Fuji 14mm Focus Ring Slop
Started May 27, 2016 | Discussions
jchabalk Regular Member • Posts: 123
I just received my 14mm... (purchased when the sale started). Put it on the camera for the first time tonight and there's a slight bit of play back and forth of the focus ring when it's slid forward to the autofocus position.
Can anyone comment on whether that's normal or not?
I have a 23mm 1.4 also and there's no play at all in the focus ring when it's in autofocus mode - on this 14mm i have it's definitely not firmly fixed in place.
The Serial Number starts: 48A0
Any idea if that's been recently built?
I'm going to go shoot it tomorrow - if the focus ring is bunk though i'll likely swap it for another.
PenPix Veteran Member • Posts: 3,261
Re: Fuji 14mm Focus Ring Slop
I checked my lens and there is a slight sideways movement of 1/4 mm or so.  Quite tight otherwise.
jm10 Veteran Member • Posts: 3,715
Agree with the previous poster - a fraction of a mm play; not a concern.
 jm10's gear list:jm10's gear list
Ricoh GR II Fujifilm X-T2 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS +2 more
slimandy Forum Pro • Posts: 17,161
It's not something I have tested for but neither is it something I have ever noticed.
 slimandy's gear list:slimandy's gear list
Sony RX100 II Nikon D200 Nikon D700 Fujifilm X-E1 Fujifilm X-T1
