Super-telephoto comparison?
Started May 16, 2016 | Questions
Ido Scharf
Ido Scharf Veteran Member • Posts: 5,216
Has anyone done some test to compare the Olympus 75-300mm II at 300mm, against the 40-150mm f/2.8 + 1.4x teleconverter at 210mm cropped to match the former?
I currently have a 75-300mm II and I'm looking to replace it with a faster lens. I have the budget for the Olympus 300mm f/4, but I think the 40-150mm f/2.8 can be more useful for me overall. Just when to know what I should expect from the 40-150 + TC, and if I would really lose any reach.
Thanks!
 Ido Scharf's gear list:Ido Scharf's gear list
Olympus 40-150mm F2.8 Pro Panasonic Lumix DC-G9 Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital 25mm F1.8 Panasonic 8-18mm F2.8-4
Skeeterbytes Forum Pro • Posts: 23,182
Re: Super-telephoto comparison?
When you review your shooting data, how much time do you spend at 300 versus shorter focal lengths? The 40-150 looks good with the MC14 from what I see posted here  (I have the lens only ) but as good as it is with the TC the 300 is spectacular and a cropped zoom+TC shot won't be it's equal, so you'll be leaving some image detail behind.
But if you shoot across the zoom range, the flexibility might be welcome over the prime. My "fix" will be to have both, but my budget isn't in order yet.
Rick
Harvey Melvin Richards Regular Member • Posts: 295
I have both lenses and the MC-14. I haven't done any specific tests, but after a day of shooting both on EM-10's, the 75-300 got put in my storage bag. The 40-150 is just much sharper than my 75-300 is.
 Harvey Melvin Richards's gear list:Harvey Melvin Richards's gear list
Olympus OM-D E-M10 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +9 more
Ido Scharf
OP Ido Scharf Veteran Member • Posts: 5,216
I'm not really trying to match the capabilities of the 300mm f/4; more trying to exceed the capabilities of my 75-300mm II without really sacrificing reach. If anyone has some shots that are comparable between the 40-150mm f/2.8 + TC at 210mm, and the 75-300mm II at 300mm, that would be fantastic.
And yeah, I guess the 40-150 is a better choice for me than the 300. While I use the 300mm end a lot when I shoot birds, I also use the shorter focal length on my 75-300 when I use it for landscapes, which I probably do more often.
Thanks!
Thanks!
Ah, I took having the budget for the 300 prime as meaning it was in the mix. I have no qualms the Pro zoom+TC are superior to either 300, and not by a small amount, but am sure several folks here have direct comparos they can supply. I really love the lens and can't wait to add the 300 as a bag-mate. One quality worth mentioning is the amazing focus speed.
Rick
Ido Scharf
Thanks! If you have a couple of samples with the 40-150 + TC against the 75-300, both at the long end of their zoom ranges, I'd really appreciate it if you upload them here. It does look like the 40-150 + TC will be it, though, and the 300 will wait for the next round of spending.
Ido Scharf
It sort of is  but I think I'm getting over that lust and starting to think more rationally now. The 40-150 will be more useful for me.
JeanPierre Martel Veteran Member • Posts: 3,304
You could use Google translation to get a rough translation of the article that I've written in French about the M.Zuiko 40-150mm F/2,8 + M.Zuiko MC-14:
http://jpmartel.quebec/2016/04/12/m-zuiko-40-150-mm-mc-14/ (in French)
Sometimes, that lens hunts to make focus, especially when in the previous shot, the subject was far and in the new short, the subject is near. When it fails to make focus, I'd put the news in manual mode, make focus (roughly) and put back the lens in automatic-focussing mode.
I don't have the M.Zuiko 300mm F/4,0 but from what I've read, teleprime is faster than the combo.
The main reason why I like the combo is its buttery bokeh at its long end...
http://jpmartel.quebec/2016/04/17/trois-papillons-orange/ (skip the French text)
... which is a lot better than its bokeh at its close end:
http://jpmartel.quebec/2016/03/24/coryanthes-macrantha/ (skip its French text).
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
If rationality starts entering the photography hobby, the industry is doomed.
m4/3 has entered the logical next phase, comprising a complete system rather than its former niche as specialty high-quality compact ILCs and move-up cameras. The list of things m4/3 "can't" do is a short one. Only our wallets suffer, now.
Rick
olyham Regular Member • Posts: 210
Thanks!
I have a 70-300 II and a 40-150 2.8 TC1.4, The only thing that I felt I lost from the 70-300 is weight for hiking in the back country, everything else is equal or better and loss of reach has not been an issue. Specifically to your issue I find that I can do better cropping from 210 than from the 70-300. You pretty much need perfect conditions to get good shots at 300 with the 70-300 which can be OK I have a few very good shots but it cannot be relied upon day after day in a variety of conditions to deliver.
If you want to get very good performance at 300 you have to improve a whole range of capabilities as they have done with the 300F4 pro.
Hope that answers your question, you should also consider the extras you get with the 40-150 2.8
Obviously a faster lens
40=70 mm (huge amount of opportunity in this range)
Closer minimum focusing distance (huge amount of opportunity in this range)
Extra function button
MF instant clutch
Better and faster focus
In camera Focus stacking on EM1
Extra weight (generally a negative) on this point I must warn you the 40-150 2.8 is so versatile you will want to use it all the time, it will let you take your general photography up a notch  but the penalty is weight. I am very happy to live with the extra weight and keep my 70-300mm II in the bottom of my bag for when I do long hikes in to the mountains.
