Samsung NX1100 (or similar) power supply - not charger.
Started May 19, 2016 | Discussions
steenamaroo New Member • Posts: 2
HI guys,
Just signed up here to ask if any of you have a solution for powering the NX1100 or similar from a supply rather than battery?
I noticed the battery hatch has a small hatch on it and figured Samsung must sell a power supply which uses a battery shaped/sized block and a trailing lead, but I can't find anything like that.
Of course I could just make one myself, and probably will, but I just wanted to ask if I was missing the obvious.
Many thanks in advance,
Paul.
Samsung NX1100
Re: Samsung NX1100 (or similar) power supply - not charger.
They never sold it but they did supply it to their sellers (it looks like bp1030 battery with lead coming out). You could probably find a shop that has them unused now.
IIRC someone had a schematic floating around for simulating a battery but I cannot find it now...
OP steenamaroo New Member • Posts: 2
Thanks Otto! That's very helpful.
I've found a picture or two of what you're describing but the only people selling seem to be US or Asia. I'm UK, btw.
If someone has that schematic it would be very helpful. I have a weak used battery which could be cannibalised for this purpose.
If it's a simple thermistor I should be able to use the one in the battery and just wire in a 6/7V power supply to replace the cells.
I'll post back if that's successful.
Thanks again.
kikislater New Member • Posts: 1
Whatch here @24min until 30min :
https://youtu.be/JJVR5AheRqM?t=24m46s
