24-70 II focus problem
Started May 3, 2016 | Discussions
ttcyclist Junior Member • Posts: 38
I recently bought a canon 24-70 2.8 II and am not happy with how sharp it is, especially at 24mm with subjects closer than ~12 ft. I’ve tried it on a tripod (mirror lockup with 2 second timer), with and without filter, bright light and low and it doesn’t seem to matter. At 70 it appears sharp, but still not as sharp as my 70-200 2.8 II or 100mm L macro. I would think I just got a bad lens and exchange it (which I plan to try anyway) except that when I had a Tamron 24-70 2.8 it focused poorly in low light, especially at 24mm (which I heard is not uncommon with that lens). I tried micro adjusting both lenses, but it did not show much improvement. Could this be a camera problem as opposed to a lens issue? It looks like it’s missing focus. I’m using a 5D3 and have tried different autofocusing drives and points. As I stated before under the same conditions other (longer) lenses are tack sharp, and my 50mm 1.8 seems to hit focus the vast majority of the time. I forgot to try a zoomed in live view manual focus for sharpness, but will do that and report back.
 ttcyclist's gear list:ttcyclist's gear list
Canon EOS 5D Mark III Canon EF 50mm f/1.2L USM Canon EF 85mm F1.2L II USM Canon EF 135mm F2L USM Canon TS-E 24mm f/3.5L II +1 more
Canon EF 24-70mm F2.8L II USM Canon EOS 5D Mark III
kreygscott
kreygscott Senior Member • Posts: 1,285
Re: 24-70 II focus problem
It would help if you could post a few pictures taken at different focal lengths for us to better diagnose the problem and possibly find a solution.
Let Your Images Read As Beautiful Melodies.
My Blog
http://prakticalphotography.blogspot.com
My Website
https://kreygscottphotography.smugmug.com
 kreygscott's gear list:kreygscott's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 17-40mm f/4.0L USM +9 more
OP ttcyclist Junior Member • Posts: 38
I don't have them with me now, but will post some after work. Thanks.
kreygscott
Okay. Will look out for them.
My Blog
My Website
larry Contributing Member • Posts: 889
My copy is sharp, close-up, with 5D3.  Are you shooting RAW and sharpening in post?
I brought it back to where I got it and the owner thought it might be a bad contact. I exchanged it and the new one is very sharp. Thanks for the replies.
kreygscott
Glad to hear you got it sorted.
My Blog
My Website
