XF 60mm f/2.4 vs. XF 56mm f/1.2
Started Apr 21, 2016 | Questions
Allen Y. Junior Member • Posts: 27
Okay all, I need a little help on a decision regarding a portrait lens.  For a little background, I am a decidedly amateur photographer who has really gotten more into better glass in the last 18 months.  After picking up an X-T10 back in the fall with the 18-55 kit lens, I'm ready to start investing in some additional lenses.
So, given my level of experience, do you expect I will get any substantial benefit from purchasing the 56mm f/1.2 over the 60mm f/2.4?  I expect I will use either primarily for portraits of family and friends, and from looking around a photos of the style I like, it seems as though the f/2.4 will give me shallow enough DOF for my purposes.  Though it's not my primary interest, I'm also intrigued by the semi-macro ability of the 60mm.
As you can tell, I'm leaning toward the 60 given it's much lower purchase price (and weight).  But a little personal experience from someone in the know would be helpful.  Thanks in advance.
 Allen Y.'s gear list:Allen Y.'s gear list
Fujifilm X-T10 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 50-230mm II +1 more
Fujifilm XF 56mm F1.2 R APD Fujifilm XF 60mm F2.4 R Macro Fujifilm X-T10
d750guy Senior Member • Posts: 1,001
Re: XF 60mm f/2.4 vs. XF 56mm f/1.2
Get the 56mm 1.2     The 60mm isn't much difference than your 18-55mm at 55mm.
Vic Chapman Forum Pro • Posts: 10,694
5
I think you've probably done your homework and said it all.
The 60mm f2.4 is way cheaper, lighter, more compact (swap the big hood for the 35mm one or third party), serves dual purpose and its max aperture is ideal for portraits unless you often want the one eye sharp look (which becomes tiresome). It now focuses as fast as the 56mm f1.2. The 60mm also has an aperture controlled by 9 rounded blades which ensures a pleasant bokeh with highlights of soft edged circles - in fact I rate it second only to my 90mm f2. Obviously the background is not quite as oof as an f1.2 will get you but as I wrote earlier, that wide aperture is of more use for 3/4 to full length images which are effective but which require more space.
The 56mm f1.2 is a fine lens and I'd not refuse one as a gift (after all, you don't have to use it at widest) but for all the reasons above I will not swapping.
Consider buying used.
BTW, it is also great for street and for picking out architectural and other detail.
60mm @ f2.4
60mm @ f2.4
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
bowportes Veteran Member • Posts: 4,337
As a portrait lens, there's no competition. You get the full-frame depth-of-field equivalence of an 85mm F1.8 lens with the 56mm while you get the DOF of a 90mm F3.6 lens with the 60mm. That's quite a difference in subject isolation and background blur, quite a difference. So for portraits, the 56mm lens complements the zoom you already own much better than the 60mm does. The 56mm also has potential for event shooting.
For close-up, semi-macro shooting, however, the 60mm complements your zoom much better than the 56mm does. So you need to decide which -- portrait or macro -- is your top priority.
I own both lenses but also own the 16-55mm zoom, which gives me F2.8 at 55mm -- fairly similar to the 60mm's F2.4. So I rarely use the 60mm anymore unless I'm doing close-up work -- flowers, copying photos, etc. If I'm doing head and shoulders or even half-torso shots, I carry the 56mm to supplement my F2.8 zoom. Sometimes I shoot it at F1.2 -- especially if the subject is farther away -- but more typically I shoot at F1.8 or 2.0 if the subject is closer.
Hope this is helpful. If I owned neither of them, I'd buy the 56mm. I've thought about selling the 60mm but keep it around for close-up shots. You might also consider the 90mm if a lot of your shooting is outdoors.
This website will do simulations of the depth of field for different lenses and apertures. You might find it useful.
 bowportes's gear list:bowportes's gear list
Panasonic Lumix DMC-G5 Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-Pro3 Fujifilm GFX 50S II +15 more
shotguns Contributing Member • Posts: 920
I know 56 can hunt and peck on focus but I didn't know the 60 was as fast now on new FW. If so, very nice. But for slow (former?) focus I know many love the 60.
 shotguns's gear list:shotguns's gear list
Sony a9 II Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
OP Allen Y. Junior Member • Posts: 27
Thank you for the responses.  Good points on both lenses, and they're quite helpful.
I think I'm gonna go with the 60mm at this time.  If I get serious with the portrait photos and feel the 60 doesn't quite do what I want, I can upgrade in a couple of years when the 56 is likely to be a bit cheaper than it is now.
dengx Senior Member • Posts: 1,032
Most likely you will be satisfied (or dissatisfied) with both.
Both are on the slow side when it comes to focusing and both are capable of producing great shots.
If you do not need f/1.2 then go with 60mm as it's much cheaper, smaller and sharp from f/2.4.
It also renders a little warmer images than 56 (nothing you cannot change in post though).
I went with 60 this time because it suits me better for the kind of portraits I use it for.
Also consider either new or old 35 - these are fantastic lenses more suited for everyday casual shooting than 56/60 that you might find not using that much. For the price of 56 you can almost have both 60 and 35 anyway.
