A week of travel with manual focus primes on the GX8
Started Jun 2, 2016 | User reviews
cameron2 Veteran Member • Posts: 4,142
11
I think enough reviews have been done already of the GX8. Depending on which ones you read, it's too large and heavy or just right, has poor ergonomics or great ergonomics, is an upgrade from the GX7 or a downgrade from the GX7, etc.
I've been shooting with the GX8 since it first came out, but one of the things that I really liked about it was how nicely it worked with manual focus lenses. I would spend a month or so at a time shooting only manual focus lenses -- "just because" -- but finally had a good excuse to pack up a manual focus kit for a trip and see how well they traveled.
First, the kit:
  • GX8
  • Voigtlander 42.5mm f/1:0.95
  • Voigtlander 25mm f/1:0.95 (version 1)
  • Voigtlander 17.5mm f/1:0.95
  • Kowa Prominar 8.5mm f/1:2.8
  • Rokinon 7.5mm f/1:3.5 fisheye
  • OURAI USB charger for BLC-12 batteries
  • Heliopan 58mm Polfilter cicular slim SH-PMC polarizer
  • EzFoto 52mm hood for the Voigtlander 25mm (with a 58mm thread on the front)
  • 58mm rubber collapsible hood
  • CourierWare Incognito "mini" courier bag - without padding
  • 64GB flash - Sandisk Extreme Pro SDXC1 U3
The harsh truth: Even though the kit packed pretty well into the small bag, I can't comfortably carry that large of a kit on a shoulder. I had really wanted to have this range of lenses available at my fingertips, but in reality I ended up going out with only 1-3 lenses at a time. I'll get to the "sweet spot" later, but suffice to say, the Voigtlanders and the Kowa are all built like tanks, and are heavy like tanks.
Second, a little bit of history. I first picked up m43 with the G1 in January of 2010. Previously, I shot 135 format, so I hoped I could use m43 with my old manual-focus and manual-aperture Canon FD and Voigtlander M lenses. The G1 was ok with these. The GH2 was ok with these. The GX7 was ok with these.
Third, for configuration and settings, I leave the LCD display set to "On monitor recording information" which is basically a large touch-screen menu, and I set white balance and ISO by hand. The front button (F7) on the camera is set to zoom in for manual focus aid "AF Mode/MF", with the "MF Assist Display" option set to "FULL", and "Peaking" set to "HIGH" and pink. "Highlight" set to "ON" with "Zebra Pattern" set to "ZEBRA2". "Shoot without lens" is obviously turned on. Most of the other settings are still on their factory defaults. I shoot RAW+JPEG but workflow goes through LR6.
Love the Voigts. This is nowhere near wide open. What happened to the green?
Out and about, I'd almost always have the 17.5mm or 25mm on the camera. I think this picture is with the 17.5mm, but to be honest, who cares, because they both render so nicely. This is a slight crop, but here's the crazy thing: Whatever color profile comes in LR6 has always stripped away a significant amount of PUNCH in the Pany files. What do I mean by this? Well, when I first click on a photo in LR6, it looks great, but then a few seconds later, LR6 re-draws it with "the flat colors palette". Since I shoot RAW+JPEG, I'm guessing that the first image shown is the JPEG, and the re-draw is the RAW with the LR6 color profile applied, but that is just a guess. Regardless, that first image ALWAYS looks far better than the second one.
Focusing with the peaking turned on is usually pretty easy with these lenses. For the most part, you only really have to focus on things that are relatively close, because the "infinity range" starts only a few meters out (and even closer with the Rokinon). Stopped down to F4, these lenses have a great DOF for outdoor shots. You can see the peaking move back and forth over the scene as you compose and focus, and for the most part the peaking doesn't lie:
Stockholm
The problem with focus with these lenses is when there is a specific thing that you want to focus on with maximum sharpness, and when that thing isn't in the general "infinity range". For that, I use the F7 button on the GX8, which is the one that theoretically falls under the middle finger. The only problem with this button is that it moves. It literally moves around the front of the camera, trying to hide from your finger. I've been using this camera for a year now, and I still can't find that button half the time! I did buy a material to put onto the button to make it more easily findable and usable, but despite that material arriving months ago, I didn't bother to apply it, and I really wished that I had BEFORE this trip!
