Canon G9X vs. G7X, Sony RX100 M1, others
Started Jun 5, 2016 | Discussions
fbx Senior Member • Posts: 2,622
Strapped for cash and looking to pick up a 1" sensor cam that can outshoot my iPhone 6s. I was thinking of buying the Sony RX100 Mark1, which I've owned previously and thought well of. But the gets me into eBay and all that. So I looked at the G7X which looked good until I read some reviews that counted it poorer in the IQ dept than the RX100. Then I looked at the G9X which was considerably cheaper but has a lesser lens than the G7X, so I figured it would be worse. Some of the reviews speak highly of the G9, saying the IQ is pretty much the same as the G7 and ALSO pretty much the same as the first version of the RX100. My shooting is all over the place--travel, portrait, dog, art, general. No printing, but I might print if the quality was good enough. Been shooting a long time but by no means a "photographer," and certainly not a "good" photographer. Still, I see noise in images, stuff breaking up, unsharpness, bokeh, etc.
Need a little help with this, advice and consent, all that. Much appreciate any advice. Thanks all--
 fbx's gear list:fbx's gear list
Sony RX100 VI
Canon G9 X Canon PowerShot G7 X Canon PowerShot G9 Panasonic Lumix DMC-G7 Sony RX100
OpticsEngineer Veteran Member • Posts: 7,823
Re: Canon G9X vs. G7X, Sony RX100 M1, others
"So I looked at the G7X which looked good until I read some reviews that counted it poorer in the IQ dept than the RX100."
My experience with my G7X is it has slightly better IQ than my RX100II that I hardly ever use anymore.    Plus the RX100II image stabilization is less effective and at long zoom, the lens is a lot dimmer.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Pentax *ist D +27 more
OP fbx Senior Member • Posts: 2,622
Thanks for this. Their must be some dispute but I'm pleased to hear that the IQ is close enough for there to be dispute. How do you compare the G7X and the G9X?
Sony RX100 VI
Digital Nigel Forum Pro • Posts: 17,852
I have both the RX100 m1 (bought soon after it came out, in 2012) and the G7X, which I bought to replace the RX100. The G7X lens is much more ambitious, being both wider and brighter. This does mean that it's heavily compromised at the wide and, but so is the RX100 lens to a lesser extent (which doesn't get as wide). As already mentioned, the G7X has better image stabilisation. It also starts up quicker and I prefer the controls. It has WiFi, which the old RX100 m1 lacks (later RX100 models have it).
However, it also lacks the multi-frame features that you find in most Sony cameras, such as in-camera panorama, Hand-Held Twilight, etc, It's also a bit thicker and noticeably heavier. I shoot RAW, and it's annoying that the G7X has no buffer capacity for RAW shots, so you only get about 1 fps (the new G7X II fixes this) burst mode.
Oddly enough, apart from the Wi-Fi, the 2015 G7X feels like an older camera than the 2012 RX100 m1. It's heavy, well-built, but lacking in modern electronics.
 Digital Nigel's gear list:Digital Nigel's gear list
Panasonic FZ1000 Canon PowerShot G7 X Nikon Coolpix P900 Panasonic ZS100 Sony RX10 III +22 more
damian5000 Senior Member • Posts: 1,948
IQ of G7X generally better than RX100M2...and more bokeh, longer reach, touch display. This isn't even a contest unless you need the hot shoe. Performance is very good unless you need fast continuous RAW. See many of the reviews from people coming from dSLR.
 damian5000's gear list:damian5000's gear list
Not longer reach than the RX100 m1 and m2. In essence, the G7X lens zoom is the superset of all the RX100 models while being, on average, brighter. But at the wide end, the image is heavily distorted and doesn't even cover the sensor, so after correction, it's not sharp:
G7X image at the widest end, no lens correction.
photo perzon Veteran Member • Posts: 4,653
Sony Rx100 I is a slow lens
G7X and mii are fast 1.8 to 2.8 lens
G7X much better portrait colors for skin tone
G7X feels like a mechanical camera, Sony like electronic gadget
 photo perzon's gear list:photo perzon's gear list
Olympus Stylus 1 Panasonic Lumix DMC-ZS50 Fujifilm X70 Fujifilm X100F Fujifilm X-T100 +1 more
Zoom these cameras in and see which goes to 100mm and which goes to 70mm, and which starts at 24 and which starts at 28. IQ is a step up regardless of corrections... whether it's a significant step up in reach or IQ, that's debatable.
in terms of bokeh, a significant step up from either 100m1 or 100m2.
A good suggestion. Why don't you try it?
