Question: camera opens up and closes down aperture automatically during focusing/metering?
Started May 24, 2016 | Discussions
jor23 Senior Member • Posts: 1,556
It's the first time for me to notice this on my E-M10.
I was trying to get a shot of an object and the room was dark. So, I brought over a table lamp to illuminate the object.
I set my Panasonic 14/2.5 to f10 and tried to take a picture in A mode. When I point the camera to a dark area of the room, it seems that the camera opens the lens up automatically. When I point it back to the object, it closes down the aperture. All of these without me touching any control.
Is this how it is supposed to work?
I observed the same thing with the 45 f1.8.
This only happened when the lens was stopped down to around f10.
Please educate me. Thanks!
Olympus OM-D E-M10 Panasonic Lumix G 14mm F2.5 II ASPH
Martian Flatcat
Martian Flatcat Regular Member • Posts: 457
Re: Question: camera opens up and closes down aperture automatically during focusing/metering?
I noticed it after the last firmware upgrade.  Was shining a flashlight into the lens (at an offset) to look at the blade pattern.  I think it's the camera trying to protect the sensor from burns.
--Flatcat
 Martian Flatcat's gear list:Martian Flatcat's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic 20mm F1.7 II Olympus 12-40mm F2.8 Pro Panasonic Lumix G 14mm F2.5 ASPH +7 more
Danielvr Veteran Member • Posts: 6,863
Yes. It's meant to keep the viewfinder's brightness more constant. I don't know about the E-M10, but the E-M1 has a setting "Flicker Reduction" (Menu->Gear-D->Flicker Reduction) that can be turned off if the aperture's 'rattlesnaking' (as some have called it) should bother you. Maybe the E-M10 has a similar setting.
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
OP jor23 Senior Member • Posts: 1,556
Thanks for your response.
Thanks.
I was a bit worried.
Lichtspiel
Lichtspiel Veteran Member • Posts: 3,528
I have wondered if this negatively affects the lifespan of the lens shutter.
And how this affects battery life.
Probably nothing to worry about.
 Lichtspiel's gear list:Lichtspiel's gear list
Sony a7C Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 20mm F1.8G Tamron 70-300 F4.5-6.3 Di RXD III Samyang Reflex 300mm F6.3 +5 more
