Panasonic 100-300mm vs Panasonic 100-400mm vs Olympus 300mm. Central sharpness comparison with GX7
Started Apr 20, 2016 | Discussions
Davatuk New Member • Posts: 9
5
Okay, so my local store has finally got these new lenses, so I was very tempted to see how they will perform on my GX7. So I took my existing 100-300mm, and shot with all those lenses at variable focal lengths and ISO's. All shots were taken handheld at aperture priority mode, so shutter speeds varied. I didn't bother to keep the angle and focus the same, so overall this is far from being a comprehensive test. However, I hope it may help others, who like me can't decide on which lens to buy (or buy one at all).
To avoid jpeg compression on dpreview, I posted the images on my personal website (which is used just as a private storage, so no advertisement here). All images are 100% crops of a central area, developped in lightroom from raw and exported at the best quality.
http://www.blot.am/telephoto_test/review.html
As for myself, I am still undecided, but inclining to Panasonic 100-400mm. At the shutter speed of 1/500 sec, its quality seems to be comparable to Olympus. Another important thing is that it gives me a big step forward in IQ at shorter focal lengths (comparing to 100-300). And last but not least, the price difference, which is even more pronounced in Australia (AUD 1875 vs AUD 3387). And while not being f/4 at 300mm is a huge disadvantage for Panny, it hardly outweighs the advantages.
luisflorit
luisflorit Veteran Member • Posts: 8,514
ISO 200?
Thanks for posting these!
Indeed the difference between the oly 300 and the pany 100-400 seems small (although I think the oly has an edge). But both much better than the old pany 100-300. Good!!
Yet, your ISO200 300mm shot of the 100-400 looks considerably worse than the ISO200 one. Maybe the OIS is not really good? The oly looks much better. My experience with the 100-300 is that, at least in my hands and with my gear, the OIS is substantially worse than the EM1 IBIS. I have it perpetually off.
Thanks again,
L.
 luisflorit's gear list:luisflorit's gear list
Olympus E-M1 II Olympus 12-40mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro Venus Laowa 7.5mm F2 MFT Olympus E-M1 +3 more
OP Davatuk New Member • Posts: 9
Re: ISO 200?
Thanks again,
L.
You've probably mistyped something here: what is worse than what? With Oly at iso200, I shot only at f/4, forgot to do it with f/5.6. I do however, have f/4 with ISO 125, will now add it to the comparison.
Robiro Veteran Member • Posts: 6,813
Ultimate deathmatch
I would love to see an ISO200 shot taken with Pana Leica at 400mm, f8 downsampled to match an ISO200 shot taken with Oly 300mm PRO at f5.6. That would be an ultimate deathmatch between the two...
All your Pana Leica shots were taken wide open. There could be an image improvement at f8 at the long end, especially with your type of a shot (white letters on a black background).
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Panasonic 12-35mm F2.8 Olympus 40-150mm F2.8 Pro Sigma 30mm F1.4 for Micro Four Thirds Olympus 100-400mm F5.0-6.3 IS
luisflorit
Re: ISO 200?
Sorry, you are right, awfully said.
I meant that the 300mm shot of the 100-400 at ISO200 looks considerably more blurred than the ISO400 one of the same lens:
ISO200
ISO400
The speed was 2x faster in the ISO400, so I guess the OIS is not working so well?
L.
luisflorit
Re: Ultimate deathmatch
I've read a review with charts claiming that the 100-400 does not improve if you close it: its best is shown wide open (according to their charts, that is).
L.
I agree. But the reality could be different. I always thought f7.1 was the best setting for my 100-300mm at the long end.
But now I see I was wrong. There is definitely an image improvedment at f8.
So, my best guess is that at 400mm, Pana Leica could be a little better at f8 (or f7.1) than wide open at f6.3. The contrasty edges between white letters and black background could be better defined with less haze.
paul cool
paul cool Veteran Member • Posts: 3,137
amazing to see the little difference between oly and Panasonic at 300mm using same shutter speeds ?
these lens really need the dual is though that both pana /oly  make at anything below 1 over focal length s/s
 paul cool's gear list:paul cool's gear list
Sony a7R III Sony a1 Sony FE 70-200mm F2.8 GM OSS Tamron 28-75mm F2.8 III Tamron 17-28mm F2.8 Di III RXD +3 more
samtheman2014
samtheman2014 Veteran Member • Posts: 4,571
Re: Panasonic 100-300mm vs Panasonic 100-400mm vs Olympus 300mm
If your test was about image quality rather than image stabilisation would tripod mounted accurately manually focussed shots not have been far more informative as to the possible quality of the lenses. I appreciate that many will use the lenses handheld with image stabilisation being used, it is just for these type of tests handholding opens up potential issues as does using AF and variable shutter speeds , also with such long focal lengths small differences in angle of view can show very noticeable weaknesses in the final image.