However, if you can find the little button, the focus aids on the GX8 are really good, and with the near focus capabilities of these manual focus lenses, it can be quite effective. A flower is probably not the greatest example, because it moves around a bit in the wind, but with the focus aids, I could make out quite a few details from the reflections in a subject's eye...
Flower, botanical gardens in Götland, probably with the 17.5mm or 25mm Voigt
For low light and stabilization, the combination of the GX8 and the Voigtlander f/1:0.95 lenses is quite nice. The Vasa Museet was quite the challenge for lighting!
Vasa Museet and never enough light!
Regarding the Kowa Prominar, I had really hoped to use this lens more, as it tends to lose out to the Pany 7-14 zoom most of the time when I have to grab a wide lens, but frankly it just wasn't worth the added weight on days when I wasn't expecting to shoot much wide. The few shots I took with it were plenty sharp and pleasing, but I really didn't have any great occasions for it the few times that I had it with me.
The Voigtlander 17.5mm on the other hand was a near constant on the camera. What a nice lens. The few times that I didn't take the 17.5mm, I took the 25mm instead, and it is very similar, except for the field of view. I don't really think that consciously about field of view with primes; they just seem to work, like they used to on 35mm cameras. Whichever lens that I had, it was the right one.
The Voigtlander 42.5mm only came out a few times. Another great lens, but it just didn't get enough time on the camera.
Rokinon fisheye in the ruins of a church in Visby, Götland
The handiest "second lens" on this trip turned out to be the Rokinon fish-eye. For the odd shot that needed an extra wide FOV, I could pull it out, and it focuses easily and weights almost nothing.
Good
  • Can't complain about any of these lenses in terms of sharpness, although wide-open, the Voigts are slightly soft in the center and truly soft everywhere else.
  • The GX8 balances well with these lenses, and the IBIS is really good in the GX8 for these lenses.
  • The manual focus aids in the GX8 combined with an incredible EVF really make it achievable to shoot consistently sharp, deliberately-focused and -exposed images with manual focus lenses.
  • Heliopan SH-PMC polarizer -- good quality.
  • OURAI USB charger -- it worked! Handy for travel. Never used it before this trip, so I was relieved that it actually worked!
  • Battery life was pretty amazing. Thousands of shots. Only charged the battery once. Didn't spend a lot of time thinking about why, though.
Bad
  • Loss of handy flash compared to the GX7
  • Seemingly crazy randomly moving and hiding "F7" front button on the GX8
  • EzFoto 52mm hood - Vignetting on the Voigt 25mm when using the polarizer on the "step up hood" (which is not surprising at all, but I didn't have my 52-58 step-up ring with me.)
Ugly
  • LR6 default color profile for the GX8 seems to be designed with a Freudian level of repression
  • Crazy moving focus rectangle drives me nuts (simple solution though; see: http://www.dpreview.com/forums/thread/4003776)
  • Physics. Why do nice lenses have to weigh so much? (Note: The Rokinon doesn't.)
Summary:
The GX8 is a really nice implementation for shooting manual focus lenses. For me, carrying more than one of the Voigtlander (or Kowa Prominar) sized lenses for an entire day is a non-starter, but I discovered that one was almost always enough. (Maybe an ideal kit is the Voigtlander 17.5mm or 25mm on the camera, with the Rokinon fish-eye and the Pany 14-140 mark-ii in the bag.) I've tried shooting with manual focus lenses for years on m43, but this is the first camera that I've tried that really nails it. As long as I can find the F7 button with that finger, I can leave my eye glued to the EVF while I compose, focus, even change aperture (I watch the aperture setting with my left eye, which is often open while shooting). I enjoyed every aspect of this, except the weight of carrying several of these lenses.
Funny realization: I think I could be happy with the Voigtlander 17.5mm on the camera 90% of the time.
