Fuji XE2 vXT10 after 2016 firmware
Started Apr 20, 2016 | Discussions
tombell1 Veteran Member • Posts: 3,138
I have a XA1 with the 18 /27 lenses.
I am thinking of either the above with the 18-55 zoom. I am tempted by the 10as I like occasional use of a flippy screen. However in the UK there is nearly £200 difference which would go a long way to my getting the 35/1.4 lens.
with the latest firmware from Fuji how do these cameras compare. My thought were to use the new camera for normal use and consider converting the XA1 for infrared usage
Look forward to hearing from you all
thanks
Tom
 tombell1's gear list:tombell1's gear list
Fujifilm FinePix X100 Fujifilm X100F Olympus OM-D E-M5 Fujifilm X-E1 Fujifilm X-T1 +16 more
Fujifilm X-A1 Fujifilm X-E2 Nikon AF-P 18-55mm F3.5-5.6G VR
DigitalJay Senior Member • Posts: 1,509
Re: Fuji XE2 vXT10 after 2016 firmware
My understanding is that the xe2 with the version 4 firmware is almost the same as an XT 10 there are a couple of mechanical differences that you can't fix and firmware but the differences are marginal
I have an X-E2 and an X-T1. I really like both cameras. The X-E2 is an outstanding value.
 DigitalJay's gear list:DigitalJay's gear list
Nikon D2X Nikon D200 Nikon D300 Nikon D700 Fujifilm X-T1 +2 more
carylee2002
carylee2002 Regular Member • Posts: 360
I own many camera bodies for fuji...but my biggest wow factor lately was the update of the 4.0 software on the XE2...When I mount that camera with my 18-135mm zoom...the pictures just pop compared to the old software. I sure hope there will be one more upgrade to the XE1/XPro1 series because I like the older X trans sensor look on my pictures, but I like the new interface that came with the 4.0 software better.
 carylee2002's gear list:carylee2002's gear list
Fujifilm X100F Fujifilm X-Pro1 Fujifilm X-E1 Nikon D7100 Fujifilm X-M1 +29 more
StuartBell Senior Member • Posts: 2,039
Far less price difference on the Fuji UK refurb store - though the X-E2 hardly ever seems to be in stock there.
http://shop.fujifilm.co.uk/refurbished-digital-cameras/compact-system-cameras?limit=15
Stuart
 StuartBell's gear list:StuartBell's gear list
Fujifilm X30 Fujifilm X-T1 Fujifilm X-E3 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
Elyharbour
Elyharbour Senior Member • Posts: 2,705
 Elyharbour's gear list:Elyharbour's gear list
Fujifilm X-T1 Panasonic Lumix DMC-GX85 Fujifilm X-E3 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
DarnGoodPhotos Forum Pro • Posts: 11,881
Price differences aside, chose the X-T10 if you want the center viewfinder, tilt screen, a bit smaller body, drive dial, and full auto mode. The X-E2 if you want a left-side viewfinder and a flash that can be pointed up.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Ed Steichen
Ed Steichen Regular Member • Posts: 322
I have an X-A1 as well as an X-E1. While I love the X-E1, I often I find myself grabbing the X-A1 simply because of the tilt screen. I also often go out with both bodies and use which ever one best suites the situation. The bodies are so small and light it's really no big burden to carry both. But when and if I ever upgrade, I want a body with a tilt screen.
Good luck.
 Ed Steichen's gear list:Ed Steichen's gear list
Sony RX100 II Fujifilm X-E1 Fujifilm X-A1 Fujifilm X-T1 Fujifilm XF 14mm F2.8 R +3 more
pb01890 New Member • Posts: 13
I tried the XT10 and appreciated the tilt screen. Though I do not have big hands I did not like the grip and its texture, small buttons and the central VF compared to my X-E1, so I opted for the X-E2. Try them both....
Good luck,
Patrick
 pb01890's gear list:pb01890's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Fujifilm X-Pro2 Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro +1 more
OP tombell1 Veteran Member • Posts: 3,138
Thanks everyone,
My feelings the XE2 incredible valie but I certainly do like a tilt screen.
Thanks re refurb as at that price from fuji the XT10 is only £100  more and is then very tempting.
I also like cameras with a bit more heft so I am tempted by that.
I also like the idea of inbuilt GPS  WHICH I think the XE2 doesnt have
The idea of trying them out is good. In the US people seem to be able to do this more thoroughlt
Calumet in the UK has Fuji rentals.
georgehere Regular Member • Posts: 194
you may reconcider it
They are quite similar, the X-E2 handles better in my view, but X-T10 has a tilting LCD. The X-T10 I found very inconvenient to hold, the palm of my hand would often be pushing the back buttons, and my fingers being in the air because there is no place to put them.
Unless you need a faster AF or EVF I wouldn't recommend swapping X-A1 for one of the other cameras. I currently have X-A2 (quite similar to X-A1), which in my view produces better image quality than any of the alternatives.
Ed Steichen
If you haven't invested in a thumb grip, I highly recommend one. I use a fotodiox type A on my X-A1 and it greatly improves handling. I wonder if such a solution could also improve the XT-10's handling.
There are also after market grips for the X-E(#)s and the XT-10.
I would also echo the sentiment of not getting rid of your X-A1.
Re: you may reconcider it
Thanks again
XA1 I will get a thumb grip as I have one on my X100 and love it!
XE2/ XT10 will continue to think and try it out ....
I think ideally I would like XE2 with a flippy screen. I mainly use VF but I do like waist shooting with screen to get low view and not to disturb the scene. Also I love the results from X100 and XA1 with Bayer and to be honest would love Fuji with ordinary sensor .... But what do I know ?
markam04 Contributing Member • Posts: 695
If the EVF is important to you, the X-T10 isn't as good as the X-T1 / X-E2.
I recently bought a second X-E2 on Ebay for £280 complete with body grip and thumb grip. Although I'd also like a floppy screen, I prefer the rangemaster style of the X-E2 is more important to me.
Unless you've got smallish hands, I wouldn't recommend buying the X-T10.
 markam04's gear list:markam04's gear list
Fujifilm X-T2 Panasonic G85 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +8 more
Ed Steichen
You are not at all alone in wishing for a broader choice of bodies with a bayer sensor.
I think if you can somehow get your hands on these cameras the decision will be made much easier.
Les Lammers
Les Lammers Veteran Member • Posts: 4,247
tombell1 wrote:
Thanks again
Me too but the XT-10 with a thumb rest is not bad IMHO. It. with the X-100 sensor would be fine with me.
 Les Lammers's gear list:Les Lammers's gear list
Ricoh GR Digital III Ricoh GR IIIx Fujifilm X-E1 Fujifilm X-H1 Fujifilm XF 18mm F2 R +6 more