I take it you haven't ever actually used an RX100 m1? It zooms from 28 to 100mm equiv. I should know -- I've owned one for almost four years. It's the m3/4 that go from 24-70 equiv.
The G7X lens distorts very badly at 24mm equiv, and that's why the sharpness suffers after correction. None of the RX100 models distort as badly at the wide end, which is why they don't suffer as much in the corners as the G7X.
I really try not to use 24 f1/8 with the G7X, as the IQ is so poor. I didn't need to do that with the RX100 (which, as I pointed out, doesn't zoom as wide). And, yes, the RX100 m1 lens is much slower at higher zoom than the G7X lens.
The R100 m3/4 have very little distortion at 24mm, which is why their IQ is markedly better at the wide end than the G7X. But their lenses only go out to 70 equiv, and are slightly slower on average.
So, as I said, the ambitious GX7 lens has the superset of the zoom range of all the RX100 models, and is also faster. That's great, but the price you pay for is poor corners at wide angles.
Thanks for the many replies. I'd like to narrow this to a comparison of the G7X and the G9X.
What are the advantages/disadvantages of both, and how does the IQ compare between the two? I gather that the G7X is much favored, but I'm curious if there's a lot of difference between the two in shooting and in product.
Sony RX100 VI
The advantage of the G9X is the very small size.   It truly is pocketable, like a Canon S110.
But to achieve the small size, there is less zoom range, the lens is less bright.  And the image quality is reduced.
If found this review informative
http://www.cameralabs.com/reviews/Canon_PowerShot_G9X/index.shtml
the same website also has a review of the G7X.
The IQ of g7x is also a step above either the M1 or M2, generally... I was quite surprised at the difference http://www.cameralabs.com/reviews/Canon_PowerShot_G7X/outdoor_resolution.shtml
At f2.8, you may have a strong point there. I haven't seen a properly done comparison. At f4 they are of a different class when peeping.
IMO, the biggest difference is brightness. You'll have much more low light versatility with G7X when zooming. If you're generally shooting wide, then the gap narrows significantly (f1.8 v f2.0)... g7x has a wider view (24mm v 28mm). I carry mine in a soft case on my belt... generally no problem.
aldan1 New Member • Posts: 1
I was looking to upgrade my s120 with the g9x. Love the s120 but in low light and indoors it gets very noisy.
At first I thought about the g7x but didn't like the size or weight and then I realised there was something I didn't like even more with the g7x. The horrible corner distortions completely swayed me away from it and to stick with the s120.
Been thinking of the g9x because of its size and 1 inch sensor should be an upgrade for low light, noise. I see that it also has the corner distortions but is it as bad as the g7x in this regard?
Also quite liked the star modes on the s120, is the g9x an improvement over the s120 with these modes? Handy having a small camera for starry night shots.
The G7X lens weak spot is when wide open at 24mm. The quality, particularly in the corners, with the lens at f/1.8 is really poor. Once you stop the lens down, it's much better, but that nullifies most of the benefits of the fast lens. The RX100 lenses are more usable wide open.
dpr4bb Senior Member • Posts: 1,418
It's not that great at 28mm, either. I use mine essentially as a 35-100mm camera.
Mark9473 Veteran Member • Posts: 6,425
Is it too difficult for you to stop it down to f/4 or so?
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
Not at all, but it doesn't help much.
0lf
0lf Senior Member • Posts: 1,284
Mine is also not great at 28mm and below, but very very close to my Rx100-2, and good enough I don't fear to use it below 35mm.
 0lf's gear list:0lf's gear list
Sony RX1 Fujifilm X70 Canon G7 X II Apple iPhone 13 mini
Yannis1976
Yannis1976 Veteran Member • Posts: 6,308
Re: G9X for size, G7X for tilting screen and ZS100 for versatility
Hi,
No matter which camera you get, there is not a perfect one. Having used both m43 systems and older good Panasonic P&S cameras, I can assure you that the G7X that I have is one of the best compromises I have ever found.
The quality of the G7X can be easily found in flickr. For me this guy here has really mastered this camera achieving excellent results:
https://www.flickr.com/photos/big_rock/
If you are interested in the shortcomings of this little gem, you can read my review some months ago:
http://www.dpreview.com/forums/post/56854979
http://www.dpreview.com/forums/post/56849984
If I were now for an 1" camera, I would look into:
1) the G7X mk2 as all around solution
2) the G9X for its great little size
3) the ZS100 for its long zoom combined with its small size.
Definitely not an RX100 because of lack of touchscreen and high cost.
Best regards
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
