NX-KS Mod pack - installation
Started May 9, 2016 | Polls
(unknown member) Contributing Member • Posts: 715
I would like to know if you think NX-KS Mod pack - should continue to allow direct install, or it's proper for people to be able to install it only after proving, that they have read a "readme" (which explains who gets credit for what).
Since most of you are the ones who use it, I would like to know if requiring proof that you have read the "readme", before installation, is the proper. I have denied to implement this restriction once already, but the issue has come up again, so I think the community - you, should be the ones who decide.
POLL
Allow direct install.
63.2% 12  votes
Require proof that "readme" was read (before install commences)
36.8% 7  votes
  Show results
headroom
headroom Regular Member • Posts: 484
Re: NX-KS Mod pack - installation
Hi I would like to say thank for your help  w. my problem 3 NX and 1 NX 500. Info "Bluethoot on" was helpfull. But NX 500 is still making troubles - cant enable Bluetooht WLAN is possible...
 headroom's gear list:headroom's gear list
Sony Cyber-shot DSC-RX10 Canon EOS 7D Samsung NX1 Samsung NX500 Canon EF-S 17-55mm f/2.8 IS USM +33 more
OP (unknown member) Contributing Member • Posts: 715
Could you please post a bit more details in the other thread?
Do you mean you can't use Bluetooth and WiFi at the same time?
If that's the problem, try setting up your WiFi on channel 7 or below to avoid interference from Bluetooth. Using a single channel 20MHz (vs 40MHz) will also help to avoid interference.
headroom
I cant post in the other tread error: Maximum Post acheived. I can select WLAN and is  ON Mode. With WLAN Off: Bluetooht select with OK jumps allways to OFF!
BernardoAdam
BernardoAdam Regular Member • Posts: 261
I think only the people with some "computer" background will install the modifications. For me it is not necessary to have a "read first advice". Never the less I liked to have a kind of manual how the mods work and to do a proper installation. Until now I still have some problems with the Focus stack mode, since the manual I use is the video in youtube, which is for NX1 and not for the NX500.
This morning I just thought about Samsungs opinion to your great work? Will they disturb in future your work by offering a new firmware? OK, we are not forced to install a new version.
 BernardoAdam's gear list:BernardoAdam's gear list
Canon PowerShot G1 Samsung NX3000 Sony a7 IV Sony a7R V Samsung NX 30mm F2 Pancake +10 more
here I can't replicate the problem you describe
please make sure you have the latest version installed, and try again
about issues with the functionality of NX-Ks, you can post in this thread:
http://www.dpreview.com/forums/post/57718618
Focus stack and the programs, which make this work (like poker - for memory modifications, gui - which allows us to have interface, to name a few) are crated by Otto.
However since Samsung camera's division (from what I can tell) is history, I seriously doubt that we'll get any firmware updates at all. And even if they did, as this is part of open source project (started by Otto), any commercial use would be violation of the GPL.
It's great that you have found video-instructions useful, but the question here is a bit different:
- "if you want to install, should you be asked for a password, which you can know only if you have read a file which explains - who gets credit for what, has listed their donation links, and so forth"?
headroom
Installation on NX 500 1.52 Version was successfull Cheers...
ArendjeF Junior Member • Posts: 28
It's nice to have a good manual what things do, and how to install the mods which zip files you have to extract. Please no passwords and so on, it is on your risk, the risk is little, because it's simple to uninstall.
ARSPR Regular Member • Posts: 385
Useless confirmation - Please, more detailed read.me
Why do you want to put a question? It's only going to make lazy people tick/answer it without actually reading the Read me file... So it's actually a waste of time and you are not going to get any less repeated "silly" questions (already answered in Read me). This is a known fact in this hard life. You can only fight against it answering only "Please read the readme file" whenever you get a "silly" question.
Nevertheless, having said this and please, please, please, please, do not misunderstand me, I really think you should some more time writing a thoroughly deep readme file. I know you've really done a incredible work, and no praise will be enough, but somehow the readme file is far too basic.
I'm a perfect example here. I haven't followed the developement and ALL the threads about it and I've just installed the mod, (in fact yesterday). So I'm somehow a fully "noob" about the mod itself but I consider myself "not a noob" about photography in general. But I find a lot of info missing in that readme.
Examples:
  • The actual meaning of each of the categories for movie bitrates. (I mean Vasile's table and the match between each mode and NX1 or NX500).
  • What does actually focus pull (EV+Half shutter) do? (¿Memory of your current focus distance in case you use "Refocus on Boot" later?)
  • What do Focus Buttons do? How do I use the 1 to 6 "keys"?
