Help can't update my 50-150
Started May 4, 2016 | Discussions
Milondon15 Regular Member • Posts: 224
i have just received my 50-150mm lens and I tried to update the lens only to find Samsung has removed all 50-150 firmwares from their different sites.
i tried downloading the from both matteverglade and herokuapp which only host the files from Samsung.com. I tried the bin file on 4 different SD cards but none have worked. My nx1 is on 100% battery and running on 1.4. Any advice ?
Samsung 50-150mm F2.8 S Samsung NX1
Kinger
Kinger Contributing Member • Posts: 549
Re: Help can't update my 50-150
What happens when you try the update directly through the camera when connected to wifi?
 Kinger's gear list:Kinger's gear list
Canon EOS M5 Canon EOS M200 Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM +3 more
OP Milondon15 Regular Member • Posts: 224
Wifi only lets you update the cameras firmware but not the lens
VisionLight
VisionLight Veteran Member • Posts: 6,227
When you go to the firmware update on the menu, make sure the 50-150 lens is on the camera. It will inform you about any update of the lens, just like any update of the body. I have updated both my 16-50 S and 50-150 S lenses by Wi-Fi while on my NX1 camera.
Visit the Galleries in my website here:
http://edwardmichaellach.zenfolio.com/
Requested by DPR readers, all website images presented by camera used:
http://edwardmichaellach.zenfolio.com/f585961546
Links to the newest images and Galleries can be found here:
http://edwardmichaellach.zenfolio.com/p833842176
My Blog - Tutorials and Opinions on Photography and Camera Reviews:
http://edwardmichaellach.zenfolio.com/blog
My current project is to display 35 Years of 35mm Film Photography:
http://edwardmichaellach.zenfolio.com/f420420058
 VisionLight's gear list:VisionLight's gear list
Samsung NX1 Canon EOS M5 Sony a7R IV Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF 100mm f/2.8 Macro USM +15 more
Kinger
As VisionLight also stated, it will update your lens too. I have done it so I can confirm.
eSteeS New Member • Posts: 10
Hi,
could you solve this problem already or is it still open?
I got my 50-150 mm these days and had the same / similar problem on the NX1.
Update via PC always stopped at 80 % Download.
Same Problem via WiFi.
After copying the .BIN on the SD Card it worked in the end using the Camera Menu Option manually choosing lens update.
Hope you were /  are able to solve it!
Best wishes
eSteeS
