I think I'm going to jump m4/3's ship because of UltraWideAngle
Started May 21, 2016 | Discussions
Davud
Davud Regular Member • Posts: 238
It has been some time that I've been considering a second body+UWA lens combo.
I want it to be light, compact and not so expensive. So, right now I think the best options are:
Olympus E-PM2 + Panasonic 7-14 and Sony a5100 + Sony 10-18
The case for the first option is that I have 2 other bodies and 4 more lenses of the system and it'd be about 100$ cheaper and the case for the second option is that the combo is lighter(569g vs 508g),smaller and all the advantages of a bigger sensor (lower noise, more DR, more resolution,...). For the impartial observer, it is a no brainer.
e-m5 and e-pm2 are identical in IQ.
What are your thoughts? Is it rational to invest in two systems?
 Davud's gear list:Davud's gear list
Olympus PEN E-P5 Olympus E-M5 II Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +2 more
Olympus PEN E-PM2
(unknown member) Regular Member • Posts: 278
Re: I think I'm going to jump m4/3's ship because of UltraWideAngle
6
How about this, weighing in at 366g? That Sony looks pretty big and heavy now.
www.flickr.com/photos/simonallam
Dutch Newchurch
Dutch Newchurch Veteran Member • Posts: 5,716
I wouldn't, because of the cost and the time it would take to familiarise myself with new controls, menus.  Also the hassle of having to charge two sets of batteries, and the extra weight and bulk of having to carry a second body when I want to bring that lens.
It just seems the more complicated solution to the problem.
On the other hand, this may not be the answer you want to hear.
(unknown member) Veteran Member • Posts: 6,192
30
Jumping to Sony for its lenses seems a novel concept.
Soulhand Senior Member • Posts: 1,467
What kind of photos will you be taking with your UWA?
 Soulhand's gear list:Soulhand's gear list
Olympus PEN E-PL5 Olympus E-M1 Olympus E-PL7 Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
(unknown member) Forum Pro • Posts: 19,317
Olympus xz1, e-pL5 , EM5 my toys.
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9.
Glen Barrington
Glen Barrington Forum Pro • Posts: 22,535
Do it . . .
29
It's been my experience that by the time most people get around to making posts like the original post, they've already made that emotional break anyway.  Many people at this point are just looking for validation.
I agree with whoever posted that going to Sony for the Lenses isn't something that happens every day, but needs change.  We can only presume that you are a rational adult with full knowledge of your needs and the options available to you.
 Glen Barrington's gear list:Glen Barrington's gear list
Olympus OM-D E-M10 II Olympus E-M5 III Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +11 more
Ulric Veteran Member • Posts: 4,559
It depends. If you intend to carry only the body and ultra wide zoom and never change the lens, then I don't think there's anything wrong with the plan. But if you plan to use the camera as an ILC, then you'll need to carry two sets of bodies, batteries etc and that will probably end up bulkier than just adding the 7-14.
I certainly think there are cases where it makes sense to invest in a camera body just for a single lens. For example, I often use the GM1 and 45/1.8 as a sort of fixed lens camera, and there is nothing else in that size that can match what that combo does.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
john isaacs Veteran Member • Posts: 8,444
17
You have Nikon and Olympus, and want to buy a Sony crop sensor?  Sounds like a plan to me.
When you decide to go long, I recommend a Canon.
Davud
OP Davud Regular Member • Posts: 238
I was talking about the same focal length. Plus, your suggestion doesn't have any sort of stabilization.
Davud
My Nikon is on the shelf eating dust. It is more like a memorabilia. If canon made a decent mirroless, maybe.
Davud
Architecture, landscape,... . What UWA is for anyway.
Did you consider an Olymous body + hires mode,? (which would also add stabilisation)
photofan1986
photofan1986 Veteran Member • Posts: 3,841
5
Well, you may have a slightly better sensor, but the Sony 10-18 is not exactly a stellar performer. The Panasonic 7-14 is the better lens. So you can compare sharpness of the sensor in the studio with standard prime lenses stopped down, but that won't tell you much about the superiority of any of those combo's.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
Since you have Nikon dSLR, introducing a third (Sony) variant sounds like one too many.  The 7-14mm is a great lens, I have it, and can be bought new for much less than the RRP on eBay.  The GM series is great if you want something really small but again a third variant.  I have the GM1 but in combo with other Pannys. It is a jewel of a camera.
If you want some real fun, add the Samyang 7.5mm.  I think the lack of IS is less of an issue with UWA and has never been an issue for me - see Aurora link below for 7.5mm and 7-14mm images.
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GF7 +13 more
LMNCT Veteran Member • Posts: 4,908
If you are shooting architecture you may want to consider one of the optical shift lenses.  The last time that I looked, Nikon and Canon both had them.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
At the time I replied you were asking for views/advice specifying nothing more detailed than UWA. You didn't describe what you'd be shooting with it so I suggested an alternative based on that. I consider 9mm on MFT an UWA and stabilisation is not generally essential with UWAs so my suggestion was reasonable.  I understand your interests better now. Enjoy your purchase.
fotomotovfr Regular Member • Posts: 470
A VF is a must have for me in those conditions.  You'll need to move up to the Sony 6xxx series for that and the size/weight advantage disappears.
 fotomotovfr's gear list:fotomotovfr's gear list
Olympus Stylus 1s Canon EOS 5D Mark II Canon EOS-1D X Canon EOS R
Bobby J Veteran Member • Posts: 5,191
John, that is hilarious!
BJM
 Bobby J's gear list:Bobby J's gear list
Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 25mm F1.7 ASPH Olympus 12-100mm F4.0 Olympus E-M1 Olympus E-M1 II +9 more
CrisPhoto
CrisPhoto Senior Member • Posts: 1,749
Take the EM10 instead
My thoughts are: Skip the PM2.
If you are on a budget, take the EM10 V1 instead.
Why? The IBIS of PM2 is nearly useless and the EVF ist not stabilized (both bad fore tele usage).
And no EVF.
And the shutter together with the inferior IBIS causes some blur.
With the EM10, you will gain a tilting LCD, an EVF, (half) electronic shutter and you can handhold your UWA shots down to 1/2s which is very useful for blue hour shots...
OM-D + Sam7.5, O25, O60, O75
O12-40, O40-150, P 14-140
 CrisPhoto's gear list:CrisPhoto's gear list
Olympus E-M1 II Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH +9 more
