Panasonic 35-100 f2.8 vs Olympus 40-150 f2.8
Started Apr 20, 2016 | Discussions
kuro_neko
kuro_neko Regular Member • Posts: 178
I'm trying to decide between these two lenses. I keep flitting between the two and I'm hoping a little chat might help me make a decision.
There are pros and cons to each of course. IMHO these are:
Panasonic 35-100
Pros: Smaller, lighter and cheaper (£771 Amazon), slightly wider
Cons: Shorter reach, no tele-converter (that I know of)
Olympus 40-150
Pros: Longer reach, more versatility with the tele-converter, better minimum focusing distance
Cons: Larger, heavier and more expensive (£1,099 Amazon - strangely you can get it with the 1.4x tele-converter for just £2 more!!)
Essentially I want a lens to use at events (both indoor and outdoor - mainly outdoor). Last year I found my 75-300 was often too long at the short end and my 16-70 (Sony A6000 lens) was often too short at the long end.
I appreciate that only I can ultimately decide which will suit my needs best, but I figure some of you will have had to make the same choice between these two and I'd be interested to know people's thought processes.
 kuro_neko's gear list:kuro_neko's gear list
Sony a6000 Olympus E-M5 II Sony a6500 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake +18 more
Olympus 40-150mm F2.8 Pro Sony a6000
slartz
slartz Senior Member • Posts: 2,103
Re: Panasonic 35-100 f2.8 vs Olympus 40-150 f2.8
5
Panasonic 35-100
Olympus 40-150
You nailed it very accurately. The 35-100/2.8 is the world's tiniest PRO 70-200 2.8 lens It's incredibly small for what it delivers. Image quality is superb. internal focusing. crisp images. One could really NOT ask for more...
However... the 40-150 offers "more" in some areas, but at a cost. The 40-150 is like a 70-200 on a crop camera ;). It's definitely more useful as a TELE lens, however, the cost in size and weight is considerable. It probably wins *marginally* on IQ, and it definitly wins on build quality (not that the 35-100 is bad, but the Oly Pro series is just superb). So at the end of the day, the question is what you use it for...
See? here is where you answer the question... for "events" - 70-200 is a classic portrait range. you don't need longer than 200 in the vast majority of cases when shooting events, unless you're doing something wrong or the couple arrives in a helicotper and wants to be shot mid air. you would be very hard pressed to find any serious event photographers shooting Canon or Nikon using a lens longer than their 70-200/2.8 on Full Frame.
And as such, you can enjoy the advantages of the small size which would tire you less during an event.
Had you said you shoot wildlife, then the story would be different...
Well  -hope this helped
 slartz's gear list:slartz's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic 8-18mm F2.8-4 +10 more
Skeeterbytes Forum Pro • Posts: 23,182
1,100 pounds with the converter? No-brainer, get the Pro. Have several m4/3 lenses, zooms and primes, and the 40-150 Pro is my favorite. On the E-M1 focus is stunningly fast and optically, it's sharp across the zoom range.
Rick
Martin Ocando
MOD Martin Ocando Veteran Member • Posts: 6,720
Panasonic 35-100
Olympus 40-150
If is going to be used on events mainly, then is a no brainier, the 35-100mm 2.8 it is. it makes a great combo with the 12-40mm. I can't imagine having to lug around the 40-150mm for 4 hours straight. For anything else, maybe the 40-150 is a better choice, but for events, nothing beats the 35-100. And even for landscape, I find the 35-100 more than enough for me. At least I haven't used my 40-150 (the cheap slow one, not the Pro), in months.
Martin
"One of the biggest mistakes a photographer can make is to look at the real world and cling to the vain hope that next time his film will somehow bear a closer resemblance to it" - Galen Rowell
 Martin Ocando's gear list:Martin Ocando's gear list
Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Lumix G X Vario 35-100mm F2.8 OIS Olympus 12-40mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH +13 more
Bobby J Veteran Member • Posts: 5,191
Swartz, I think your'e comments pretty much nail it.  I have both lenses and I don't have a preference....depending on what I'm doing.
If I'm doing street photography, then the 35~100.  Also if I'm traveling I'll usually take it along with the 12~40.  Good travel set up, at least for me.
For "events" I'd take the 40~150 and the 1.4 TC as well.  As all here know it's an excellent lens.
The 35~100 also doesn't have outstanding close focus ability whereas the 40~150 does.  I realize both are expensive lenses and not everyone can afford to own both, so I guess it boils down to what you intend to use it for.  Actually if most of my stuff is kind of general and a long lens is not a prime consideration, I'd get the 35~100 and get the 65~300 for a lightweight long lens to "tag along".  My son bought an absolutely perfect one on eBay for 375.00.  He's thrilled with it.  So you could have both of these  for little more than the price of the 40~150 alone.  Just something to think about.
