Possible Canon 55-250 IS STM Decentering Issue
Started May 25, 2016 | Discussions
skogsfaktor New Member • Posts: 2
So, i recently bought a new lens for my 7D, the Canon 55-250 IS STM. Since i am a bit pedantic with my equipment, i have been testing the lens all night. However, i have had a bit of a problem with determining if my lens has misaligned optics.
To test the issue i took a handheld photo of a nearby apartment building wall at a distance from my balcony(since i do not own a tripod). The photos were taken using a 250mm focal length, aperture of f/5.6(which is the largest), AV mode, spot AF(PDAF) and the center AF point. The camera was probably not parallel to the wall.
The photos below show the entire image and crops(not uniform) from all 4 corners, top to bottom, left to right.
The problem is that i don't know how to interpret the data. What is an acceptable difference in sharpness between the corners? It is evident that the top of the frame exhibits more chromatic aberration, with the left corner being the worst in terms of sharpness and CA. Is this difference just the result of the conditions in which the photograph was taken, or could it be that the lens has a decentering issue? Could/Would an exchanged lens perform better optically? Does this make a difference in real life shooting?
Any conclusions, tips or opinions would be of great help to me.
Complete Image
Top Left Crop
Top Right Crop
Bottom Left Crop
Bottom Right Crop
 skogsfaktor's gear list:skogsfaktor's gear list
Canon EOS 30D Canon EF 28-135mm F3.5-5.6 IS USM
Canon EF-S 55-250mm f/4-5.6 IS STM Canon EOS 7D
(unknown member) Forum Pro • Posts: 11,521
Re: Possible Canon 55-250 IS STM Decentering Issue
it's a $299 lens.. it is pretty slight. clean up the CA and see how bad it is first.
run it though DPP's DLO and look at it and decide .. but really .. when I thought you meant decentering.. I expected to see something alot worse than that.
heck that's wide open at max zoom.
I'm surprised it's that good to be honest.. that's not bad considering you haven't corrected for any aberrations yet.
OP skogsfaktor New Member • Posts: 2
Thanks for the tip!
I ran it through 50% DLO in DPP 4, making the flaws much more apparent.
Here are crops of the best(top left) and worst corner(bottom right). In my opinion the upper left corner looks more distorted. Is this normal? Could it just be an effect of my handheld shot, since the camera probably wasn't parallel with the wall?
Top Left Corner Crop
Bottom Right Corner Crop
photonius Veteran Member • Posts: 6,895
Looks quite ok. Serious decentering would look worse.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
skogsfaktor wrote:
Thanks for the tip!
hmm, to me, the bottom right looks better.   That's the point, if we can't agree on this, it can't be a serious issue.  And anyway, if you want to look for small differences, yes, you need to take it to another level, and do very careful tests with test charts, with well calibrated and aligned equipment.
catleet2016 Forum Member • Posts: 64
there are several articles online that shows a quick way to test if the lens is decentered, just google it, but for a 400mm equiv lens on crop body, super lightweight for <$150...cant really complain!
 catleet2016's gear list:catleet2016's gear list
Canon EOS 7D Mark II Canon EF 35mm F2 IS USM