Scandinavia. Bicycle. Seemed appropriate.
 cameron2's gear list:cameron2's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Hasselblad X1D
20 megapixels • 3 screen • Four Thirds sensor
Announced: Jul 16, 2015
cameron2's score
4.5
Average community score
4.5
bad for good for
Kids / pets
unrated
Action / sports
unrated
Landscapes / scenery
great
Portraits
excellent
Low light (without flash)
great
Flash photography (social)
unrated
Studio / still life
unrated
= community average
drcPhoto
drcPhoto Contributing Member • Posts: 611
Re: A week of travel with manual focus primes on the GX8
Not everyone who really enjoys photography is going to also love Voigtlander lenses, after all as you say they are manual focus, big, heavy, and built like a precision built tank. No, not everyone, but I am happy I share your passion for these fabulous lens. I presently have three: the 17.5mm (my favorite and most used), the fabulous 25mm, and a rather small manual focus Voigtlander Helier 75mm f2.5. I should say I came really close to also buying the Voigtlander 42.5mm, but got a case of laziness so wet with the automatic focus Nocticron 42.5mm f1.2 instead (what can I say???).
I do love my Voigtlander's though, and it is a rare time indeed when one of these beautifully made lens isn't on my GH3 or my E-M1. They have helped make photography fun for me.
Thanks for sharing your story and review.
Dale
 drcPhoto's gear list:drcPhoto's gear list
Panasonic Lumix DMC-GH3 Sony Cyber-shot DSC-HX9V Fujifilm X100T Olympus E-M1 Voigtlander Nokton 25mm F0.95 +27 more
OP cameron2 Veteran Member • Posts: 4,142
The Nocticron is quite the lens. I think you made the right choice there. I had the Nocticron already (got a good deal on it new via Pany's EPP) but then ran into a well priced Voigtlander 42.5 and couldn't say no ....
DogsRule New Member • Posts: 17
Hi, Cameron. I have a  GX8 and I JUST got the Voigtlander 17.5 mm. Which stabilization are you using in the menu--or, rather, which one qualifies as IBIS (both?)? Then, when the camera turns on, and the camera asks about the focal length, do you stay at 35mm? Should I switch to 18mm?
Confused. Thanks either way.
mshine
mshine Regular Member • Posts: 195
Congrats for an excellent lens choice!
Only 'body' IS works with manual lenses, and when taking stills. Unfortunately, with manual lenses video doesn't have IBIS.
Set IBIS focal length in terms of the format, at 18mm. However, if you're coming from Olympus don't expect a miracle from the IBIS...
Also, I've found peaking unreliable with shallow dof. Better way to 'peek' is to set sharpness at maximum +5 for chosen picture mode. High contrast areas start to flicker when in focus and indicate critical focus accurately. Note that this method works only when shooting raw; maximum sharpness setting will ruin jpgs by oversharpening them.
http://www.flickr.com/photos/elahtine
You see things, not as they are, but as you are.
larsbc Forum Pro • Posts: 18,282
You select the focal length of the lens.  In that case it is 17.5mm or the closest to it (17 or 18).
Lightroom
It's very easy to adjust the saturation, contrast, and tone curves and then make them the default every time you import into LR.
pdk42
pdk42 Senior Member • Posts: 1,299
That shot of Stockholm shows some pretty nasty blurring and CA on the left hand side.  I thought at first it was field curvature, but the right hand side looks fine.  It might be worth getting it looked at for de-centering.
 pdk42's gear list:pdk42's gear list
Olympus PEN-F Panasonic Lumix DC-S1R Panasonic Lumix DC-S5 +1 more
Unfortunately it's hard to remember which lens that was ... it might have been the 42.5 (I had a few of the voigts with me at the time). I never tested them for de-centering, but I have a rough idea how to go about it (high-detail in-focus fixed subject, comparing shots with camera right-side-up vs. up-side-down).
jeffharris
jeffharris Forum Pro • Posts: 11,409
Nice write-up! Great camera. Fantastic kit! Looks like a great trip!
The GX8 is damn near perfect for working with manual lenses. I set up the Fn7 button (in front) to trigger magnified view for focusing.
I'm a Voigtländer user, too. 17.5mm, 25mm, 35mm f1.4 Nokton Classic, 42.5mm and 75mm f2.5 Color Heliar. My favorite walkabout kit is the 17.5mm, 42.5mm and 75mm.
