Panasonic 100-300mm vs Panasonic 100-400mm vs Olympus 300mm. Central sharpness comparison with GX7
Started Apr 20, 2016 | Discussions
OP Davatuk New Member • Posts: 9
Re: Would use f/7.1 to get the best from 100-300 to compare be better?
No, I used mechanical shutter. I do not know much about electronic shutter, just that it's not suitable for moving objects, so I was trying to behave as if I was shooting a bird. For that same reason I did not stop it down, the sharpness wide open is what matters for me.
alcelc
alcelc Forum Pro • Posts: 19,003
Your title is about sharpness. If you could not produce the sharpness image from your lenses, how can we judge which lens would be better? We can't compare a bunch of rotten apples and decide which one is better because of less rotten.
E-shutter might eliminate any possible shutter shock (I'm not a ss fanboy, but very often e-shutter could capture sharper image easier than m-shutter. In my experience with my GX7, e-shutter would be easier and could give 100% sharp image vs m-shutter's <100%), plus shoot at the sweet spot for their sharpness could make a fair quality/cost comparison.
After you picked the winner, you could then use it in anyway that suit you. How you would use it should be independent from a lens is better than the others.
YMMV
Albert
YMMV
Did you mean "if you could not produce the sharpest image"? If so, it was not my intention. I wanted to produce the sharpest image under specific conditions. Maybe I did not give the thread a proper title and clearly specify the conditions, sorry for that.
josbiker
josbiker Senior Member • Posts: 1,088
YMMV
Stop this nonsense!
Study and react sensible>
 josbiker's gear list:josbiker's gear list
Panasonic S1 Panasonic S Pro 70-200mm F4 OIS Panasonic S 24-105mm F4 Macro OIS Canon Pixma Pro-100
cameron2 Veteran Member • Posts: 4,142
Thanks!
Davatuk wrote:
As for myself, I am still undecided, but inclining to Panasonic 100-400mm. At the shutter speed of 1/500 sec, its quality seems to be comparable to Olympus. Another important thing is that it gives me a big step forward in IQ at shorter focal lengths (comparing to 100-300). And last but not least, the price difference, which is even more pronounced in Australia (AUD 1875 vs AUD 3387). And while not being f/4 at 300mm is a huge disadvantage for Panny, it hardly outweighs the advantages.
Thanks for posting these!
The Pany 100-300 being the baseline, the 100-400 is consistently better, but WOW! the Oly 300 is incredibly good! It's not "which one to buy", but "which order"
 cameron2's gear list:cameron2's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Hasselblad X1D
Julius
Julius Contributing Member • Posts: 865
Re: Exactly what I'd expect
I have both the 100-400 and the Oly 300mm and although the Oly has an edge on the 100-400, a light extra sharpening in Fotoblade brings it to a level that becomes pretty much indistinguishable.
So because of the size and weight and versatility of the zoom, the 100-400 gets used more than the Oly 300.
 Julius's gear list:Julius's gear list
Olympus PEN-F Olympus E-M1 II Sony a6400 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus 12-40mm F2.8 Pro +4 more
