Sigma 17-70mm f/2.8-4 Dc and MC-11 Converter
Started Jun 2, 2016 | Discussions
rocketjacket
rocketjacket Regular Member • Posts: 192
Wondering what the experience of using the Sigma 17-70mm f/2.8-4 Dc and MC-11 Converter is like on an a6000.
Any issues with the lens stabilation? Or any other issues?
 rocketjacket's gear list:rocketjacket's gear list
Ricoh GR II Panasonic GH5 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 Sigma 30mm F1.4 for Micro Four Thirds
Sony a6000
jezzad Regular Member • Posts: 224
Re: Sigma 17-70mm f/2.8-4 Dc and MC-11 Converter
Do you have the lens already? If you were buying it specially I would pass, it would probably be fairly average.
The adapters are designed for people who already have lens collections in a particular mount.
 jezzad's gear list:jezzad's gear list
NEX5R Sony a6000 Samyang 12mm F2.0 NCS CS Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 35mm F1.8 OSS +1 more
rocketjacket
OP rocketjacket Regular Member • Posts: 192
I am after a faster mid range lens for my E mount, any suggestions?
PC Wheeler
PC Wheeler Forum Pro • Posts: 17,902
Faster than what lens?
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot ELPH 330 HS Sony RX10 IV Panasonic ZS100
mcslsk Veteran Member • Posts: 5,773
On the a6000, you should go with native e-mount if AF is important to you. With the a6300, the Sony  a-mount 1650/2.8 SSM  is an option that works.
 mcslsk's gear list:mcslsk's gear list
Sony a6500 Sony Alpha NEX-5N Sony Alpha NEX-6 Sony a7R III Canon EF 135mm F2L USM +53 more
coloR blinD Forum Member • Posts: 72
5
We , the foolish Sony apsc lot expecting a fast mid range wide-tele zoom from Sony ....for 6 years now ....
...The a6300 falls a mere crap without such a native e mount apsc ....but Sony never cares !
Sony will never release an APSC 17-55 f2.8 or similar lens because that would be exactly the same size and price and quality as for example an A7 with 24-70 f4
...certainly all the the lens inventory of fast dying A mount system is then being 'directed' to apsc e mount thru LEA LOA LWA LUA adapters ...what a roadmap by Sony for apsc e mount !
Ever thought about how big (and expensive) such a lens would be? If you look at exisiting offerings for a-mount from Sony, Sigma, Tamron, or comparable lenses from other camera makers: Do you think there is any chance Sony could produce a smaler, less expensive "fast" mid-range zoom? And if Sony would offer the 1650/2.8 in e-mount, how many would put that on an a6000 or a6300? We all would love to haewv a small, lightweight, inexpensive and fast mid-range zoom. Don't think it is going to happen. Until then, use the exisiting 1650/2.8 which works great on the a6300 and is relatively inexpesnsive.
PC Wheeler
What drivel that statement is!
Phil
Entropy512 Veteran Member • Posts: 4,842
Wrong in the case of the MC-11.  The MC-11 was designed so that Sigma could sell their SGV lenses to Sony body users without creating new lens part numbers.
As to how well it works with the A6000 and 17-70 - I don't know, but I'm likely ordering that combo in a month or so.
 Entropy512's gear list:Entropy512's gear list
Sony a6000 Pentax K-5 Pentax K-01 Sony a6300 Canon EF 85mm F1.8 USM +5 more
Note that unlike most adapters, the MC-11 emulates a native lens instead of an EA3 adapter.
rocketjacket
What 1650/2.8 are you referring to and what adapter?
rocketjacket
The kit lens.
rocketjacket
I would like:
Optical Stabilization
The speed of a 2.8
Auto focus for video and stills
I wonder in the 17-70mm f/2.8-4 Dc and MC-11 combo would do the trick?
Sorry. I was referring to the Sony DT 1650/2.8 SSM for A-mount and the LA-EA3. €580 + €130 @ amazon.
grasshpr
grasshpr Contributing Member • Posts: 540
I've got the sigma 17-70mm contemporary and MC-11 with the a6300.  The sigma 17-70mm is very sharp, which is one of the main reasons why I wanted to explore this direction rather than purchase the super expensive sony 16-70mm.  In terms of autofocus, it is pretty snappy in acquiring focus, and the focus accuracy is very good.  Under very poor lighting, this lens and adapter combo will tend to hunt a little bit, but usually will find focus.  In comparison to the speed of autofocus for the Viltrox II adapter, I think they have similar autofocus speeds.  I'd recommend the MC-11 vs Viltrox II adapter only if you have need for some of the other focus modes and focusing areas that are intrinsic of e-mount lenses.  However, DMF is useless with this combo since you have to switch the on-lens AF/MF switch to engage MF mode.
Image stabilization also works really well for this combo, probably on par with most of my other e-mount lenses.  Two caveats of this lens is the weight of this lens and the autofocus motor is a bit loud compared to my other e-mount lenses.  If you can ignore these problems, you will be pleasantly surprised with a lens with very good IQ at an affordable price.
 grasshpr's gear list:grasshpr's gear list
Sony a6000 Sony a6500 Sony a7 III Sony FE 70-300mm F4.5-5.6 G OSS Sony FE 70-200 F4 +13 more
Arneb Contributing Member • Posts: 525
I've got the sigma 17-70mm contemporary and MC-11 with the a6300. The sigma 17-70mm is very sharp, which is one of the main reasons why I wanted to explore this direction rather than purchase the super expensive sony 16-70mm. In terms of autofocus, it is pretty snappy in acquiring focus, and the focus accuracy is very good. (...)
So, in short, it seems like a great lens on the a6300!
Have you also tested it on the a6000? Many forum members (like me) haven't yet upgraded :).
I'm also interested in the performance of the a6000 + MC-11 + Canon 10-18 STM. Canon's WA is quite a bit cheaper than the Sony one...
Do you also know whether the AF-C in video works (probably really different results between a6000 and a6300)?
rich07 Regular Member • Posts: 130
I get fed up of hearing these pathetic handwringing excuses for Sony.
 rich07's gear list:rich07's gear list
Sony a6000 Nikon D600 Fujifilm X-T10 Sony E 55-210mm F4.5-6.3 OSS Sigma 60mm F2.8 DN Art +6 more
Rich, that's an f4 lens, similar to Sony's 16-70. Fuji do have an f2.8 lens, but it is much bigger, heavier and more expensive. The Sony equivalent to this is the 24-70mm f4 on an A7.
