35mm echivalent prime for APSC
Started May 2, 2016 | Questions
Zoltan Ilyes
Zoltan Ilyes Junior Member • Posts: 27
Hi,
I would like to start with an assumption: if you mount a 35mm EF lens (say 35mm f1.4 L) on an APS-C body it will give you the same field of view as a 56 mm (35*1.6) EF-S lens mounted on the same body - because the sensor actually is not using the entire part of the glass, just 1/1.6th of that.
Please correct me if my assumption is incorrect as that makes the entire question void.
But if my assumption is correct, what are my lens possibilities for a (around) 35mm focal length equivalent fast (f1.8) prime for an APS-C body? I've searched through my local vendor's list and actually the single EF-S prime I found is the 24mm f2.8, but that is too slow. Did not had better luck searching the net either as all I could found were EF lenses.
Thanks.
 Zoltan Ilyes's gear list:Zoltan Ilyes's gear list
Nikon D3300 Nikon AF-S DX Nikkor 35mm F1.8G Sigma 17-50mm F2.8 EX DC OS HSM
Kjeld Olesen
Kjeld Olesen Veteran Member • Posts: 4,594
Re: 35mm echivalent prime for APSC
A truely equivalent lens do not exist as far as I know - it would have to be something like a 20 mm f/1.0 or f/1.2.
I think the Sigma 20 mm f/1.4 is as close as you can get: http://www.dpreview.com/products/sigma/lenses/sigma_20_1p4
 Kjeld Olesen's gear list:Kjeld Olesen's gear list
Canon EOS M Canon EOS 6D Canon EOS M5 Canon EOS R6
pilou1253 Regular Member • Posts: 139
Hi,
First, look at my thread history, I did start a similar discussion some months ago.
Then, your asumption is not right, an EF 35 mm and an EF-S 35 mm would give the same field of view if mounted on a crop body. The focal length is independant of the sensor size.
But you are right to say that the FF equivalent FoV of a 35 mm on APS-C is smthg like a 20-22 mm lens.
The only prime corresponding to this is the EF-M 22/2 IS, for EOS M.
My solution: I bought the Sigma 18-35 1.8, a great lens. Check some reviews to make sure you don't miss its drawbacks (AF, no IS, size/weight).
Cheers
 pilou1253's gear list:pilou1253's gear list
Canon EOS 1000D Canon EOS 70D Canon EF 28mm f/1.8 USM Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +7 more
jitteringjr Veteran Member • Posts: 3,608
pilou1253 wrote:
Hi,
Cheers
The 18-35 is the best pick here for crop IMO too.  It lets you zoom to exactly 35mm equivalent and will give equivalent DOF of a 2.8 lens.  The Sigma 20/1.4 would give an equivalent 32/2.2 and the Sigma, Canon or Samyang 24/1.4s would give 38/2.2 equivalent.
 jitteringjr's gear list:jitteringjr's gear list
Canon EOS 7D Canon EF 50mm F1.4 USM Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +9 more
telecomprofi New Member • Posts: 24
sigma 30mm f/1.4 dc hsm  is kind of close and gives very nice results if 15mm of fov are not critical(30*1,6). autofocus accuracy could be better though - but that depends on body/lens combinations as well as distance to the subject. and it is relatively kind of cheap (~250-300 used)
 telecomprofi's gear list:telecomprofi's gear list
Canon PowerShot S5 IS Canon PowerShot SX50 HS Fujifilm X100S Panasonic LX100 Canon EOS 5D Mark III +24 more
Spotted Cow Senior Member • Posts: 1,586
While I agree that Sigma 30mm f1.4 is a nice lens (I had the one before the Global Series Version and it was one of my favorite lenses and I didn't even care for that FL on APS-C sensor which should say something), it is by far from"kind of close to 35mm equivalent FL for FF. 35mm and 50mm on FF sounds close but in reality is a world of a difference. I'm sure someone disagrees. YMMV.
I agree. That's precisely why I bought the 18-35 1.8 to replace my EF 28 1.8, too long (and soft) for my taste.
brightcolours Forum Pro • Posts: 15,885
confusion
6
Zoltan Ilyes wrote:
Hi,
Wrong.
A EF 35mm f1.4 L USM or EF 35mm f2 IS USM lens on APS-C will give the same FOV as a EF-S 35mm lens on APS-C, if such a EF-S lens would exist.
A 56mm EF-S lens on APS-C will give the same FOV as a EF 56mm lens on APS-C also.
However, a 35mm lens on APS-C will give the same FOV as a 56mm lens on full frame.
