black box appears on images olympus em10
Started May 29, 2016 | Questions
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Re: black box appears on images olympus em10
robgendreau wrote:
alfredo_tomato wrote:
Because it happens on different cards, and different cameras makes me think it is in Photos.
Now I am testing to see if it has something to do with RAW files. I am shooting JPG to see if the issue shows up.
It would help if you put an image file somewhere so that others could see if the same problem exists on other systems.
Pardon my asking but when you upload a picture to dpreview, don't you upload the file itself and we are looking at the dpreview viewer itself, not the OP's?
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
alfredo_tomato
OP alfredo_tomato Veteran Member • Posts: 4,382
I uploaded from my computer. The Cacti is an unedited, the other is a screen grab.
 alfredo_tomato's gear list:alfredo_tomato's gear list
Olympus PEN E-PL1s Olympus PEN E-PM2 Olympus OM-D E-M10 Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +13 more
brycesteiner
brycesteiner Senior Member • Posts: 1,934
I see you shoot RAW. Does it do this if you shoot JPG (full res)?
That would eliminate the viewer because you can check it out on many programs.
Make it a Great day!
 brycesteiner's gear list:brycesteiner's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus E-M5 II Olympus E-M1 II Panasonic Lumix G 20mm F1.7 ASPH +9 more
alfredo_tomato
I just starting to shoot jpg, after years of just shooting raw. So far, so good.
Martian Flatcat
Martian Flatcat Regular Member • Posts: 457
The Olympus viewer software is available on Macs too. Try looking at the existing problem .ORF raw files in that? I haven't seen any mention of trying that in the thread yet. If it looks good there, I would suspect the Photos app.
--Flatcat
What's a flatcat? https://en.wikipedia.org/wiki/Flat_cat
 Martian Flatcat's gear list:Martian Flatcat's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic 20mm F1.7 II Olympus 12-40mm F2.8 Pro Panasonic Lumix G 14mm F2.5 ASPH +7 more
brycesteiner
You exactly right. That would be the first place to start if you want to keep shooting RAW.
alfredo_tomato
For now I will shoot jpg to see what happens. I think it is how Photos handles RAW.
BTW, how good are the editing tools in the Oly viewer?
haslo
haslo Regular Member • Posts: 411
Some claim that it's the best way to develop Olympus RAW files. You get curve adjustment, noise control tools, and all kinds of color balance and intensity management.
If you shoot RAW, it's a bit of a waste to use Photos. Photos is targeted at the Instagram crowd, and shows a similar level of subtlety in its tools.
 haslo's gear list:haslo's gear list
Olympus E-M1 Olympus E-M5 II Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +8 more
alfredo_tomato
Thanks. How do I change the default from Photos to Oly viewer?
Alex Ethridge
Alex Ethridge Veteran Member • Posts: 5,424
Assuming Windows 8.1, right click on the ORF file> select "Open With"> "Choose Default Program"> be sure there is a check-mark next to "Use this program for all ORF files"> click "More Options"> scroll to bottom of the the list> click "Look for another app on this PC"> browse to C:\Program Files (x86)\OLYMPUS\OLYMPUS Viewer 3> select  "OLYMPUS Viewer 3.exe"> click Open.
Click OK.
You're done.
 Alex Ethridge's gear list:Alex Ethridge's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-G1 Panasonic GH5 Sony a7 III Nikon AF Micro-Nikkor 60mm f/2.8D +10 more
alfredo_tomato
I'm on OSX, and Photos comes with the OS.
haslo
Select the file, Cmd-I (should be "Information" in the popup menu if you right click), a bit down you'll see "open with:".
Select the program you want from the dropdown, use "different program" if it isn't in there. Then click "change all".
Voilà.
Bryan
Bryan Senior Member • Posts: 2,570
You don't need Windows to test. May I suggest you use Olympus Viewer 3 for converting from RAW. I have this running under El Capitan on my iMacs and Windows 10 Pro on my Dell Laptop i5. I have never seen such an image since moving to digital from film many years ago.
The comments about card errors make sense to me but if you have tried a few different brands/speeds and all the same I would recommend sending the camera back for exchange or refund. Are all images showing this same problem? Was your battery fully charged? Was your card charged in camera - it should have been as Mac OS is different. Have you tried your cards in other camera bodies, ask a friend?
I am using Mac OS and Olympus Viewer so we are both using the same system. I would give Photo a miss even though it is free, Viewer 3 is also free and much much better. Feel free to send me a RAW image, not the one displayed, and I will check it out for you.
Bryan
Box-Brownie and other stuff.
iMac 27" i5 5K also old i7
Still looking for a digital back for my Box Brownie.
 Bryan's gear list:Bryan's gear list
Panasonic Lumix DMC-ZS40 (TZ60) Sony RX10 IV Canon EOS D30 Canon EOS 7D Mark II Canon EF-S 18-135mm F3.5-5.6 IS USM +5 more
Bryan
I find Olympus Viewer to do an excellent job. Doesn't have all the bells and whistles that many have but I prefer the RAW conversion quality to Adobe Elements which I also have. I also have, and use DxO Optics Pro Elite 10, but also have the one month free trial of 11 running to compare. Worth giving the free 30 days trial a go?
Olympus Viewer does the majority of things I need and does them well. I never used iPhoto nor do I use Photo. Without spending a penny more install Viewer 3, allow auto updates then enjoy. Hopefully this may have sorted out your problem.
Good luck.
Bryan
alfredo_tomato
It happened on my EPM2 and my EM10, on different cards, over several upgrades to OSX. I even changed the usb.
Now I am experimenting with Oly Viewer 3.
alfredo_tomato
I think I have found how to keep Photos from launching.
alfredo_tomato
Thanks. I am making the transition to Oly Viewer now.
