Can anyone do a comparison of 75-300 ii/ 100-400 / 100-300 ?
Started Apr 28, 2016 | Discussions
Lassoni Contributing Member • Posts: 512
I'm curious because I own a 75-300 ii, and want to know just "how much" better the 100-400 is. Is it worth all the money when I already have "some lens"? I took couple of shots with my 75-300 couple of days ago, and whilst I got some images pretty good, most of them were out of focus due to slow focusing speed.
While I'm at it, how would you rate these two images? Are they good?
 Lassoni's gear list:Lassoni's gear list
Panasonic Lumix DMC-GX8 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 100-400mm F4.0-6.3 ASPH +8 more
Photo Pete Veteran Member • Posts: 5,430
Re: Can anyone do a comparison of 75-300 ii/ 100-400 / 100-300 ?
I can't help you unfortunately... But add me to the list of people who would like to see a proper comparison between the 100-400 and 75-300 for both image quality and focus performance.
Anyone?
Have Fun
Photo Pete
pannumon Veteran Member • Posts: 4,130
It seems that 75-300mm and 100-300 have very similar IQ. That being said, this comparison may be useful. Look the video!
http://www.mirrorlessons.com/2016/03/10/panasonic-100-400mm-vs-100-300mm/
Nice images, but common subjects and nothing jaw dropping. Technically, the images look soft. I have not shot much BIF myself, but I am getting much sharper results on static birds than what you got. Try finer scale sharpening (e.g. on LightRoom: Adjust Sharpening/Radius setting ).
See the video to see what kind of IQ you should expect.
To reduce blur, I don't practically use mechanical shutter anymore. Even for BIF, I would try electronic shutter first (I know, rolling shutter is there). Olympus cameras with first electronic curtain are probably fine.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
LMNCT Veteran Member • Posts: 4,908
All I can tell you is the 100-400 attains focus much faster than the 100-300.  The quality is better overall and of course, the build of the lens is also much better.  Having said that, I will keep the old lens as well as the new one.  Never know when some deserving individual may come along.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
Well, I would say that both pics are too soft and show chromatic aberrations. So in terms of technical value, a 4/10. Now is this due in part to dpreview compression? Probably but not mostly. I would surmise that using a PL 100-400 "pro-level" lens capable of dual IS would be a great advantage to the non-stabilized lens but also a great disadvantage to your pocketbook...
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
JLTaylor Senior Member • Posts: 1,189
Re: comparison of 75-300 ii/ 100-400 / 300 F2.8
I put what I thought would be full size photos of from three lenses (fully open and F8) in this gallery:
http://www.dpreview.com/galleries/6528805548/albums/300s#page=1
Electronic Shutter with 4 second anti-shock. Distance is about 8 meters.
Not sure how dpreview galleries work, but I couldn't expand them to full resolution.
Full size
Crops from lower center (brush strokes stand out):
75-300 F8
100-400 F8
And the four thirds 300mm F2.8 wide open
(hope I got those right, can't see the titles when adding photos).
On a tripod with anti-shock the larger, more expensive the lens the more detail. Real world when handheld, with AF issues, and atmospheric distortion... ...better to get closer to the subject.
(unknown member) Contributing Member • Posts: 578
The 4/3rds f2.8 is quite some in front isn't it. I thought the 100-400 Panasonic might have been a bit closer than that. Now if you only had the Olympus 300 f4 as well.
abe4652 Veteran Member • Posts: 3,147
But why at f8?
abe4652 wrote:
But why at f8?
Shot all three lenses wide open and at the same f stop. The 75-300 was slightly better slightly stopped down.  When wide open is 6.7, F8 isn't a very big step.
I would have been disappointed if the 300 wasn't noticeably better, but so far I'm very satisfied with the Panasonic. If you aren't at 100% the gap narrows pretty quickly. The 75-300 looks like it is way behind, but get more keepers from it then the 300.  Portability matters.
Olympus had a really impressive lineup right out of the gate. The 300, 50mm F2, 50-200, 14-54, then followed it up with the 150 F2.0.
OP Lassoni Contributing Member • Posts: 512
Thanks for criticism. The gulls I posted here I tried to do sharpening / noise reduction, but looking at the raw with zero NR/sharpening the gulls are pretty soft. I wonder if I need to get it sharp "in-camera" for a picture to be good, and only after then enhance it?
The 75-300 / 100-400 / 300 posted here also shows quite a difference between the lenses. 75-300 doesn't seem very good at 300mm, so maybe I should limit myself to using it @ shorter fl if possible (where it's sharper)?
I actually the images may have been fine, but the noise reduction/sharpening may be the problem. Sharpening with "large brush" (radius in Lightroom) actually destroys fine detail. The sharpening artifacts around the birds suggest this. So, you need to decide if you want the image to look as sharp as possible on screen (typically 1-2Mpix) or maximize the fine detail sharpness (16MPix). It is only possible to add limited amount of sharpness. The point 6 in my list below is crucial. At this point, the selected radius/"brush size" largely depends on how sharp the image was in the first place.
I am no expert, but my noise reduction procedure in Lightroom is as follows,
  1. Rough adjustment with exposure parameters
  2. check enable "remove chromatic aberration"
  3. Put view to 1:1 or 1:2, and select a critical location for Detailed zoom.
  4. Put NR, Sharpening parameters to 0
  5. Set Sharpening/Amount to max
  6. Adjust 'radius' depending how sharp the image is. The sharper the image, the sharper the result will look at low 'radius'. I do not worry about the noise at this point.
  7. Fine tune the Sharpening/Detail parameter
  8. Reduce Sharpening/Amount according to taste. The smaller the radius, the more NR can be applied.
  9. Change the masking parameter according to taste
  10. Select Noise reduction/color, increase it so that all the color noise is eliminated
  11. Carefully apply luminance noise reduction. Keep it as low as possible!
  12. Re-adjust some of the parameters.
The 75-300 really does deteriorate by 300. Try a comparison shooting them all at 270. I think you'll find less of a difference then.
Len_Gee
Len_Gee Veteran Member • Posts: 9,880
I'm not a bird person.  What kind of birds are those?
FWIW,  I've been thinking about buying a used 100-300 to take on an Alaska land tour ocean cruise holiday.    Offered at $250 USD.
Good luck on your lens decision.   Report back your choice.
Lena
Like others here, I suffer from chronic GAS.
Gear Acquisition Syndrome.
a few hundred nautical miles SW : 17º 52S, 149º 56W
 Len_Gee's gear list:Len_Gee's gear list
Olympus PEN-F Olympus OM-D E-M10 IV Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital 17mm F1.8 +4 more
