Are these the same M.Zuiko 14-42 lens?
Started May 16, 2016 | Discussions
Charley123 Senior Member • Posts: 1,166
I ordered this lens from B&H Photo: M.Zuiko Digital ED 14-42mm F3.5-5.6 II R
I receive a lens named: M.Zuiko Digital 14-42mm F3.5-5.6 II R
The lens I received is missing the ED designation, but is otherwise the same name. Both lenses names end with II R.
I'm confused. Are those the same lens?
Helen
Helen Veteran Member • Posts: 7,606
Re: Are these the same M.Zuiko 14-42 lens?
Yes, they are. In fact, the IIR lens (and the optically-identical but cosmetically slightly different II that preceded it) never did have ED in their name. However, many dealers mistakenly added it, as the original 14-42 M.Zuiko, as provided on the E-P1, E-P2 and E-PL1 (though the E-PL1's version had an L sneaked into the name on the top of the barrel, to point out that it had a plastic mount) DID have an ED in the name. This lens was a different physical and optical design.
In case the above makes you wonder, the II and IIR have always been only available with plastic mounts.
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Yes, they are.
No ED element in those lenses, though the EZ model has an ED element. See the lens you bought at http://www.four-thirds.org/en/microft/standard.html#i_014-042mm_f035-056_ii_r_olympus and see the EZ with ED element a few above that lens.
Regards..... Guy