  • How does Focus Stack work? I've pressed Near (to select near distance), then Far and then Stack and nothing happens. (Shouldn't my NX1 start taking pictures as in a bracketing mode?)
  • Why cannot I use 0s as delay in Focus Stack "?" setting button?
  • What's Batch recording (continuous recording)? How can you record without being continuous? (Is it just a No time limit?)
  • What's Swap 256MB?
  • Is No Rec Limit setting the very same one set through the Auto:Down-OK.... "service" hidden menu? Or is it another different thing?
  • What's Kill switch (removes keyscan and gui from memory)? (What's a "keyscan"?) I can swear that this custom feature is REAAAALY scary for a noob...
 ARSPR's gear list:ARSPR's gear list
Samsung NX1 Samsung NX 50-200mm F4-5.6 OIS Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
Re: Useless confirmation - Please, more detailed read.me
The request of having this "pass" implemented has more to do with "making people see who gets credit for what", making them see "donation links" and things like that. Nothing to do with preparing them to use the mod (which is why I rejected this request once before).
Examples:
The table Vasile shows is how the camera separates the different resolution/quality modes, something that I tried to simplify, so you don't really need to know that table, just use the menu. (keep in mind that on NX1 high fps HD uses 4K's bitrate), other than that, it should be self-explanatory.
Goes back to previous focus distance that was used. Focus to subject 1, press EV+Half-shutter, focus on subject 2. Now when you half-press EV+Shutter you will switch back to the other subject in focus.
there are some youtube videos, but that's something Otto developed, so I'm not familiar with it's operations in detail
again something Otto developed, and since I use manual lenses it's not something I'm familiar with
on NX500 recording limit is not removed from 4K / UHD, so it's an easy way to make one video after another
a virtual memory extension
same thing, just no need for service menu
This one removes the programs from memory (so no more key-combination which are watched for by keyscan, no gui), until the next reboot, or they will get restarted in 3 min.
I'll try to make the readme more detailed when I have time : )
cheers
vasile Contributing Member • Posts: 575
The pack should be complete on its own, it should include the information needed for a total uninformed person to get it installed, without needing to refer to other websites, etc.
A comprehensive README included in the pack should suffice.
Passwords/etc. are not needed.
  1. If the person already knows how to install it, it can simply unzip in a sdcard and go.
  2. If the person does not know, they will open the zip and notice the README. They should be able to read it and get from it all info they need to install and hopefully to operate the pack.
rgds
 vasile's gear list:vasile's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 16mm F2.4 Pancake Samsung NX 85mm F1.4 ED SSA +1 more
Hi, some information
  • Focus buttons - Program that displays series of buttons on top of the screen
    • long press (1+s) to save current focus position
    • click to restore saved focus position
    • Can be used for studio shooting, astrophotography (focus on infinity during day, recall the focus during the night), etc.
  • Focus stacking
    • Focus on near point - press "Near"
    • Focus on far point - press "Far"
    • Click "Stack" and wait for it to finish
    • Files are in the usual place - remember to fix exposure/awb/etc as you normally would
So, when you click on Stack the stacking should start.
There needs to be at least some delay as the camera needs some time to complete the commands (focus then take image, etc) - via experiments came down to 1s as minimum.
Mostof the things are in development mode right now and are not as polished as they should be so most documentation is for somewhat knowledgeable people (early adopters of sorts) and is available at https://github.com/ottokiksmaler/nx500_nx1_modding
rgds
So you want a zip, inside the zip with a readme?
(no more proof of read?)
Considering that it's available from github and the readme is next to it, personally I think it's pointless, and overbearing having a zip inside a zip.
Packing it in just one zip and having a readme on the sdcard makes even less sense.
I'll pack it any way the community wants, as it is for them.
(what I use and how I pack it for myself has nothing to do with it,
and as it's available and easy modifiable, anyone else can customize it too)
cheers
rgds
You still assume people that are given a direct link to the zip file will automatically know there is a readme stored next to it on github and that they will know to go there to find out how to install it and what it can do.
Not true. See here for an example. They were given a direct link to the zipfile, and had to ask about it.
rgds
cheers
rgds
this group requires membership, so I can't see it
but as I said, it doesn't matter, as anyone can modify the contents and re-zip it pretty easily, and imho, penalizing people by complicating the installation will make no difference to the links/posts, you are worried about.
rgds
cheers
Jefbak
Jefbak Forum Member • Posts: 55
This feels a lot like the early Magic Lantern Canon hack days... Now that software really made me feel like a noob! Hopefully there will be a wiki for this at some point, nightly builds and all that - but it will take support from the Samsung user base, which the readme enforcement could help with.
