NX-KS Mod pack - installation
Started May 9, 2016 | Polls
OP (unknown member) Contributing Member • Posts: 715
Re: NX-KS Mod pack - installation
BernardoAdam wrote:
I agree 100 % with your theorie. They like to get a lot of money for their overprised smartphones and do not like to have complains. I jumped out of this train 3 years ago, i am very happy with thl, jiaju and kingzone. The only thing the chinese smartphones do not have is good cameras. But therefor we have a nx500. For the moment i see no reason to update to1.41, there is no benefit for me. I still own a 2 year ols t320, Samsung is not updating the android version 4.4.
Do we need for the future 2 versions of the hack, 1 for 1.4 and another for 1.41??
for now it looks like bitrate mods will have to wait a while (if they ever happen again)
I'll hold off a new release for a couple of day to see if vasile manages to figure out the bitrates, and if that happens I'll switch the mod pack to be available only for the latest firmwares, if that does not happen, it will stay for 1.40/1.11 only.
maintaining two separate firmwares will be too much
BernardoAdam
BernardoAdam Regular Member • Posts: 261
Bitrate hack was the most improvement to the cameras. I have no problems to stay with 1.40. I would prefer that now a post focus is more of interst than supporting 1.41. Lets wait and see what are the real improvements in the 2 new firmware, there are enough people who will update and report. Scm improvements are no reason to change, at least for me.
 BernardoAdam's gear list:BernardoAdam's gear list
Canon PowerShot G1 Samsung NX3000 Sony a7 IV Sony a7R V Samsung NX 30mm F2 Pancake +10 more
ARSPR Regular Member • Posts: 385
It really seems to me quite weird, that nobody spends time on a dying system in order to kill community efforts...
Therefore, I'm more inclined to think this is a side effect of any bug-hunting they've done under the hood, (in addition to the official and public BT/SCM enhancement).
And therefore, maybe we, (cof, cof, I should have written "you the wise guys"), should check if the memory leak which caused the crash with the time limit removal while recording has been solved.
A shot in the dark but maybe...
 ARSPR's gear list:ARSPR's gear list
Samsung NX1 Samsung NX 50-200mm F4-5.6 OIS Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
Well, it depends. If you are a videographer, sure. But if you are a photographer, I'm not so sure.
I do prefer my future smartphone to continue being a GPS source for my camera. And I'm probably not going to ever use the enhanced movie bit rates, but maybe I'll use the focus stack/bracketing occasionally (if they are available...)
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Nope. They are simply scared. The mod could potentially brick cameras under warranty -> they could loose money.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
tecnoworld
100% agree. Samsung is now out worst enemy
Re: 2.5K - good to go
What are the bitrates on 1.12 for 2.5k?
BernardoAdam
VASILE: I am no software specialist like you. But I have one question. If you compare the old and new firmware did Samsung change more than necessary parts of the code than for scm and Bluetooth?
vasile Contributing Member • Posts: 575
You are mistaken, BernardoAdam, I am not a software specialist.
But yes, it has passed through my mind to check binary differences - it is in my ToDo list as part of the bitrate mod update.
But thanks for trying to help - always open to ideas.
 vasile's gear list:vasile's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 16mm F2.4 Pancake Samsung NX 85mm F1.4 ED SSA +1 more
depends on where you "mount" it
2.5K when set on DC, with Pro quality - the reported bitrate of a test file is 70Mbps
2.5K set on VGA  - shows total bitrate 7Mbps
(those are the values from 10 sec. test files)
BTW. I try to always keep this up to date: work in progress.
70Mbps is enough for me and I'm not really using DC so it seems I'm good to update. Thanks!