For the wide end, I've had my eye on the Kowa 8.5mm, but now I'm waiting to see how the Laowa 7.5mm f2 stacks up… when it's finally released. For now, I blaspheme with a the 7-14mm f4.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
BillSprague Senior Member • Posts: 1,504
Thanks for the review.  I want one of those 17.5s!
"here's the crazy thing: Whatever color profile comes in LR6 has always stripped away a significant amount of PUNCH in the Pany files. What do I mean by this? Well, when I first click on a photo in LR6, it looks great, but then a few seconds later, LR6 re-draws it with "the flat colors palette". Since I shoot RAW+JPEG, I'm guessing that the first image shown is the JPEG, and the re-draw is the RAW with the LR6 color profile applied, but that is just a guess. Regardless, that first image ALWAYS looks far better than the second one."
That is the way LR is supposed to work.
Even with RAW only, after import the "embedded" (in the RAW file) first preview is displayed. It includes all the sharpening, saturation, luminance, etc that the camera does to process the RAW data to what you see on the LCD when you chimp. Then, LR builds a second preview from the RAW data that is intended to be free of all corrections so that you can make them to your taste. You get to add the saturation, sharpening, clarity and vibrance to your taste, rather than Panasonic's.
There are two LR provided methods to quickly adjust the intentionally dull preview. One is the tiny "Auto" button in the Develop module. It will bump the sliders to something Lightroom guesses will make you happy.
The other method is to apply a "preset". After one trip where I compared my RAW results to my DW's JPEGs from her Panasonic purse camera, I was frustrated. Her colors were "better". Asking for advice, she said, "Set it to 'Happy Color'". The Panasonic LF-1 really does have that choice in the menu. As best as I could, I created a custom preset to mimic Happy Color and can apply it to some or all of my images! Point and shoot JPEG purse cameras be damned! I shoot RAW!
Bill Sprague
 BillSprague's gear list:BillSprague's gear list
Sony RX100 Panasonic LX100 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica 100-400mm F4.0-6.3 ASPH +1 more
Thank you!
jalywol
jalywol Forum Pro • Posts: 12,301
Custom profiles
Unfortunately, for whatever reason, as you have discovered, LR does not have a pull-down selection of RAW development profiles that are equivalent to the native in-camera profiles for Panasonics. They have them for Oly, they have them for Sony....but not Panasonic.
You can pretty easily create your own if you have a color calibration card/chart, by photographing the card in the light you will be using, and then adjusting the color/hue/luminosity sliders to match the card colors to the JPG version. It takes a little practice, but you can come up with some pretty good profiles if you work on it.
I had to do this with the GM5 as its RAW output in LR is just dreadful. I came up with a  good profile for it for very bright shooting situations that I use when doing outdoor sunny day flower photography, and it works quite well.
I did also, however, purchase a set of Huelight profiles for the GM5, and those are very good, especially for more normally lit images. They are vastly superior to the LR6 native conversion profile, and can be used as is or as starting point for developing other profiles, too.
Interestingly enough, I did pick up an X-Rite Color Checker Passport a number of years ago, when I had a GH2 (which had some major color rendition flaws that needed addressing). It includes a handy white balance and color card in a protective plastic case, plus software to analyze the images you take of the card and generate profiles automatically. The card part of it is really nice, as it's very handy and nicely protected when you take it with you. However, I don't think the software has really kept up with newer cameras. It generated very good profiles for my GH2, but on every more recent camera I've used it on, it has heavily oversaturated the reds, and I've had to do major adjustments to whatever profiles it has ended up auto-generating. So, now I use the card as a starting point and then do a manual profile if I need one (with varying degrees of success ) As a result of this experience, I think you probably could do just as well with a good set of the color cards alone, and manual adjustment to generate a good profile.
The other thing you could do is change your workflow a bit. You could open up the RAWs in SilkyPix, which is supplied by Panasonic, and, of course, DOES have the profiles loaded, and then export a TIFF or DNG file with the native profile applied, and then work on that in LR, instead. It would definitely give you access to the native profile as a starting point for your RAW development, even though it's a bit of a pain to do it that way.
Hope this helps,
-J
Re: Custom profiles
Yeah, I got the colorite for the GH2 as well, and I've been intended to grab or make some color profiles for LR, but just haven't had the time ...