If you want 35mm on APS-C, the options are:
  • Canon EF 35mm f2
  • Canon EF 35mm f2 IS USM
  • Canon EF 35mm f1.4 L USM
  • Canon EF 35mm f1.4 L USM II
  • Tamron 35mm f1.8 USD VC
  • Sigma 35mm f1.4 Art
  • Sigma 30mm f1.4 EX DC Art (APS-C only)
  • Samyang 35mm f1.4 (manual focus only)
  • Zeiss 35mm f1.4  (manual focus only)
Above your wording, within your confusion about EF and EF-S lenses, states you want 35mm on APS-C. Here, you seem to say you want the FOV 35mm gives on full frame, on your APS-C camera.
If you want the FOV a 35mm lens gives on full frame, for your APS-C camera, these come close:
  • Voigtlander 20mm f3.5 SL II N (manual focus only, too slow)
  • Sigma 20mm f1.8 (old lens)
  • Sigma 20mm f1.4 Art (big, heavy, expensive, very good)
  • Sigma 24mm f1.8 (old lens)
  • Sigma 24mm f1.4 Art
  • Canon EF 20mm f2.8 (too slow)
  • Canon EF-S 24mm f2.8 STM (too slow you say)
  • Canon EF 24mm f2.8 IS USM (too slow)
  • Canon EF 24mm f1.4 L USM
Two zoom lenses to consider;
  • Sigma 18-35mm f1.8 DC (APS-C only)
  • Tokina 14-20mm f2 DX (APS-C only)
Both are very good zoom lenses.
Thanks.
Zoltan Ilyes
OP Zoltan Ilyes Junior Member • Posts: 27
pilou1253 wrote:
Hi,
Thanks for the clarification, now I got it. I've read a few articles about lens equivalency and got confused.
I am aware of that lens but it is out of my budget right now. Bot so to say all the alternatives, but the 28mm f2.8. I'm considering to switch from Nikon to Canon or Sony and researching alternatives to my Nikkor 35 f1.8.
Anyway, it is good to know that there are possibilities, thanks again.
Zoltan Ilyes wrote:
pilou1253 wrote:
Hi,
The Canon EF 35mm f2 (old one with noisy AF) and EF 35mm f2 IS USM  (which superseded it) are fine alternatives to that Nikkor. The Tamron 35mm f1.8 USD VC is also an alternative.
I have used the Canon EF 35mm f2 on my Canon 450D (APS-C) for years, it has nicer bokeh with close ups than the Nikkor, it is about the same size and weight, a bit less barrel distortion and vignetting, a bit lower CA. The coatings are older so it probably veils a bit more shooting into strong light, than the Nikkor.
The new Canon is better than the Nikkor in every way (nicer bokeh especially), and offers image stabilisation as bonus. So does the Tamron.
SarahBK
SarahBK Regular Member • Posts: 184
The 'S' designation is only to let buyers know that these lenses cannot be mounted onto a full frame camera - I believe there is a physical limitation on the mounting part of such lenses. I presume that even if EF-S lenses had no physical incompatibility, they would not be able to cover the full sensor of a full frame camera. The reverse is not true - EF lenses can be mounted to crop sensor cameras. And hence, as others have said, a 35mm EF-S (i.e. crop sensor) lens and 35mm EF lens give exactly the same field of view when mounted on a crop sensor camera (as you rightly said the equivalent of 56mm on a full frame).
I've been using the 24mm f/2.8 STM and I've been happy with it, although indeed at f/2.8 it is still kinda slow. If 35mm were a focal length I was using 90% of the time, rather than buying a wider aperture alternative, I'd probably be seriously considering a full frame camera in order to benefit from one of the nice 35mm lenses around (Canon 35mm f/2 IS, 1.4L etc).
 SarahBK's gear list:SarahBK's gear list
Canon 6D Mark II Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F4L IS USM Canon EF 40mm f/2.8 STM Canon EF 24-70mm F4L IS USM +2 more
Zoltan Ilyes
I marked the first answer as correct just because of time ordering but practically I could mark all the answers.
So thank you all for your feedback, I got the right confirmation that I'm not missing focal lengths switching brands. Right now I think I will get a Sigma 17-50 f2.8 as an all-rounder and get a prime later (50mm is cheap and good, but maybe long, 35mm-s are good but not so cheap).
Dizz Mk II New Member • Posts: 24
Clearly my reply comes too late to do you any good but for those who come across this thread later, as I did, in my opinion if you're thinking of doing something as dramatic as switching brands and eco-systems I'd profit of the opportunity to also change formats. Either be traditional and upgrade to full-frame DSLR or follow all the industry R&D $$ into mirrorless.  Cameras that were considered cutting edge a scant 4 - 6 years ago will be less than half their original price now and will assuredly still take excellent pictures. And there would be money left over to spend on lenses.
