Cross eyed to parallel
Started Apr 21, 2016 | Discussions
Athegn Senior Member • Posts: 1,341
I can view parallel images without any problem; I also have a parallel viewer (3D inlife??) so i can see large parallels on screen.
However most posts are cross eyed. I see on odd view; reversed front to back?
I can bring an image into Photoshop and swap the left and right but is there a way to swap within a browser?
 Athegn's gear list:Athegn's gear list
Sony RX10 III Sony RX100 VA
Sailor Blue
Sailor Blue Forum Pro • Posts: 15,536
Re: Cross eyed to parallel
Yes, it can be done but the problem is that the images posted are a single JPG image. You would have to very carefully select one image and copy it to a new layer, do the same for the other image, then move each image across to the other side and align them carefully at just the right distances.  Move with the right/left arrow keys and Shift + arrow keys so you don't move the images vertically.
A better alternative is to extract the two images as above then save each individually before combining them in StereoPhoto Maker (free) as a parallel 3D image.  StereoPhoto Maker can do an alignment if needed.
StereoPhoto Maker (English)
Living and loving it in Pattaya, Thailand. Canon 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Canon EOS 5DS R Tamron SP AF 90mm F/2.8 Di Macro Tokina AT-X 16-28mm f/2.8 Pro FX +9 more
OP Athegn Senior Member • Posts: 1,341
Thank you.
I wonder why cross eyed is the preferred option for publishing?
Turbguy1
MOD Turbguy1 Senior Member • Posts: 1,467
Actually, you can open the combined jpeg in StereoPhotomaker as a stereo image and click on "swap" to reverse them.  No need to extract them first.
Stereophotomaker will "break them apart".
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
Turbguy1
Many of us post crosseye here (and elsewhere) to permit "freeviewing" of a pair (no viewer aid required).
A significant portion of the population can freeview crosseye with a small amount of practice, and there is no practical limit to image size when freeviewing in that manner.  Normal vision requires crosseye control to converge on close objects.  The practice requires getting skillful at "decoupling" convergence and focus.   Once you accomplish this, it's like riding a bicycle, you don't forget how.
Freeviewing parallel is constrained by image separation not much larger than 2.5", or 65mm, otherwise vision has to diverge, which is NEVER done in normal vision and is quite uncomfortable, or even painful, for a huge percentage of the population.
The separation restriction limits the size of a parallel stereo pair capable of being freeviewed.
That said, it is possible to withstand and accommodate larger parallel separations with practice, but it can be very distressing at first. And it does not get easier with increasingly wider separations
Sailor Blue
Thanks for your post Turbguy 1.
I didn't know you could do that with StereoPhoto Maker.  I just tried it, using the Swap Left and Right command when opening a cross eyed JPG, and it worked perfectly.
Thank you all for your information
Joseph S Wisniewski Forum Pro • Posts: 35,462
Cross eyed dates back to the old JPS standard
Athegn wrote:
Thank you.
Like Turbguy pointed out, cross-eyed is the standard for "zero cost" viewing. That had something to do with why it was chosen for the JPS (side by side JPEG) and PNS (side  by side PNG, not to be confused with the PMS standard, which you really want to avoid).
The purpose of having "a standard" is so a lot of programs can process it. As long as the standard is easy to read (side by side JPEG qualifies), it serves as a useful input to a "conversion chain" that may output anaglyphs, left-right, crosseye, horizontal or vertical interleaves, or even top-bottom or two  separate monitors with one flipped for certain mirror viewers.
Problem is, they build a standard and nobody came. More on this in a reply to the main post...
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D90 Nikon D2X Nikon D3 Nikon D100 Nikon Z7 +48 more
JPS and PNS failed...
There used to be, but I don't think there is, any more.
The standard for stereo images is a cross-eyed side-by-side, or "RL" JPEG or PNG, with JPS and PNS (respectively) extensions and MIME types.
Once you know what image format you've got (LR "parallel" JPEG, RL "cross eyed" JPEG, odd or even vertically or horizontally interlaced JPEG, etc) it's a simple matter to convert it to any other viewing format (Anaglyph, LR, RL, compressed LR, interlaced, dual screen, etc) and apply any necessary lens corrections, etc). That's how RL became the standard: it's not "the best", it just serves as a "known starting point".
Back 10-15 years ago, during a 3D renaissance that never happened, people started releasing browser plugins that would allow you to set your viewing preference (anaglyph in various color combinations, LR, RL, interlaced, etc) and have any JPS or PNS display automatically.
Some of these included NuVision 3D, Schillr, and VRex DepthCharge. I haven't tried installing one of these plugins in a modern browser.
At least one of these (don't ask me which one) added a right context menu to allow it to process stereo images that were not properly tagged as JPS or PNS. That was very handy, as you could use it on all the images that people post in this forum.
Ciao! Joseph
hdr Senior Member • Posts: 2,867
Re: JPS and PNS failed...
Parallel viewing stereo pairs restricts one to viewing small images of 2" or thereabout without using any viewing contraption, ie. free viewing.
If one can view any size of image pairs using only the eyes, which most people can do with just a bit of determination or none, it is worthwhile acquiring the 'skill'.
http://SingaporeGallery.com : Sightseeing Without Hassle
green-is-my-friend New Member • Posts: 1
I just came across this post today and I needed to do that at times too...
And yes I can do the same as you, opening up the image in GIMP and swap left/right images myself but it seems like something you don't want to have to do repeatedly for every image.
So I made a quick simple javascript tool/page that allows you to enter URL of image
or select a file from your computer and you can render with adjustable midpoint.
https://cs-pattern.com/crossview-swap.html
tony brown Veteran Member • Posts: 4,387
You can just load the existing Xeyed image into Stereo Photo Maker as a 'Stereo Image'. It will then allow you to swap the images under 'View/Swap Left/Right' or output as Anaglyph in several modes, re-align or adjust in many ways.
See post above:-
https://www.dpreview.com/forums/post/57651416
Cheers, Tony.
