Advice using Olympus 40-150mm f2.8 with Panasonic G7
Started Apr 28, 2016 | Discussions
Neil426 Forum Member • Posts: 75
Hi all,
I currently use the Olympus 75mm f1.8 prime with my G7 and I am very pleased with the results. I am however looking at adding the Olympus 40-150mm f2.8 for shooting sports action including Cricket , Football and Athletics in good outdoor light for the most part.
So I am wondering if anyone has purchased the 40-150 f2.8 and uses it successfully with the G7, G6 or G5 and has found that it is useable at 150mm without any in body stabilisation?
The natural step would be to probably add the GX8 or GX80 over the coming months but I cannot afford to purchase both the lens and a new body currently.
Would perhaps a monopod offer a solution in the short term and help deal with camera shake?
Thanks for advice
pannumon Veteran Member • Posts: 4,130
Re: Advice using Olympus 40-150mm f2.8 with Panasonic G7
Neil426 wrote:
Hi all,
Thanks for advice
I have G7 and lenses that go up to 150mm and beyond (and to 140mm).
Which shutter speeds you plan to use? If you are planning to freeze the motion and shoot at something like 1/500s, you don't need IS the get sharp images. The bigger problem is that the LCD/EVF display will not be stabilized while. It should not be a great deal at 150mm.
Actually I find Olympus style stabilization too efficient for action shooting. Too much stabilization makes the image lag behind when you pan the camera. No such problems with OIS. BTW, I have never heard this argument before, so maybe it's just me?
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
Skeeterbytes Forum Pro • Posts: 23,182
Use mine occasionally on the GM5 with no issues, so long as I mind the shutter speeds. It's one of my two soccer lenses and the high shutter speeds needed render IBIS moot (l use the E-M1).
Keep it over 1/1000 and you should be fine with any camera. It's completely usable at f:2.8, which helps.
Rick
Cipher010 Contributing Member • Posts: 727
I expect at long telephoto range, IBIS is very useful. I believe G7 has no IBIS.
 Cipher010's gear list:Cipher010's gear list
Olympus E-M1 Sony a7R II
Not really with field sports. The needed speeds to freeze action render IS moot. For more artistic pursuits such as panning and international blurring, it's invaluable and I'm happy to have it.
Rick
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
the cheaper oly 40-150 works well with panasonic g7 for sports, so you should do well with the better lens.
i don't know if you have to do anything different with that lens.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
horsth Senior Member • Posts: 1,638
Re: Examples using Olympus 40-150mm f2.8 with Panasonic GH4
Sometimes I shoot with my GH4 paired with 40-150 pro plus MC-14. Shutterspeed is important due to the missing stabilization. On the other hand, shooting BIF for instance needs no stabi at all, only speed.
here is my flickr test album that I built, when i got the GH4 (bad weather conditions):
https://www.flickr.com/gp/97351775@N02/XpzgvC
all CAF and medium burst!
 horsth's gear list:horsth's gear list
Fujifilm X20 Olympus E-M1 II Olympus OM-D E-M1X Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +9 more
OP Neil426 Forum Member • Posts: 75
ref Examples using Olympus 40-150mm f2.8 with Panasonic GH4
Thanks Horsth very reassuring that you have captured such sharp images without IS... i will probably add the GX80 later on this year to have the best of both worlds but at fast shutter speeds the results you have posted speak for themselves..
Just out of interest do you feel the MC-14 is essential as from testing my rather older 45-200mm the difference between 150mm and 200mm is actually not as much as I was expecting and therefore I suspect given how sharp the lens tends to perform I would simply crop into the image taken at 150mm to achieve the 200mm fov if it was needed...
If anyone has any comparisons of 150mm v 200mm FOV or 210mm as it will be for this lens I would appreciate it..
Many thanks for the other replies all of which have been very helpful..
Re: ref Examples using Olympus 40-150mm f2.8 with Panasonic GH4
I sold the 45-200 when I got the 40-150 pro. The MC-14 is very good (sharp), gives you more reach and focuses fast. You can get it in a bundle together with the lens a little sheaper.
By the way, I think, that 1/2000 sec is perfectly sufficient in order to compensate for the missing IS. I just wanted to be on the safe side.
Hi Horsth,
One quick question how do you find the AF on the GH4 when using this lens?
Any particular settings that you would recommend? do you use the subject tracking? I know much is made of the DFD system that Panasonic offers with its own lenses but wondered how the Olympus lens performs as you seem to have a good hit rate?
Yes, made me wondering as well. DFD is not activ with Oly lenses. But I just kept the single focus frame on the target and fired away and it worked. My assumption is, that the 4k power of the GH4 (two processors) together with this fast lens is completly enough for fast focus acomplishment, even without DfD. The same should be valid for the G7. I didn' t use tracking, just CAF. CAF+tracking doesn't function fast enough.
Rick
Yes, if the shutter speed is very high. However, IBIS is an invaluable feature for me in many situations.
Kensah New Member • Posts: 1
http://panasonic.jp/dc/g_series/g7/high_speed.html
No one notices but Panasonic JP web site clearly says that DFD works with other company's lenses. It says by using part of the DFD function so I assume it is not 100% works just partially.
This happened with newer cameras like G7 and GX8.
I had E-M1 and G7. I bought 40-150 pro last year because this made me wanted to know which is better AF with the lens.
After extensive use of both cameras for BIF (mostly swallows), in most cases, G7 was a lot faster and less frustrating than E-M1
On the other hand, I felt E-M1 is better (accurate) for closer and bigger moving targets like dogs, cars etc.
BTW, I am Japanese so English might be weird
