What is the lifespan of an EF 50mm f/1.4 USM?
Started May 25, 2016 | Discussions
Digital Imaging Technician Regular Member • Posts: 313
I have a bunch of photographer friends that shoots Canon. All of those that bought the 50mm f/1.4 has had the same problem: the AF breaks down within a couple of years. Were they just unlucky or does this lens have some serious quality issues? Searching the web doesn't make me more sure about buying it. Should this lens be seen as a consumable?
I wonder if someone has actually had the EF 50mm f/1.4 for, say, over 7 years and still has a working copy.
 Digital Imaging Technician's gear list:Digital Imaging Technician's gear list
Canon PowerShot S90 Fujifilm FinePix X100 Canon EOS 6D Panasonic Lumix DMC-GH4 Sony a7 III +11 more
Canon EF 50mm F1.4 USM
Rock and Rollei Senior Member • Posts: 2,916
Re: What is the lifespan of an EF 50mm f/1.4 USM?
Can't remember when I bought mine, but it's well over 7 years ago. Well over 10, for that matter. That said, it's not one of my most-used lenses, but there's certainly no timed self-destruction function in it.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
Steve Balcombe Forum Pro • Posts: 15,582
I don't have one myself but this is a well-known issue. The 50/1.4 has a unique AF mechanism not used on any other lens - micro USM with a clutch to provide full-time manual focus so it masquerades as Ring USM but it's actually inferior to the real thing. It seems to be prone to mechanical damage if there is pressure on the extending inner barrel.
The solution I often see suggested is to keep a lens hood attached to protect the inner barrel from pressure, and always remember to retract the barrel before putting in a bag.
I'm sure there are many.
nail33 Senior Member • Posts: 1,054
The first two replies say it all. I've had mine since 2006 with no problems, but I baby it as I do all my lenses.
RogerZoul
RogerZoul Veteran Member • Posts: 3,243
I wonder if keeping the lens hood attached is always a wise thing to do.  Lenses do come with hoods for some reasons...I've always assumed the reasons were 1) to block sunlight, and 2) to protect the front element.  Maybe the list is longer...
I keep my hoods on all my lenses that have them...and if they don't come with one, I usually buy a cheapo off amazon.
 RogerZoul's gear list:RogerZoul's gear list
Canon EOS R5 Canon EF 500mm f/4.0L IS II USM Canon RF 35mm F1.8 IS STM Macro Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 800mm F11 IS STM +31 more
Spotted Cow Senior Member • Posts: 1,586
I don't think that's a bad idea but the only thing would be the amount of space the lens would take up with the hood attached when storing it at home. Of course if you have the space for it, by all means.
Usually those are the only reasons, but a hood which attaches to the main barrel can protect an extending inner barrel from damage. It's not a very common configuration but it happens to be the case with the 50/1.4.
Melissa_N Forum Member • Posts: 75
I've also had the AF fail after a few years.  It was never dropped or had any undue force applied to the front.  I wish I'd known about this issue earlier on.  Leaving the hood on (even when not in use) would more than likely avoided the problem.
Melissa
 Melissa_N's gear list:Melissa_N's gear list
Canon EOS 5D Mark III Canon EF 17-40mm f/4.0L USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm F4L IS USM +4 more
gavin
gavin Veteran Member • Posts: 8,242
+1 Mine failed too. Its not a very good lens. There are some great 3rd party ones nowadays.
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
Incidentally, it replaced a 50mm f1.8 Mk II, which just fell apart in my hands - now that was a lens that really wasn't built to last.
I like the f1.4 - yes, it's got a very old-fashioned look, being somewhat soft wide open. Thankfully! Hard to find modern lenses with real character without paying through the nose for a modern recreation of an old lens.
arty H Senior Member • Posts: 1,546
I have had mine for a number of years and it is fine. I always keep the hood on the lens, since even with the hood - it is relatively compact. It is not heavily used, so this may help contribute to it working. I also don't use MF on the fly with the lens, since it is gear driven. I have never bothered to retract the lens before putting it away. I am sure that I have had it for at least 6 or 7 years.
