Canon 350D question...
Started May 23, 2016 | Discussions
Wing0
Wing0 Forum Member • Posts: 63
This might seem like a strange question to ask, but to those of you that have used or still own a Canon Rebel XT (350D), do you find it hard to read the text on the bottom screen (where the menus and picture preview are displayed)?
I find that sometimes, I really have to strain my eyes to read through the various menu options on the screen since the text is so small. The problem with me is more pronounced when I have allergies and one of my eye lids is swollen.
Is there anything I can do to make the text a bit bigger or does anyone have any tips on what to do?
 Wing0's gear list:Wing0's gear list
Canon EOS 350D Canon EF 35-80mm f/4.0-5.6 III Canon EF-S 55-250mm f/4-5.6 IS Canon EF-S 18-55mm f/3.5-5.6 II Samsung Galaxy S4
Canon EOS 350D (EOS Digital Rebel XT / EOS Kiss Digital N)
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,920
Re: Canon 350D question...
Sorry, it is what it is. Later models had somewhat larger screens.
Reading glasses. Cheap ones from Wal-Mart or similar are fine.
The open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
Wing0
OP Wing0 Forum Member • Posts: 63
I was looking into upgrading to either the T5i or T6 because of the limitations of the screen on the XT.
What I forgot to mention is, I already wear prescription glasses.
Oh well, life goes on, will have to make do.
iancrowe Senior Member • Posts: 1,477
Have you tried turning up the LCD brightness (third entry on the first tools menu).
You can purchase screen magnifiers but they're not cheap £30+ and are very bulky.
It might be worth getting your prescription checked and maybe take the camera in to show your optician. Maybe also consider bifocals/varifocals.
Ian
Doug Pardee
Bifocals, then. Or if you don't think you're old enough for bifocals (usually age 40 and up), you might want to have your glasses prescription checked.
Wing0
Funny you should mention that, I just turned 40 last week. Not due for an eye exam for another 4 months (September 2016) at my Optometrist.
At my last exam, my prescription changed ever so slightly when I went last year, so my optometrist told me I did not have to change it, so I didn't to save money.
Wing0
Ian
Not yet, I will have to try that the next time I take my camera out.
I don't want to use screen magnifiers or get new glasses unless I absolutely have to.
kreygscott
kreygscott Senior Member • Posts: 1,285
Being age forty-two myself and someone who still uses a Canon 350D I wear progressive lens for reading and viewing extremely fine prints. This is something you could consider and suggest to your optometrist during your next visit.
Let Your Images Read As Beautiful Melodies.
My Websites
https://www.clickasnap.com/kreygscott
https://kreygscottphotography.smugmug.com
My Blog
http://prakticalphotography.blogspot.com
 kreygscott's gear list:kreygscott's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 17-40mm f/4.0L USM +9 more
pj1974 Regular Member • Posts: 168
I own a 350D (as well as a 400D, 700D and 7D).
Interestingly, I am also in my 40's, and wear prescription glasses  to correct near-sightedness (i.e. I'm short-sighted). I have worn prescription glasses since I was 4 years old.
The 350D's screen is definitely the most unclear for me to see of all my DSLRs. It is 1.8" and only 115k resolution. This affects both menu usage and image review. Even my 400D's screen is notably better (2.5" and 230k resolution).
However there is a big step up with my 7D (3" / 940k) and 700D (3" / 1040k).The screens on these later DSLRs also appears to be able to go brighter (not just higher resolution).
So when I compare my 350D to my 7D or 700D, there is a huge difference in clarity. Having said that, it does not mean I find my 350D to be unusable.  I still use my screen for both image review and menu use. It's just not as clear or easy to see.
It is not possible to check for focus accuracy with the 350D by reviewing the photo in screen (the 400D is also limited, but not quite as limited in this regard). I recall reading that the 350D (and I think 400D also) do not access the full image file, but just a limited thumbnail. In any case, focus accuracy review is truly best on a proper computer monitor. However, at times I can use the 7D and 700D allow me to check, with a reasonable degree of accuracy.
If you find the 350D's screen limiting, and your eyesight is as corrected by prescription glasses as is practical at this stage, I would recommend going to a newer DSLR body with a larger and higher resolution monitor. Wiki has a good summary Canon EOS comparison table, where you can review
https://en.wikipedia.org/wiki/Comparison_of_Canon_EOS_digital_cameras
I hope my input is helpful.  Best regards
Paul
Wing0
Paul
Actually was thinking of upgrading to the T5i, but I would still keep the XT as a backup.
Paul
That is definitely a good upgrade path, with the T5i (700D) having a lot of useful updates as a significantly newer camera in Canon's same DSLR line.
Having both, (i.e. keeping the XT/350D) as a backup is a solid plan.
Paul
