What is the lifespan of an EF 50mm f/1.4 USM?
Started May 25, 2016 | Discussions
Tom-C Senior Member • Posts: 1,415
Re: What is the lifespan of an EF 50mm f/1.4 USM?
When my Canon 50 F 1.4 auto focus failed I found that it was a common failure. I didn't use it a lot but always carried it in my camera bag. That apparently made damage to the auto focus mechanism more likely.
Until Canon comes out with a newer model I think either of Sigma's 50 F1.4 lenses are a better choice. I now have the Sigma 50 F1.4 Art and am very happy with it.
Tom
 Tom-C's gear list:Tom-C's gear list
Canon EOS 5D Mark IV Canon EOS R5
Suave Senior Member • Posts: 2,289
I've owned mine for about 10 years, and although I don't use it often now, there were periods where it was on my camera for months.  I never had any issues.
I think in general, when you hear complaints of this sort it is useful to ask:  "what else broke on you?"
Where's my new 50, Canon?
 Suave's gear list:Suave's gear list
Nikon D7000 Canon EOS 5D Mark III Canon EOS RP Canon EF 85mm F1.8 USM Canon EF 24-70mm f/2.8L USM +7 more
John Bohland Regular Member • Posts: 115
Mine just broke this weekend. Apparently a poor design on this particular lens. I'm going to send it for repair and make sure it's focused to infinity before storing in the future. Makes me miss the old indestructible FD lenses.
John
DKCJB Regular Member • Posts: 286
How old was your when it broke?
 DKCJB's gear list:DKCJB's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EF 20mm f/2.8 USM Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM +4 more
Approximately 8 or 9 years but it's my least-used lens.
John
OP Digital Imaging Technician Regular Member • Posts: 313
Reporting back, it broke after 1 month
Digital Imaging Technician wrote:
I have a bunch of photographer friends that shoots Canon. All of those that bought the 50mm f/1.4 has had the same problem: the AF breaks down within a couple of years. Were they just unlucky or does this lens have some serious quality issues? Searching the web doesn't make me more sure about buying it. Should this lens be seen as a consumable?
I wonder if someone has actually had the EF 50mm f/1.4 for, say, over 7 years and still has a working copy.
Just reporting back, mine held for 1 month before the AF broke went kaputt. It can now only AF objects at a close distance, but not objects that are far away. What a joke.
 Digital Imaging Technician's gear list:Digital Imaging Technician's gear list
Canon PowerShot S90 Fujifilm FinePix X100 Canon EOS 6D Panasonic Lumix DMC-GH4 Sony a7 III +11 more
expro Senior Member • Posts: 2,274
Re: Reporting back, it broke after 1 month
19 years and still fine.... My brother now uses it as his main portrait lens on his 5d3...
but I just gave him my 135L so that may change...
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
Gandolphi Senior Member • Posts: 2,840
I had the 50mm f:1.4 for 7 years and it worked perfectly. It didn't work perfectly for 7.5 years, the autofocus gave up.
The only other lens I have had a problem with is my 24-105 f:4 which also failed on the autofocus.
 Gandolphi's gear list:Gandolphi's gear list
Leica SL (Typ 601) Hasselblad X1D II 50C Leica SL2-S Leica Super-Vario-Elmar-SL 16-35mm F3.5-4.5 ASPH Leica APO-Summicron-SL 35mm F2 ASPH +2 more
MarcBton Regular Member • Posts: 257
I broke my first one on the first day I used it when I let go of it still outside the shoulder bag I thought I was placing it in when changing lens by feel, so that does not count. Big dent in lens and my pride.
The replacement started playing up after 3 years light use, no AF response whatsoever at all one day. I use it manually now not wanting to spent more money repairing it. Although rarely using it, I had kept it in my bag going everywhere most of the time though.
First camera 1979, first slr 1982, first dslr 2008
 MarcBton's gear list:MarcBton's gear list
Canon EF 50mm F1.4 USM Canon EF 16-35mm F4L IS USM Fujifilm FinePix X100 Olympus Tough TG-4 Canon EOS 5D +11 more
Schnapper Contributing Member • Posts: 995
Mine lasted a few years of light use before it first broke... I never used it much because AF was unreliable/iffy (maybe it was that I was shooting at wider aperture than I was used to, or maybe it always had a bit of an issue) and I missed focus on a lot of shots.  When it broke I brought it to Canon (Australia... a bit north of the Harbour Bridge) and they repaired it - it lasted about 10 shots before I was dropping it off again, and then it lasted a few days before the third repair.  They finally seemed to fix it on the third try - they replaced the AF mechanism (ramp and motor?  something like that).  Since that time - maybe it was about 2008 or so - it has not broken again, but I've probably used it about 5 times over those 8 years because since I got the 17-55/2.8 I really never use the 50/1.4 anymore.  2.8 is big enough aperture for me, especially when IS is an added bonus of the zoom to make up for the loss of 2 stops.  I rarely used the 50/1.4 below about f/2.0 anyway, so it's really only 1 stop I lost.
If I could do it over again, I would not get the 50/1.4.
Howard S Senior Member • Posts: 2,212
I'd guess 10 years or more and still going strong
 Howard S's gear list:Howard S's gear list
Canon G3 X Canon EOS 7D Canon EOS M Canon EOS M50 Canon EOS M6 II +12 more
lumenite Senior Member • Posts: 1,208
Same here.
Among all my Canon lenses, 50/1.4 and 24-105L had to be sent for repair.
Both are them had been kept with hood and careful treatment.
Of course, no drop or shock.
However, suddenly they did not work when I tried to use them.
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
OldSchoolNewSchool Senior Member • Posts: 1,403
I had mine 4 or 5 years and it acted like I had dropped it in sand (which I hadn't).  The autofocus mechanism was crunchy, and then it stopped altogether.  I hadn't used the lens much and I babied it all the while.  The lens was sent off to Canon for repairs.  I got it back, used it for a year, and then learned this was a common problem.  Figuring it would someday fail me again, I sold it while it was still functioning properly and replaced it with a Sigma 50mm f1.4 EX DG HSM lens.  The Sigma, IMHO is better than the Canon 50mm f1.4 lens in every way, except it is bigger and heavier, though no so much that it is annoying.
My state of confusion has turned into a circle of confusion.
 OldSchoolNewSchool's gear list:OldSchoolNewSchool's gear list
Canon G9 X II Canon EOS 5DS Canon 6D Mark II Olympus OM-D E-M1X Canon EOS 90D +21 more