BJM
 Bobby J's gear list:Bobby J's gear list
Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 25mm F1.7 ASPH Olympus 12-100mm F4.0 Olympus E-M1 Olympus E-M1 II +9 more
I notice that the OP already owns the 75~300, so in his particular situation I think I'd like opt for the 35~100 Panny.  I think it would fit well in his equipment set up.  I also think the IQ I get from mine is as good as I get from my 40~150.
BJM
RaymondR
RaymondR Senior Member • Posts: 2,496
was looking at same choice earlier this year.  went with the Panny due to size and price differential.  like other posters, the Oly 12-40 and the Panny 35-100 is my basic two lens kit.  With the 12-40 mounted, I can fit the camera and both lenses in a Think Tank Mirrorless Mover 20. The Oly PRO is very desirable but we have to be practical!  I have the slower Oly 40-150 when I need more reach and am considering the Panny 100-300.
RaymondR
 RaymondR's gear list:RaymondR's gear list
Sony a7 II Sony a7C Sony FE 24-105mm F4 Sigma 70mm F2.8 DG Macro Art Tamron 17-28mm F2.8 Di III RXD +2 more
DLBlack Forum Pro • Posts: 15,865
You nailed the comparison  of these two excellent lenses.
I own both.  I got the Panasonic  35-100 f2.8 before the Olympus 40-159 f2.8 was released.  I used the Panasonic a bunch but found it a little short for nature and wildlife.  For when the reach was not enough I will use the Olympus 75-300 lens.  The image quality of the Panasonic is noticeably better than the 75-300.
Anyhow I got the Olympus 40-150 f2.8 and the 1.4x TC when it was released.   For my use landscspes and wildlife I like the Olympus 40-150 f2.8 a lot better than the Panasonic 35-100 f2.8.  Also with the 1.4x TC I have enough reach that I didn't have to carry the 75-300 any more.   So my kit became a little lighter.
It seems like every time I tried to go small by taking the Panasonic  I end but missing the extra length of the Olympus.
Anyhow, you can not go wrong with either of these  two lenses.  It basically comes down what is more important for you between smaller size or extra reach.
 DLBlack's gear list:DLBlack's gear list
Pentax K-7 Pentax K-5 Olympus E-M5 II Olympus PEN-F Olympus E-M1 II +46 more
dv312
dv312 Veteran Member • Posts: 9,215
Re: Panasonic 35-100 f2.8 for me
If you do a search you'll find another thread on this
I also contributed there
But in summary
I bought and sold the 35-100mm in favor of the 40-150mm
Then I realized I used the shorter focals more often so bought back the 35-100mm
and sold the 40-150mm
Both are sharp, no doubt
I prefer the bokeh on the 35-100mm
The 40-150mm could be fussy at times
Key thing is the 35-100mm is quite small and can easily be mounted on a Pen like body and used for streets without alarming anyone
Both are weatherproof so can be used with weatherproof bodies
I use my 75-300mm for longer reach; not quite as good as the 40-150mm but again lighter and smaller
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
slartz
in fact - the 75-300, in the range of 75-150 is quite amazingly sharp. it is afterwards that it loses quality. of course - it's not on the same league as the 40-150 anywhere along the line, BUT, up to 150, the 75-300 is surprisingly good for a consumer lens.
CrisPhoto
CrisPhoto Senior Member • Posts: 1,749
But then you can use the cheap 40-150/4-5.6. It is also very sharp up to 150mm
OM-D + Sam7.5, O25, O60, O75
O12-40, O40-150, P 14-140
 CrisPhoto's gear list:CrisPhoto's gear list
Olympus E-M1 II Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH +9 more
slartz
we might define "very sharp" very differently
I find the 40-150/4-5.6 to be a pretty mediocre lens, all across the board. sharpness, contrast, color, all a little "dead". I personally can't stand that lens...
kuro_neko
OP kuro_neko Regular Member • Posts: 178
Thanks for all the feed back guys. I've ultimately decided on the 35-100 for the size and weight saving (and cheaper cost). Shame that Panasonic never released a tele-converter for this lens as that would have made this decision somewhat easier.
I can see a use for Olympus 40-150 and if money was no object I'd get both, but sadly I can't justifying buying both (unless I win the lottery or something).
Day Hiker Forum Pro • Posts: 10,829
an event photographer
(Edit: I see that you bought the Lumix. Good move, although either is excellent)
I shot events for years (no longer, alas). An event photographer does not need a lens longer than a 70-200mm f/2.8 pro-level zoom. I speak from experience. Yes there are events, and then there are "Events." But I never needed anything longer than my EOS 70-200mm f/2.8 L.
Save some money and your back and get the Lumix. This is coming from a dedicated M.Zuiko 40-150mm f/2.8 PRO owner! I will eventually add the Lumix to my kit, as I see the two lenses complementing each other.
Jim Pilcher
Summit County, Colorado, USA
Life is good in the woods
