Canon 100-400 L i vs ii
Started May 4, 2016 | Discussions
Jon Tarbuck Forum Member • Posts: 60
Am looking to purchase a telephoto lens for my 5D Mark III, and have narrowed it down from a focal range, size and weight point of view to the two Canon 100-400 L lenses.
I shoot wildlife, some birds, and quite a few of my two and half year old son in generally good lighting conditions.
The first version of this lens is going to disappear at some point, and is obviously a great deal cheaper than the new version right now - but is it false economy to buy the older version if the new one is so much better? I've heard that the autofocus performance of the newer model is a lot better, and that it's a lot sharper across the frame, at all focal lengths and pretty much all apertures...
 Jon Tarbuck's gear list:Jon Tarbuck's gear list
Canon EOS RP Canon RF 70-200mm F2.8L IS USM Canon RF 24-105mm F4.0-7.1 IS STM
Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF 100-400mm F4.5-5.6L IS II Canon EOS 5D Mark III
bigfatron Contributing Member • Posts: 777
Re: Canon 100-400 L i vs ii
You've heard correct. The Mk II is extremely good indeed and if it is within your budget then get it.
 bigfatron's gear list:bigfatron's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 24-105mm f/4L IS USM Canon Extender EF 1.4x III Canon EF 35mm F2 IS USM +3 more
kevindar
kevindar Veteran Member • Posts: 4,625
6
I currently have both versions.
The version 2 is faster in AI servo focusing and has better IS system. at the every so important 400mm and center of the image, the two are very similar. Version 2 does turn in a better overall performance though when comparing the entire zoom range.
If money is not an issue, version 2 is better (though I like the pull push of version 1). if it is an issue, for many years version 1 has produced amazing images for many photographers. this is esp true on the 5d3.
Here is a 100% crop of version 1, on the 70D (high pixel density) wide open at 400mm. My version II is not any better or worse (though may be a bit higher keeper rate if AF is working better),  click for 100% or loup view.
 kevindar's gear list:kevindar's gear list
Canon EF 85mm F1.2L II USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Sony a7R II Sony a6300 +25 more
RS_RS Senior Member • Posts: 1,788
I owned the original version from shortly after its introduction, and replaced it with Version II at the end of 2014, shortly after it was introduced. The original version seems to have been a bit hit-and-miss, certainly in its early years, although reports from users of lenses made later in its production run seem to be more positive. At its best, the original version was pretty good in the centre, rather less so into the corners, and tailed off somewhat towards 400mm. Mine suffered from optical problems that were a bit different after each of many trips to repairers, including Canon at Elstree, but were never really fixed. I have seen no reported optical problems with Version II, and mine is marvellous. In terms of build quality, the difference is like night and day. The original version was prone to failure of the ball-bearing zoom mechanism, and mine failed in that way, requiring an expensive repair. Finally, the original version was never good with Canon Extenders, but Version II works really well with the Extender 1.4× III.
In short, go for Version II – you will not regret it.
OP Jon Tarbuck Forum Member • Posts: 60
I have only used the first version of the lens once on a 6D, and did find the images to be a little soft and the stabiliser not quite as effective as I hoped - but this could just be my imperfect technique.
I do like the push-pull mechanism of the first version, however, and am a bit concerned by how quickly and smoothly the rotary zoom mechanism will work when I need to zoom and autofocus as quickly as possible...
Rock and Rollei Senior Member • Posts: 2,916
Good copies of the original are very good; the new lens is great, though.
Loosen up the zoom ring, and you can use the new one as push/pull if you wish. I don't.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
I guess it will be a bit of a gamble if I went for the first version as to whether I would get a good copy or not - just have to decide if the second version is worth more than twice as much to my photography now...
Spyder531 Regular Member • Posts: 291
The new version (I didn't own the 1st) has an adjustment ring so you can decide if you want the rotating zoom to be smooth and easy or stiff and harder to zoom. What an amazing idea. I use that 2nd version on a 7dmk2 (though on the dmk3 it's great too) and it is amazing.  i miss the 2.8 a little but it's great.
"A camera is a save button for the minds eye." - Roger Kingston
 Spyder531's gear list:Spyder531's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +6 more
gavin
gavin Veteran Member • Posts: 8,242
I just upgraded to mk II. Here are my thoughts
1) Turn zoom is better than push pull.
2) AF is much faster
3) Its thicker so its hard to hold the barrel of the lens to carry it around.
4) PQ is much better.
All in all i am very happy with my upgrade. BTW I saw that its on sale down to $1600 ish recently so go grab one.
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
gavin
mk I has the same tight - smooth ring. Personally I prefer just a zoom lock.
beagle1 Forum Pro • Posts: 11,742
I've been using the original 100-400 for six years, so far I have not found a reason to upgrade
Tarpon6 Contributing Member • Posts: 956
The IS is much better with version II.  I have had both and version II is better in every way.  Not that V I is bad, it is a very capable lens, but V II is the way to go if you can swing it.
A few people have said that the first version doesn't work well with the 1.4x canon teleconverter - will it autofocus? I have a 5d3 so af works down to f8...
gavin
I think mk I is good but mk II is better in many ways. So its not a must upgrade, but a pretty good one. I felt it was worth it after I got mk II and used it for a few weeks.
I have a 5D3 and the MkII & TC combo and autofocus does work on that quite well. You're limited to the centre spot and expansion spots but it definitely works in good light and the IQ is still very decent.
https://www.flickr.com/photos/yod/26748730316/
https://www.flickr.com/photos/yod/22895025554/
I used the original 100~400 with the Extender 1.4× II on the EOS-3 and EOS-1V film bodies and later the 5DIII with upgraded firmware, all providing f/8 PDAF, and with several other Live View capable digital EOS bodies. My copy of the 100~400 certainly did not work well with a known--good copy of that Extender. Whereas the 100~400 II works very well with the Extender 1.4× III.
gavin
Thanks. Good info. I do intend to get 1.4x when I upgrade my 5D II.
I've never used a teleconverter but some use them with the 100-400
maxwebster Contributing Member • Posts: 523
Re: Better minimum focus distance and IS
These two big improvements leave me wanting to trade in my totally awesome 400mm f/5.6 and 100-400 v1 lenses, but they have been magnificent to me fantastic values for the money.
 maxwebster's gear list:maxwebster's gear list
Canon EOS-1D X Mark II Canon EF 500mm f/4.0L IS USM Canon Extender EF 1.4x II Canon EF 16-35mm F4L IS USM Canon 70-200 F2.8L III +9 more
George Spencer Senior Member • Posts: 1,079
Version 1 is a very good lens.  I used it for 12 years.  I did not care for the push/pull way to change focal length but I got used to it.
Version 2 is a better lens IMHO.  You change focal length conventionally with the 100-400II.  The 100-400II focuses as quickly as any Canon lens that I have . . . especially on my 7DII.  The pictures that I get are sharp and the color is good.
You won't go wrong with either lens.  I just gave Version 1 to my son.  He will get some good use out of it.
 George Spencer's gear list:George Spencer's gear list
Canon EOS 50D Canon EOS 6D Canon EOS 7D Mark II Panasonic Lumix DMC-GX8 Canon EF 50mm f/1.2L USM +12 more
