Hobart waterfront, panorama, NX200 etc
Started Apr 24, 2016 | Discussions
bourdieu_boy Regular Member • Posts: 150
5
Here's a photo on my old NX200. Sometimes I take it out with the 30mm and use it like a large-sensor fixed lens compact.
I always forget the panorama mode, and I guess it can be a bit gimmicky, but it worked well here.
Samsung NX 30mm F2 Pancake Samsung NX200
CraigVMN Contributing Member • Posts: 808
Re: Hobart waterfront, panorama, NX200 etc
That's a nice shot, you should consider some HDR effects
 CraigVMN's gear list:CraigVMN's gear list
Nikon D5600 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR
bancika
bancika Regular Member • Posts: 421
I used to use built-in panorama mode, but since learning to stitch my own panoramas I would never use it again , for several reasons:
* you're limited to great light conditions as you're moving the camera all the time. Long exposure is out of question. If you take individual shots and stitch them later, you can take as long exposure as you wish (on a tripod).
* it only does horizontal or vertical line panoramas. I often like to take 9 (3x3) or 12 (4x3) shots, so I can get a 4x3 or 16x9 shot after stitching.
* it outputs low-res jpeg, with individual photos you can get raw and better resolution
* you can use different projections when stitching photos, some work better than others in a given situations
 bancika's gear list:bancika's gear list
Samsung NX300 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 12-24mm F4-5.6 ED Samsung NX 45mm F1.8 2D/3D +4 more
OP bourdieu_boy Regular Member • Posts: 150
Yes, the panorama mode is limited, but it does enough for me. I don't have the time for all that stitching and editing.
