Older wide/superwide options for 5dmk2?
Started Apr 22, 2016 | Discussions
fellig1 Forum Member • Posts: 52
I recently picked up a used and abused 5dmk2 and some random cheap lenses but have quickly seen how the sensor is out resolving the cheaper lenses. I love the 85mm f1.8 but the tokina 19-35mm "plastic fantastic" doesn't seem so on this camera. Lots of fringing and doesn't seem sharp. After some tweaking, the old 70-210 f3.5-4.5 is great, which got me thinking about the older EF 24-85mm zoom, or the EF 24mm f2.8 as a wide option. I do some landscape and architectural shots and would love to stay wider than that, but not at the expense of sharpness. Any suggestions for someone not able to afford an L lens?
Canon EF-S 24mm F2.8 STM Canon EOS 5D Nikon DL24-85 Tamron SP 85mm F1.8 Di VC USD
diness Veteran Member • Posts: 3,758
Re: Older wide/superwide options for 5dmk2?
You could try the 20-35mm usm. I wouldn't expect awesomeness but I've heard it's decent and it's very heap
 diness's gear list:diness's gear list
Canon EOS R Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
OP fellig1 Forum Member • Posts: 52
Thanks - that one is on the radar... Seems to get mixed reviews but I'm just looking for a step up from the tokina.
Have you thought of the samyang Rokinon 14mm?
Tapeman Contributing Member • Posts: 672
I used to own the Canon 20-35mm (not the f2.8) when I was still shooting film and thought is was a very good lens.
waltsfotographics Forum Member • Posts: 51
Hi
Non l lenses for a 21 mp full frame...tricky
Canon 20 2.8: good for landscape, architecture stopped down
Sigma 15-30: distortion, flare, but sharp (as L) stopped down
Adorama has one right now in v condition for 179. With a 14 day return policy, I recommend the Sigma.
Oh yeah, everyone should have the 50 1.8 stm
Read the reviews for these lenses.
"The right tool for the job, Beavis"
I have looked at them... Probably the top of my price range and I have a feeling I would find a way to scratch that front glass!
Macro guy
Macro guy Veteran Member • Posts: 6,069
Tamron 20-40mm f2.7-3.5 is just fantastic!  It's very sharp, hardly any distortion and no fringing.  I love that lens.  Another one that I adored was the Tokina ATX 17mm f3.5.  It's a bit soft wide open, but stopped down to about f5.6-f8 and it sings.  Make sure to have a hood on because it's prone to flare.
Canon 24mm f2.8 is very good as well, it's a good choice, although the Tamron 20-40 can be had for the same price.
 Macro guy's gear list:Macro guy's gear list
Canon EOS 5D Mark II Canon EF 50mm F1.8 II Canon EF 70-200mm F4L IS USM +4 more
That tamron looks interesting... Thanks! Seems like it can be had for a good price as well.
Macro guy
Yeah, it seems to be one of the best kept secrets.  A buddy of mine recommended it to me and I bought it just based on his recommendation (he never recommends a bad lens) and it's one of the best purchases I had ever made.
hotdog321
hotdog321 Forum Pro • Posts: 21,141
It would be great if you could find a used 17-40 or 16-35 f/2.8. A lot of people sold theirs to get the newer 16-35 f/4L IS. These would be perfect for landscape work.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
Thanks to everyone for the advice... After a lot more reading and looking at sample images, I decided to give the tamron 20-40 a shot... Will see how it compares to the tokina once it arrives!
Macro guy
Good luck!  Let us know how it goes.
Thanks for the info and advice! I finally got the Tamron 20-40 out and tested it... and here's my take...
Build: The Tamron is a bit larger, heavier and uses more metal - it feels sturdy and looks quite a bit better in person. The Tokina is much lighter and is just about all plastic, but still has pretty good build quality.
Focusing: I will say the Tamron is LOUD, but I got used to it after a few shots. The Tokina is quieter (though still somewhat loud), and seems to hunt a little bit less than the Tamron. I'd probably give a slight edge to the Tokina.
Image Quality: Here's where it gets interesting. I set up a tripod and took similar images with each - the Tamron at 20mm f11 and the Tokina at 19mm and f11 (I know the purists will complain, but since I'd use each of them at their widest it didn't seem very practical to keep them both at 20mm). The first thing that jumped out was the color rendition. The Tamron gives deep, saturated colors that are very accurate.  The Tokina is a little washed out - not as saturated and blows out more highlights.
When I first looked at sharpness (at 19mm and 20mm), I was surprised by the Tokina. Comparing the two, image centers are almost equally sharp, with maybe a slight edge to the Tamron (I actually favored the Tokina in one shot). Move away from center and you see the differences more clearly. The Tamron is surprisingly sharp out towards the edges, where the Tokina starts falling off quickly once you move away from center. Where the Tokina turns foliage into a smear in the corners, the Tamron holds strong and provides good definition. Not sure how to explain it, but the Tamron also has a very pleasant way of rendering edges compared to the Tokina... my guess would be that it can resolve more detail due to better quality glass/coatings. In terms of C.A., however, the Tamron may actually be a little worse. Purples and greens are abundant in the corners of each, with a little more in the Tamron samples.
I also noticed a difference in distortion between the two. The Tamron shows some barrel distortion at 20mm, but it's very "normal" looking and easy to correct. The Tokina shows some as well, but also adds some odd mustache distortion to horizontals - not a big deal for landscapes but architectural shots are a little tougher to correct.
Just for fun, and since I had it in my shirt pocket, I also tested the Tamron zoomed to 40mm against my ef 40mm f2.8 (at f8) and was surprised that the Tamron held its own in terms of sharpness and clarity. I'd still give the pancake the edge, but it's not as different as you'd think.
Overall, I think the Tamron will stay in the bag and I'll part with the Tokina. It was well worth the price I paid for it, and fun to use, but it's time to upgrade. I can live with noisy AF in exchange for better image quality. I wish I had the canon 20-35 to compare it to - but I have used the Sigma 10-20 on APS-C and an Olympus 9-18 for M43, and the Tamron compares favorably, I think.
Macro guy
I'm glad you liked the Tamron.  It's a nice lens, especially considering for the kind of money you can get it.   It's one of the best bangs for the buck I ever bought.
