Thanks, you're right. I have a Batis 85mm as my only E-Mount lens; I tested it and the PDAF boxes do not light up. The Sigma 50mm seems to focus more slowly than my adapted 24-70mm so I assumed it was contrast-detect, but it could be the much larger aperture and lens design slowing it down. It is definitely a usable speed, however, and I was testing in low light levels (maybe ISO 1000, 1/60, f/1.4).I would not expect the phase detection points to light up. If you have a native lens and you put it in AF-S mode Small, Medium, or Large it will not show you the PDAF points. Just the larger bracket bars. So in my opinion its active like a true native lens Sony or Zeiss native lens with AF. You can confirm this by switch between between these three variable spot modes for AF-S and if just the outer braces light up its emulating a native lens exactly.I just received my adapter (had pre-ordered) and performed a quick test on the Sony A7R II.In terms of build, I like the quality of construction and the switch to unlock the lens from the adapter is larger and much easier to use than that of the Metabones IV.
One disclaimer: it is entirely possible that firmware updates could improve the results I experienced:
- Sigma 50mm Art: It seems to be using contrast-detect AF rather than phase-detect as the small phase-detect AF boxes within the medium-sized AF square do not light up when focusing this lens. They DO light up with my other Canon EF lenses using the same adapter. However, I tested Eye-AF and it works. I am guessing this could be fixed in an update.
- Canon EF 24-70mm f/4L IS: Phase detect AF works. However, Eye-AF does not. This was not promised in the literature, but I was nonetheless disappointed. I had the impression it would focus Canon EF lenses using Eye-AF from watching DPReview's video (http://www.dpreview.com/news/854738...-lenses-full-range-of-af-modes-on-sony-bodies). I watched it again, and while Rishi doesn't explicitly say that it will focus Canon EF using Eye-AF, there are a number of general statements about the adapter focusing DSLR lenses using all Sony focusing modes that made me think it could.
- Canon EF 100mm f/2.8 (non-IS): Focuses using phase detect AF, but I can only open the aperture to f/3.5, or at least that is what shows on the camera. Eye-AF does not work.
Overall, if you own a Metabones, it seems like the only reason to buy this (currently) is if you really want to use Eye-AF with Sigma Art Lenses. It could also be a good choice if you don't own any adapter as it is cheaper than the Metabones and performance is currently decent. However, I'm not sure how committed Sigma is to improving the AF performance of Canon EF lenses. For me, since I already have a Metabones, it is hard to justify $250 just to Eye-AF my Sigma 50mm Art, even though the results would be great.
- Canon EF 35mm f/1.4L: Focuses using phase-detect AF. Eye-AF does not work.
