an old Hoya linear polarizer. Both rotate to adjust degree of polarization and both work fine on m43 cameras. The only difference I have noticed is that the Hoya seems to have a stronger polarizing effect.
Skeeterbytes Forum Pro • Posts: 23,186
I have never seen a coated, much less multicoated linear pola, so end up using circular for my OM-Ds despite the extra cost and greater light loss. Circular are only required where there is a beam splitting scheme, as done with DSLRs.
For folks who don't know, all screw-on pola filters rotate, which is different than "circular" technology: "...comprises firstly a linear polarizer which performs the artistic function just described, followed by a quarter-wave plate which further transforms the now-linearly polarized light into circularly-polarised light before entering the camera. This additional step avoids problems with auto-focus and light-metering sensors within some cameras, which otherwise may not function reliably with a simple linear polariser."--Wiki
Rick
hutu Contributing Member • Posts: 651
PDAF requires CPL.  CDAF works with both.
lescrane Contributing Member • Posts: 904
Good to know that mirrorless can use linear which are cheaper.  Probably will keep using my slr polarizers (mostly B&W) but can save $ w replacements
 lescrane's gear list:lescrane's gear list
Panasonic Lumix DC-G9 OM-1 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Panasonic Leica 100-400mm F4.0-6.3 ASPH Olympus M.Zuiko 300mm F4 IS Pro +4 more
olyham Regular Member • Posts: 210
Re: Circular vs Linear Polarizer on m4/3 Camera exept EM1 ?
Good point All of us with EM1's need CPL as we have both PDAF and CDAF, on this basis the answer that Mirrorless can use either is incorrect. Or  does it make no difference to an on sensor PDAF, I would have thought not but maybe there is an expert out there who can confirm or deny this so we can be exact ?
OP Charley123 Senior Member • Posts: 1,166
Yes, linear polarizer has a stronger polarizing effect. I used to know that. Eventually forgot it. Memory refreshed now.
drj3 Forum Pro • Posts: 12,636
I thought the reason for circular polarizers for SLRs/DSLRs was the use of beam splitters and not fully reflective mirrors.  Since the E-M1 does not have either, why would it need a circular polarizer?
It is probably not relevant (even though you would have less light loss with a linear polarizer), since I have not seen a high quality multicoated linear polarizer.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
Heliopan makes high quality double coated linear polarizers. Hoya makes good linear polarizers, but they're uncoated. Add a lens hood and you're good to go.
I get very poor  AF results when using a CPL on the EM1 in C-AF high speed sequential, I guess there could be a few factors causing that, but needless to say I never use it when operating in that mode, I have also never used an LPL in that same config. to test if it is related as I only have a smaller LPL.
Are you sure about that? I don't know that on-sensor PDAF is affected, while beam-split AF and metering are.
Rick
TheEye
TheEye Veteran Member • Posts: 4,883
Linear polarizers are a bit more effective than circular polarizers. Considering that polarizer-happy photogs often overdo the effect, it is not a bad thing to use a circular polarizer by default. It will work on any camera.
The highest quality polarizers are environmentally sealed, which prevents the sandwiched polarizer foil from getting damaged due to moisture. These pricey filters are called Käsemann.
Some cameras require circular polarizers for the AF system to work proplery. The manual should say, or you can call technical support.
For use with wide-angle lenses, get slim polarizers. The ones with a thick mount may cause vignetting.
Beru Roniki - AKA Grzzl
Beru Roniki - AKA Grzzl Regular Member • Posts: 428
I have both
And they both work fine. No problems with exposure or autofocus.
I never had, in contrary to what they say. Not on Minolta, NIkon, Panny or Olympus.
Linear is much cheaper.
From all the things i have lost, i miss my mind the most
http://flickr.com/beruroniki
 Beru Roniki - AKA Grzzl's gear list:Beru Roniki - AKA Grzzl's gear list
Olympus PEN E-PL3 Olympus OM-D E-M10 Sony a7 II Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
Update. I purchased two polarizers (37mm and 46mm).
Here is what I've learned, what I bought, and why I bought it.
I bought a linear polarizer because it will work with my mirrorless, contrast detection M10ii and M5ii. Linear will work better than circular because linear polarizes more strongly. Normally linear costs way less than circular, but not in this case since I bought Heliopan linear which costs as much as a good Hoya circular.
The only brands of linear polarizers I could find are made by Heliopan, Tiffen, and Hoya.
Hoya doesn't make size 37mm linear polarizer, or at least none available in that size.
Hoya and Tiffen linear polarizers are uncoated.
Heliopan was the only brand I could find for a 37mm multi-coated linear polarizer.
I bought Heliopan linear (multi-coated) polarizer in size 37mm and 46mm for $69 each from BHPhoto.
Heliopan was the only brand of linear polarizer (that I could find) with anti-reflective lens coating on each side.
Heliopan linear polarizer is rated 5 stars by users at BHPhoto.
The other good, high-end, linear polarizer I found was Hoya for $22 each. It does not have any lens coatings, but is rated 5 stars by users at BHPhoto. I've had excellent results from Hoya in the past and would have bought it, but it didn't have any lens coatings. I'm sure it's the best linear polarizer for the money, but it's not available in size 37mm, which is another reason I didn't buy Hoya.
The lack of lens coatings didn't matter much back in my film days when I got excellent results from Hoya and Tiffen uncoated linear polarizers. However, I'm not sure if that same applies to digital. Would the lack of lens coatings be a problem for digital? I don't know, which is why I went for the coated Heliopan at way more cost.
Tiffen linear polarizer was available for $19, but has no lens coatings. It's rated 4 stars by BHPhoto customers. I didn't buy it because I think the Hoya and Heliopan are better. However, in my college days (using film) I used a Tiffen polarizer and it gave excellent results. It was great with film. It's probably good with digital too. But I can afford better now. Hoya is better for only $2 more. Heliopan is much better for $50 more.
Though my question stands... Does lens coating (or lack of) on a linear polarizer matter more for digital than for film? Cause on film I was getting great results with cheap uncoated linear polarizers like Tiffen and Hoya.
Re: Update. I purchased two polarizers (37mm and 46mm).
You are a better sleuth than I, who has never found a coated LP when I've looked. Please post some shots once you get dialed in!
Rick
p.s. I don't believe coating will affect the pola effect, just increase light transmission, and reduce flare when bright light hits the filter.
dontfret
You certainly have more flexibility with individual filters, but I find I seldom need both at the same time on different lenses.  Why not get the 46 and a 37-->46 step ring?  I have two linear coated Hoya pols from older lenses at 72mm and 55mm, and a handful of step rings.  I have used the 55mm on a lenses and step up to the 72 to get an infinite ND for HDR stacking.
Rich
