black box appears on images olympus em10
Started May 29, 2016 | Questions
alfredo_tomato
alfredo_tomato Veteran Member • Posts: 4,382
This has happened twice since May 16.
This is a factory refurb.
I had a similar issue with my EPM2, instead of a black box, a block of the image was pasted within the image.  Should I return the EM 10?
http://www.flickr.com/photos/alfredo_tomato/
 alfredo_tomato's gear list:alfredo_tomato's gear list
Olympus PEN E-PL1s Olympus PEN E-PM2 Olympus OM-D E-M10 Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +13 more
Olympus OM-D E-M10 Olympus PEN E-PM2
Dutch Newchurch
Dutch Newchurch Veteran Member • Posts: 5,716
Re: black box appears on images olympus em10
Yes, if it were mine and still under warranty, I'd return it.
(unknown member) Regular Member • Posts: 278
Have you tried a different memory card? Might save some frustration if it is that simple.
www.flickr.com/photos/simonallam
Jeff Tokayer Veteran Member • Posts: 6,289
It's...
It's a "censored" camera.
My nickel, since the penny is now discontinued...
Jeff.
alfredo_tomato
OP alfredo_tomato Veteran Member • Posts: 4,382
I will give that a try
alfredo_tomato
Re: It's...
That makes sense
alfredo_tomato
That is a real option.
alfredo_tomato
I think it is the OSX Photos app
Giiba
Giiba Regular Member • Posts: 414
The Oly .orf files have a thumbnail preview embedded in them. Non-compliant viewers will glitch and display that thumbnail in a variety of ways, such as your example.
Have you tried a different viewer?
 Giiba's gear list:Giiba's gear list
Olympus E-M1 Olympus 40-150mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH Olympus 8mm F1.8 Fisheye Pro Panasonic 8-18mm F2.8-4 +1 more
alfredo_tomato
Non compliant viewer?  I import from my camera to Photos.
Robert Evagelista
Robert Evagelista Veteran Member • Posts: 3,448
Most likely memory card as mentioned above... many cases of this already...
Be kinder than necessary, lets make this a better community.
http://robertevangelista.blogspot.com/
https://www.flickr.com/photos/robert_evangelista/sets/72157647543027710/show
 Robert Evagelista's gear list:Robert Evagelista's gear list
Olympus E-M1 Samyang 85mm F1.4 Aspherical IF Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Canon Pixma Pro-100 +11 more
RedDog Steve
RedDog Steve Senior Member • Posts: 1,972
"No EXIF data" ?
That, plus 2 cameras with the same unusual issue raises a red flag.
Additionally there seems to be some issue with the rest of the image as well.
Can you post the SOOC jpg ?
My deduction is it's downstream from the camera.
rd
 RedDog Steve's gear list:RedDog Steve's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Panasonic Lumix G Leica DG Summilux 12mm F1.4 ASPH Panasonic 8-18mm F2.8-4 +17 more
alfredo_tomato
I changed memory cards.  Now I see this anomaly. Note the picture within the picture below the blooms.
alfredo_tomato
I'm starting to believe it is the Photos app.
Robert Evagelista
When you view it in the camera, I assume it is ok.
If so, it might be your photo viewer.
alfredo_tomato
I'm starting to think that is the case.
Al
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
My own thought exactly; perhaps a memory writing error?
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
alfredo_tomato
Because it happens on different cards, and different cameras makes me think it is in Photos.
Now I am testing to see if it has something to do with RAW files. I am shooting JPG to see if the issue shows up.
robgendreau Forum Pro • Posts: 10,931
It would help if you put an image file somewhere so that others could see if the same problem exists on other systems.
“Art is not what you see, but what you make others see.”
— Edgar Degas
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
alfredo_tomato
I don't have access to Windows or Linux to test it.
