New Fuji XF 14mm + Fuji Serial Numbers
Started May 29, 2016 | Discussions
jchabalk Regular Member • Posts: 123
I recently received a new fuji 14mm and i'm trying to figure out how new it actually is. It came from B&H and is in fine condition but it had been opened before i got it. (The bag the lens was in had been gone through and was crinkled up and the paper work on top was packed crookedly).
I've seen a couple of threads on Fuji serial numbering but i haven't seen one that answers the question of build dates definitively yet - and this lens' serial number is much lower than my other lenses (also purchased new).
The S/N of my lens starts with: 48A0
If the first number is the year as has been mentioned before i've got a 2 year old new lens. I don't care too much but the fact that the box has been opened previously makes me want to understand what's going on a little more.
Can anyone else who's recently received a new 14mm share the beginning of their S/N?
Clayton1985 Veteran Member • Posts: 8,802
Re: New Fuji XF 14mm + Fuji Serial Numbers
Maybe Fuji has a bunch of 14mm lenses sitting around.   Probably why there are discounting this lens so much.
OP jchabalk Regular Member • Posts: 123
agreed, seems like they're either trying to simply clear out old stock and/or prepare to release an updated version. I've never gotten returned gear from B&H before and i've been using them for a long time so the whole thing is a little off-putting.
Forgot to mention that mine is from B&H and in the same range but it is clearly brand new from what I can tell.    The Fuji lenses aren't sealed in the plastic bags so it can be hard to tell if someone actually opened it or if it was a sloppy job by Fuji assembling the box to begin with.    If the lens is perfect I wouldn't worry about it.
d750guy Senior Member • Posts: 1,001
not sure if this helps but I recently purchased 23mm 1.4 and 56 1.2 from b and h, serials 55A and 58A respectively. So both manufactured in 2015.
Chris Dodkin
Chris Dodkin Forum Pro • Posts: 13,956
First World Problem
People worry about the strangest stuff - suggest mounting the lens on the camera and putting it to use
Your time is limited, so don't waste it arguing about camera features - go out and capture memories
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm X100F Fujifilm X100V Fujifilm X-T2 Fujifilm GFX 50S Fujifilm GFX 50R +50 more
Re: First World Problem
buying new stuff and getting used stuff instead?
Chris Dodkin
If you really think it's used, contact B&H - and/or your credit card company
If it's in perfect condition, and works perfectly, does it even matter if the bag was crinkled...
i've got it covered. thanks for the advice!
Jake21 Contributing Member • Posts: 533
I have a similar but slightly different question. Rather than start a new thread I was hopeful it could be answered here. On the fuji lens (14mm) I received the receipt (b&h) and box have a comment f/x-pro1 on the box. What exactly does f/x-pro1 indicate ?