My last advice is to wait for the discounts from Fuji (they often discount their bodies and lenses - few times a year) if you are planning to buy a new one (though there are plenty of them used in mint condition).
Best regards
 dengx's gear list:dengx's gear list
Fujifilm FinePix X100 Fujifilm FinePix S5 Pro Fujifilm X-Pro1 Fujifilm X-H1 Sony a7R IV +8 more
Thanks for the feedback.  This was my thought as well.  I'm planning on picking up the 35 f/2.
slimandy Forum Pro • Posts: 17,161
Having tried both I kept the 60. I like the macro capability, it is smaller and the image quality is on a par. The fact that it was so much cheaper was a bonus.
The obvious advantage of the 56 is the very wide aperture. Given that I'm likely to stop it down a little for portrait anyway I don't really miss it, but it would offer better subject isolation if you really need that bit extra, and it is better in low light (though with shallow DoF of course).
I'm happy with the 60.
 slimandy's gear list:slimandy's gear list
Sony RX100 II Nikon D200 Nikon D700 Fujifilm X-E1 Fujifilm X-T1
7
It's a much better lens than the zoom in many respects. Better IQ (sharper, nicer bokeh), over a stop faster and of course much better for close-up.
photodan1
photodan1 Contributing Member • Posts: 974
It sounds like you have decided and I would agree with your choice. At one time I had both and though the 56 was an absolutely gorgeous lens, it doesn't focus close or any faster than the 60 and I found the bokeh from the 60 was better in my opinion (only my opinion). I swapped even the 56 for a 16-55 and feel like I got a bargain. I use the 60 primarily for closeups and the zoom most of the time for the few portraits I shoot.
www.dankaneimages.com
 photodan1's gear list:photodan1's gear list
Nikon Z6 II Nikon Z 24-70mm F4 Nikon Z 50mm F1.8
KKJohn
KKJohn Senior Member • Posts: 1,138
I have the 60 and 35/1.4 and very happy with this combo. I did try the 56 in a store but found it too big and heavy, as well as expensive. The 35 is my walk around lens and I also use it for casual portraits in low light. The 60 I use for close ups of flowers etc and also for daytime portraits.  The 60 tends to hunt for focus in low light, so the 35 is always ready for these situations as I do a lot of street and night photography. I also have the 50-230 for trips to zoos and parks, which I really like and find it has excellent IQ for a plastic lens, and is so light and good for daytime shooting. Here are a few portrait shots with the 60.
 KKJohn's gear list:KKJohn's gear list
Fujifilm X70 Fujifilm X-A1 Fujifilm X-T10 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +2 more
Les Lammers
Les Lammers Veteran Member • Posts: 4,247
The 60 would work well. So would the excellent manual focus Pentax M 50mm f1.7 that you could get for $50-75. You'd need an adapter about $10-15.
 Les Lammers's gear list:Les Lammers's gear list
Ricoh GR Digital III Ricoh GR IIIx Fujifilm X-E1 Fujifilm X-H1 Fujifilm XF 18mm F2 R +6 more
KKJohn
Whoops, thought I better throw in a few flowers as well.
LouisScarole Regular Member • Posts: 168
You have the answer here
blessingx
blessingx Contributing Member • Posts: 606
Get the 90.
 blessingx's gear list:blessingx's gear list
Sigma dp2 Quattro Sigma dp0 Quattro Leica SL (Typ 601) Fujifilm X-Pro2 Sigma sd Quattro H +15 more
blessingx wrote:
Get the 90.
Hah, that's a given for sure but it's no lens for a tight-ish budget. Happily I have the best of both worlds in the 60 and the 90.
Spike Milligan
Re: You have the answer here
LouisScarole wrote:
http://www.fujivsfuji.com/60mm-f2pt4-vs-56mm-f1pt2/
Excellent comparison. Thanks for posting.
ijustloveshooting
ijustloveshooting Veteran Member • Posts: 3,003
i read the first sentence and quit reading rest. get 56 F1.2, no comparison there.
 ijustloveshooting's gear list:ijustloveshooting's gear list
Fujifilm X-A1 Sony a7 II Sony a7R IV Fujifilm XF 35mm F1.4 R Sony E 10-18mm F4 OSS +17 more
(unknown member) Forum Pro • Posts: 16,732
No... there is more subject isolation with the 56, but that means you have to be more careful with DOF. The 60 is perfect for 'formal' portraits, is very sharp wide open, has very precise AF and has very nice bokeh quality (typical macro lens).
56 is more specialised, will give more isolation at a distance which is good for street work, when the subject is full length and not as close.
I use the 56 more outdoors and the 60 in the studio. Also a near perfect product photography lens and duplication lens. I have shot about 20 photographs of painting and artworks for book covers with the 60 and it is really excellent for that.
Yes, and don't forget the effective macro strength of an APSC lens is 1.5X great than on FF. Eg 0.5X macro is actually 0.75X. So it's quite useful and very sharp.
I love them both, but I prefer formals with the 60 and street portraits with the 56.
Reporter: "Mr Gandhi, what do you think of Western Civilisation?"
Mahatma Gandhi: "I think it would be a very good idea!"
