Almagest
Contributing Member
Re: Focus stacking: E-M1 with Oly 60 macro...Thanks!
gardenersassistant wrote:
Almagest wrote:
Hi Nick,
I started using post focus stacking when I first got my G7 last year, I had to do the stacking manually because the G7 couldn't do the stacking in-camera. The 8mp results are really good IMO and even better now with the G85, as the stacking can be done in-camera.
But the lure of full resolution images using focus bracketing is very enticing, but the manual provided little to no info on how to use it. But I'm slowly getting to hang of it...
G85 Focus Bracketing with 1 Step and 30 shots, stacked using Affinity Photo
I still need more practice, but at least I'm on the right track...
A bit further on than that I think. The knife worked out well.
How fast does it capture the images? One of the issues I found with post-focus was the time (and the unpredictability of the time) it took to capture the images, from 40 or so to over 200, which at 30fps can take seven seconds. That's a long time to be hand-holding, and a long time for a the breeze to hold off and not blow a plant around, and a long time for an insect to not move. I'm hoping that with focus bracketing I can capture perhaps 10 or 20 shots and that this could be done a lot faster than a post-focus capture even though the shots are full resolution.
Your 4K post focus shots are very good, congratulations!
Thanks.
Warren
That's the conundrum, it appears that focus bracketing has many variables associated with it. The number of "steps" 1-10, the number of "images chosen", the focal length of the lens, the lens aperture chosen, the shutter speed chosen, depth of focus required for everything you want to be in focus.
The image of the knives required 30 shots using step #1 @ f/8, I had to use iso 3200 because I was indoors. I have no idea what settings I would have use if I were outdoors and wanted to do a landscape shot with everything from 3 feet to infinity in focus, or say a flower 20 feet away and a focus range of 5 inches.
So yes, I've got a lot experimentation to do before I could say I know what I'm doing.
At this point I do think that any focus bracket shot would require a tripod. That why I'm glad that the G85 has both types of stacking available to the user. Post focus 4K stacking is doable handheld especially with dual IS-2 lenses.
Since the G85 gave me no clue for how to use bracket focus I started here...
http://www.mirrorlessons.com/2015/09/04/using-focus-bracketing-on-the-olympus-om-d-e-m10-ii/
Copied from the above website...
Depending on the number of subjects in the shot, your distance from the subject, how much of the subject you want to capture, and your chosen f-stop, the number of shots and the focus differential required will vary. Knowing which values to choose is really a matter of trial and error, though experimentation and experience will help you make an educated guess. Generally speaking, you’ll need more shots if:
- there are many subjects in your composition at varying distances from the lens
- you are very close to your subject
- you want to cover a wide depth of field
- you are using a fast aperture
And this...
http://extreme-macro.co.uk/focus-stacking/
http://www.duford.com/2016/07/using-focus-bracketing-on-olympus-om-d-cameras/
Good luck...
Warren