First of all: MANY THANKS FOR YOUR REPLY. (In big capital letters).
If that is the reason (you want to put a big "made by xxxx" and "please support us doing yyyy"), of course I've got nothing to say about it.
But nevertheless you could add all this info inside the readme file (in fact the "made by Vasile and ottok" is there, what it's missing is "made by Kino Seed"). More over when ottok is currently saying "if you want to make a donation go to your nearest church, NGO, mosque or just the Red Cross..." (an attitude which highly speaks of him).
Examples:
No it's not self explanatory. As example I could concede that a 4K setting (NX1 pro1, aka 4K Pro) affects 4K and UHD at the same time (as both resolutions are more or less the same). But then that setting is also affecting some Full HD modes which is not obvious at all.
And also the very first time I saw the menu (where there's only 4K and HD listed), before I started digging in the forums, I actually thought "Aren't UHD and FHD resolutions tweakable?"
This is the type of info you have to add to the readme, like the NX1 User Manual contains the NX1 default bitrates...
First of all. I would put a HUGE text saying that this feature is specially useful in MF mode (at least with both S lenses), because the camera can actually move the focus here. (The camera moving a lens in MF mode is not anything intuitive at all... unless explicitly told). Remember that in AF this function is more or less useless as the camera re-focuses again.
(In fact all the focus functions (stack and buttons) actually work in MF which is just great).
Suggestion for improvement in order to use this feature in AF: Is it possible to make EV+Shutter actually take the picture? I mean imagine that in AF, I've made EV+HalfShutter. Yes, the camera has actually moved to a previous focus position, but I cannot do anything more from here. If I go to EV+S it doesn't do anything, if I release EV and go to S it still doesn't do anything and if I release EV+HS and I press HS->S it refocuses...
Nevertheless I still don't understand exactly how this works.
I mean:
  • Power on cycle. Lens in MF.
  • First EV+HalfShutter: Remember focus position 1.
  • Move focus to 2.
  • Second EV+HalfShutter: Move focus to 2.
  • Third EV+HalfShutter: Move focus to 1.
  • Fourth EV+HalfShutter: Move focus to 2.
  • Move focus to 3.
  • Fifth EV+HS: What is going to happen? Do you memorize 3 and move to 1 (in fact, this is what seems to happen)? Do you memorize 3 and move to 2 (this is what I would expect to happen as my previous focus position was 2, not 1)?
So it's just record till limit then start again. I suppose this also works in NX1 if you haven't disabled movie limit.
And???
I mean, we are photographers, no computer geeks. So my question remains unchanged: what does that virtual memory does?
Voilà. So it just "temporally" turns off the Mod. That info should go in the readme.
cheers
Oh, I nearly forgot my last "stupid" question. Can I delete all the "strange" folders that my SD now contains? (I suppose I can't, but this is not EXPLICITLY specified in the readme). And of course, formatting the card is evidently forbidden therefore.
btw, I'm still not clear what you want.
rgds
rgds
cheers
- One zip containing ( readme and a second zip with installation files) ?
- One zip containing mod-installation and included in them a readme, which will get left on the SDcard?
- One zip, a readme and the installation file in a sub-directory, in which the installation files are located?
Examples:
It's not a perfect world. Those high fps are only a case with NX1, and actually can't be separated from the 4K settings. How would you explain it better?
well... it's in Vasile's table, however it sounds like it's just as confusing for people on a first look.
I mean:
  • Move focus to 2.
  • Move focus to 3.
actually only memorizes one : ) so it is flexible
when you press EV+HS, it records the current focus position, and goes back to the previous last, which disappears and the current position which we recorded before the focus-jump becomes "the last" on record, to which will be jumping on next EV+HS
it makes 840sec. files.
it should work with NX1 too
And???
there were some reports that when the rec-limit is removed, there is a crash due to a memory leak (camera gets to be out of memory), this should/may help with this issue, however its not tested/confirmed yet. It was tested for buffer extension and high-bitrates, but it did not improve them
it's like having more RAM but on a disk (it's slow but increases the available amount of memory)
it used to be called "KillKillKill" : )) I can only imagine your reaction then ; )
It does not turn off the mod, as the modified bitrates remain. (it will be confusing and people would think that the regular bitrates will be active on turning off the mod, but  they remain modified)
cheers
All install folders should disappear on install. The folder "presets" holds your custom profiles, and camera settings-backup, which you can make from the menu (which you can store and replace later too if you wish to have backup settings)
The only other folder is the one, in which your pictures are stored ; )
btw, please use this thread for questions about the mod-pack:
cheers