If you can manage the extra weight then it is a no brainer.
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
I have both. At f7.1 my 75-300 is tack sharp up to 440mm, and its very light.
The 40-150 + tc1.4 is also very sharp at 420mm when stopped down to f5, but its really heavy. The big bonus is regarding it's wider field of view at 80mm compared to 150mm for the 75-300.
Plus without the tc fitted it is silly sharp even wide open at f2.8.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Ido Scharf
Thanks, will do.
Fortunately, the clutch mechanism where you pull the focus ring towards the camera to engage manual focus, should help a ton with this.
Ido Scharf
Perfect, that's exactly what I was hoping to hear!
I'm not too sure I'll use it this much, but I guess it can allow for less lens-changing to my trusty but soft 12-50.
MF instant clutch
This I hope to make good use of.
Hopefully it will make for a significant improvement in continuous/tracking modes. Not counting on that, as my E-M5 is holding it back somewhat (I'm sure the E-M1 does better), so any improvement at all would be welcomed.
Yes, I think I would be the same. In fact, I've been thinking about buying an L-plate for my camera for a long time now and for some reason haven't got around to it, so I guess the tripod collar can be a nice bonus for me to easily rotate over to vertical orientation with the telephoto.
CrisPhoto
CrisPhoto Senior Member • Posts: 1,749
I support every word Rick and Adrian have written above. You won't loose any reach with the 40-150. Maybe under perfect condition a little bit, but in non-perfect conditions the 40-150 is much better. You will gain many new opportunities like f2.8 or Macro.
Before I bought the 40-150, I struggled with a similar question as you do: 75-300 versus 50-200.
I posted sample images for 75-300 and 50-200. As the 40-150+TC is very similar in IQ to the 50-200+TC, while it is not exactly what you were asking for, it might be allowed to reference the old comparison:
http://www.dpreview.com/forums/thread/3709665
Read it and replace 50-200 with 40-150. You will get a rough impression ...
Christof
OM-D + Sam7.5, O25, O60, O75
O12-40, O40-150, P 14-140
 CrisPhoto's gear list:CrisPhoto's gear list
Olympus E-M1 II Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH +9 more
Yes, absolutely.
No need to go to the menu: we just need to pull the toggle ring, to make focus (roughly), and to push that ring. It takes three seconds.
mike_smith_uk Regular Member • Posts: 390
Re: Panny 100-300 on GX7 vs 40-150 plus 1.4tc on OM M1
I did a quick and dirty test recently whilst sitting on my patio supping a glass of wine. I tried to keep things fairly even so shot at same ISO, both shot at F8 being sweet spot of the Panny Zoom, hand held, electronic shutter on GX7 and 0s time lag on M1 both hand held, processed from raw files on equal basis and cropped to about the same size for 100% pixel peeping comparison. Make your own mind up.
What you pay for in the pro lens is f2.8 aperture isolation ability, solid build, ability to use TCs, faster AF ability and weather proofing, but when shot at similar sweet spot aperture with static subjects the differences in image quality can be fairly small.
Oly 40-150 plus 1.4tc on OM D M1
One of the major advantages of the PRO lens is that you don't have to shoot at f/8.0.
Phocal
Phocal Veteran Member • Posts: 3,528
Thanks!
When I first started my conversion to Olympus I used a Canon FD 400mm ƒ4.5 on my EM5.  This worked pretty well but I decided I wanted AF so I got the 75-300 to use.  It was decent lens for what it was but I thought beyond 250mm it was soft and never used it pass 280mm because of the softness.  After playing with this combo for awhile I had decided I wanted to make a bigger commitment to µ4/3 and bought the EM1 and the 50-200 SWD (as well as the EC-14) to use as my wildlife lens until the 300mm ƒ4.0 Pro was released.  Went this route because there is little difference in IQ between the 50-200 and 40-150 Pro and the extra reach was really nice to have.
If you had an EM1 I would recommend the 50-200 with both the EC-14 and EC-20 if budget is a concern.  Since you are using the EM5 I would get the 40-150 and TC.
 Phocal's gear list:Phocal's gear list
Olympus Zuiko Digital ED 150mm 1:2.0 Olympus M.Zuiko 300mm F4 IS Pro Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake +6 more
Martin.au
Martin.au Forum Pro • Posts: 14,339
Thanks!
How lucky that I was wandering by. That is exactly what I did.
My Review: 40-150, vs 40-150 + TC, vs 75-300.
Here you go.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
Adrian Harris
Thanks!
Here you go.
Great review and after many months of use I fully agree with your findings. Sadly however I really struggle with the weight of the 40-150 f2.8, so if shooting in great light (rare in southwest UK) or if not fast action, I do now use the 75-300 (often with a raynox 2.2x teleconverter on the front), it is slightly soft at 1000mm, but I get amazing shots that I could not get any other way.
The Raynox 2.2x also works well on the front of the oly 40-150 f2.8, but is awful if the tc14 is fitted!
Hope that info helps someone.