I would be tempted to wait for a new Canon upgrade. Hopefully, it will come soon. Another option is the 50F1.8 STM Canon, since that lens is is inexpensive -- but reports are that AF is not very fast in low light. People do seem happy with it, and it may be as good as the F1.4 at F2.
photosen Veteran Member • Posts: 6,226
I had to go into my amazon order history, I've had the 50mm 1.4 for 8 years. Still working perfectly, which doesn't mean others haven't had problems, nor does it mean most people have had problems.
I've kept the hood on at all times and I try not to use filters with it.
The best bokeh goes unnoticed, grasshopper.
 photosen's gear list:photosen's gear list
Canon EOS 30D Canon EOS 70D Canon EF 35mm F2.0 Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM +3 more
DKCJB Regular Member • Posts: 286
http://www.dpreview.com/forums/post/57441765
Mine is 16 years old and still going but with a little focusing glitch from time to time. I asked the same question 2 months ago...
 DKCJB's gear list:DKCJB's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EF 20mm f/2.8 USM Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM +4 more
I've had mine for a few years and it still looks and functions like a new lens. Part of the reason being its not used nearly as much as my other lenses as 50mm is not one of my favorite FL to use. From the moment I got the lens, I've always had the lens hood on as I've read about the motor breaking from impact to the front of the lens from extending when focusing. I've been extra careful with it, and retracting the front part of the lens in by manually focusing to infinity before I put on the lens cap.
Mika Y.
Mika Y. Senior Member • Posts: 2,135
I bought the 50mm f/1.4 at around 2005 and it worked nicely until 2014. In my case it wasn't the AF that failed, instead I think some lens element must have become partially dislocated, as regardless of using AF or MF it was no longer possible to achieve truly sharp images at any aperture; even at best the fine details were mushy and there was a kind of halo-like effect.
I considered that to be a valid excuse for upgrading to the Sigma 50mm f/1.4 Art (which I haven't regretted, optically it's a very much superior lens especially at large apertures) and maybe getting the Canon lens examined / serviced at some point later as a back-up (which I still haven't done).
So in my case it survived about 9 years of frequent use, give or take a few months.
 Mika Y.'s gear list:Mika Y.'s gear list
Canon EOS Rebel T4i Canon EOS 5D Mark IV Canon EOS R7 Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM +13 more
I do that too, and with all my non internally focusing lenses as a reflex.
irm Veteran Member • Posts: 3,105
Depends!
I have two, the first one has been repaired many time over 10 years, focus motor (well that is what it is called), the gear goes out of round and jams. As many people have said, don't push on the front of the lens.
I don't use either of them that much becasue the focus speed is slow, inaccurate and not consistent. Very bad CA until you get to approx f2.2 or 2.4.
If you shoot at night without any bright lights in the scene you get excellent results which you would not normlly get.
Contrast is very bad until f2.2
my 2 exposed flashcubes worth.
Ian the pbase supporter.
http://pbase.com/ianm_au
Please check my profile for equipment list.
An amateur with dreams of being a good to excellent photographer.
 irm's gear list:irm's gear list
Canon EOS 10D Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF 50mm F1.8 II Canon EF 135mm F2L USM +9 more
Scott Larson Veteran Member • Posts: 7,505
I've broken two of them. The one I have now has lasted six years... because I never use it.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
Le_Kilt Regular Member • Posts: 206
Mine ok since 2007
Don't use it very often nowadays, but it did get some good use for a while, and it still comes out for some low light events once in a while.
Never treated it with particular care nor chucked it around carelessly, no hood, and it's still working perfectly.
Kjeld Olesen
Kjeld Olesen Veteran Member • Posts: 4,594
Mine OK since 2004
http://www.dpreview.com/forums/post/50521140
Not used a lot, but OK never the less.
Only item I recall that has actually died was a 550 EX flash after 16 or 17 years of service.
 Kjeld Olesen's gear list:Kjeld Olesen's gear list
Canon EOS M Canon EOS 6D Canon EOS M5 Canon EOS R6
