Canon 450D autofocus problems
Started Apr 29, 2016 | Questions
Marc dbr
Marc dbr Regular Member • Posts: 365
I shoot a lot of outdoor portraits with my Canon 450D (Rebel XSi) and Canon 70-200 f4L IS USM and the results are very nice when the focus is right on.
But only 20 to 40% of my shots are tack sharp, most of the time when my subject is not moving. The action shots and kids portraits are generally oof by a little bit.
I am convinced that my techique is good because I never shoot with the 9 focus points on auto, I'm always selecting one of the spots.
I've also read that you could calibrate your lense(s) but it is not available on the 450D. I'm also planning to uprgade to a 5DIII when the 5DIV comes out, but until then (october I guess?) what do you recommend me to do to improve my AF accuracy?
Thanks in advance.
 Marc dbr's gear list:Marc dbr's gear list
Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EOS R5 Canon EF 135mm F2L USM Canon EF 16-35mm F4L IS USM +6 more
Canon EF 70-200mm F4L IS USM Canon EOS 450D (EOS Rebel XSi / EOS Kiss X2) Canon EOS 5D Canon EOS 5D Mark III
Olga Johnson Forum Pro • Posts: 24,360
Re: Canon 450D autofocus problems
With the 450D you have to use the center focus point for focusing on moving targets. That is the only cross style focus point which makes it easier to focus.
Olga
Lemming51
Lemming51 Forum Pro • Posts: 15,278
With moving subjects do you have the AF mode set to AI Servo? Are you allowing it to track your intended subject by holding at half-press for a moment or two before full press to capture? And/or do you have the Drive set to Continuous and capture a burst to give the camera time to "catch up" to your moving subject since it continues to track between shots of a burst?
The 450D does not have MicroFocusAdjustment, but you can have your lenses and/or body calibrated by Canon Service (or other shop) if that's the problem.  But since you get good AF with still subjects I doubt it's lens calibration causing the issue with moving subjects.
Thanks in advance.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Marc dbr
OP Marc dbr Regular Member • Posts: 365
When I shoot portraits where my subject isn't moving I have my focus mode set to "one shot", when I shoot kids portraits and action I have it set to "AI Focus" and when I shoot something like a soccer game I have it on "AI servo".
I think that my 450D needs calibration though because even when I'm in "one shot" single point AF, with still subjects, the eyes of the subject can be slightly out of focus. I have to say that when my subject is not moving, I have the best chance to get a sharp image
Marc dbr
Thanks for the advice Olga, I was not aware that the center one was the only cross type.
I am definitely going to use that single AF point from now on.
WilbaW
WilbaW Forum Pro • Posts: 11,643
You only need One-shot for a few specific purposes (mainly to be able focus then recompose). In all other cases where you can keep an AF point where you want it on the subject, Servo is better. (I know that's not what it says in your camera manual, but the recommendations there are variously vague, simplistic, ambiguous, and misleading. You can do better.) "Nobody" recommends AI Focus.
I wouldn't jump to that conclusion. There are other things that can cause blur that's easy to mistake for a focus problem. Tell us more about your settings (filter? shutter?...), technique (how you're holding and/or supporting the camera, how you frame the shot, how you press the shutter button...), and post an image with full EXIF that shows the problem, and we might be able to spot something.
Check out the unofficial Rebel Talk FAQ.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
PhilPreston3072 Senior Member • Posts: 2,660
AI Servo with Back button focus
I've had great results with AI Servo and Back Button focus on my 450D. I used to always use One Shot focus with half-pressed shutter but there would be quite a few where the focus missed, even for static shots. I was quite surprised to get better results with AI Servo and Back Button focus.
It's really the best of both worlds, and I only use the centre point.
Just keep holding the back button down if you want continuous AI Servo focus.  And you can keep holding it whilst you fire the shutter.
If you want one shot focus, just press the back button for half a second and release.  This works for the Focus-recompose technique.  You can also press the back button several times just to be doubly sure of the focus.
I got good results shooting a soccer match and also my 2 year old daughter who always tries to run away whenever I point the camera at her...GRRRR!
(To set back button focus: Go to Custom Function 10 and select option 1.)
(User Manual Pg158.)
 PhilPreston3072's gear list:PhilPreston3072's gear list
Canon EOS 450D Canon EF-S 18-200mm f/3.5-5.6 IS +1 more
R2D2 Forum Pro • Posts: 26,551
Re: AI Servo with Back button focus
+1 This is exactly how I shoot too.  Extremely versatile.
R2
bludragon Forum Member • Posts: 77
Aside from not getting accurate focus to start, you should also check that the subject is not moving out of focus by the time the picture is taken, and also that you are not suffering from motion blur.
Marc dbr
Thanks for the advice, I'll try it out and we'll see if it works for me
Marc dbr
I'm not using any filter on my lens, and because I always shoot outdoors I keep my ISO around 100-200 and my shutter speed at 1/125 or above. I'm holding the Camera correctly (left hand supporting the lens) with IS turned on. When my subject is not moving I focus, then recompose and shoot. Otherwise I focus and shoot quickly after focus archievement.
so I think I'm not doing anything wrong
junk1 Senior Member • Posts: 1,788
I have the 450d with 60k shots on it.  Why select anything except the center focusing point?  Why let the camera guess as to what you want to be focused?
The camera will often select something in the foreground to focus on since objects which are closer will inherently have more detail/contrast.  Also, the center focusing point has more precision is my recollection.
When the 450d came out, there were lots of posts like yours, and selecting the center focus point is one part of the solution.
If I'm shooting a landscape and want the image to be as sharp as possible, I use live view mode since then there is no worry over calibration of the lens and body, and the potential phase focusing sensor misalignment issue goes away.
If you have enough light, stepping down many lenses to F8 is where they are the sharpest.
I found AI Servo to be useless, with the original 55-250 lens anyhow.  Get more keepers with single shot focus.
One thing is wrong - pretty sure the camera is natively ISO 200 so you are needlessly slowing down your shutter speed..
Camera is not natively ISO 200, or whatever you mean by that.
Olga
My understanding is that many SLRs have the most dynamic range at ISO 200 (because ISO 100 is shot at ISO 200 electronically, but modified to appear to be ISO 100 via software, similar to how ISO 320; etc are created).  I can't recall if that's the case with the Rebel XSi/450d. I see some mentions of it online but not on a major site.
Also, years ago I decided 2x the shutter speed improves the images more than the additional noise, if any, at ISO 200 versus ISO 100.
None of the Canon dSLR's fall into that category.
Olga
One thing to check would be the AF sensors at the bottom of the mirror box.  Make sure they are absolutely clear.
R2