Though given the £369 price of the 100-300mm , compared to the £1349 100-400mm and the £2200 of the 300mm , I would certainly hope that there is a very marked improvement with the pricier options.
 samtheman2014's gear list:samtheman2014's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GH4 Sony a7R II Panasonic Lumix DMC-GX8 Nikon AF-S Nikkor 14-24mm f/2.8G ED +10 more
photofisher Senior Member • Posts: 1,567
The effectiveness of the IS trumps all other considerations with a lens this long IMO. Both Oly and Pana were very wise to focus on this.
Family Man/Amateur Photographer
 photofisher's gear list:photofisher's gear list
Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 75mm F1.8 +3 more
Yes, I agree that this is not an IQ test, but rather testing the sharpness under the conditions that I will normally shoot. I also agree that while the old Panny 100-300 is not great at IQ, its main weakness is poor stabilisation. On GX7, stabilisation of Panny 100-400 and Oly 300 look more or less equal to me.
Julius
Julius Contributing Member • Posts: 865
The Olympus 300mm is clearly the BEST
nt
 Julius's gear list:Julius's gear list
Olympus PEN-F Olympus E-M1 II Sony a6400 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus 12-40mm F2.8 Pro +4 more
bgalb
bgalb Senior Member • Posts: 2,179
According to the resolution charts in THIS review, The lens central sharpness is best wide open up to 300mm , and then very slightly better at F8 at 350 and 400mm.
"Any sufficiently advanced technology is indistinguishable from magic." Clarkes 3rd Law
 bgalb's gear list:bgalb's gear list
Panasonic Lumix DMC-GM5 Olympus E-M1 II Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Panasonic 20mm F1.7 II Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +4 more
Boss of Sony Senior Member • Posts: 2,425
Re: Panasonic 100-300mm vs Panasonic 100-400mm vs Olympus 300mm.
As these are 100% crops, in my opinion the IQ difference is probably not visible at normal viewing distances, and therefore the only advantage of the 100-400 is greater length and possible better image stabilization (at the expense of size, weight, and price).
 Boss of Sony's gear list:Boss of Sony's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 9mm F8 Fish-Eye Body Cap Lens
You're right and made me think again. I've never felt disappointed by the sharpness of 100-300 at the shorter end, apparently because I've never needed to crop it, otherwise I would have zoomed in during shooting in the first place (well, with rare exceptions). And I would definitely benefit from f/4 at 300mm at low light conditions (and this is when the wildlife is most active). Tough choice.
Charles Bandes
Charles Bandes Senior Member • Posts: 1,928
Exactly what I'd expect
Looks like a 'you get what you pay for' sort of answer - the Oly comes out on top, the 100-300 on the bottom, and the 100-400 in the middle. Considering the price differential, I think the 100-300 does remarkably well, and while I'd agree that the Oly is the sharpest of the three, I remain quite happy with my decision to get the 100-400.
 Charles Bandes's gear list:Charles Bandes's gear list
Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Leica D Summilux Asph 25mm F1.4 +5 more
Thanks! As predicted.
Would love to see downsampled Pana Leica 100-400mm f8 shot compared to Oly 300mm f5.6.
jalywol
jalywol Forum Pro • Posts: 12,301
I'd be most curious...
To see a comparison of the 100-300mm vs the 100-400mm NOT wide open.  I know my 100-300mm does much better at f7.1 than at f5.6, for instance, out at the long end.
I'd like to see how they look stopped down one, or ideally, two stops.  (I'd do it myself, but I only have the 100-300mm, not the 100-400mm )
-J
Re: I'd be most curious...
-J
I'll do that for you, if I buy the 100-400. With my 100-300 at the longer end, I have also noticed better IQ when stopping down to f/7.1. However, from my birding experience, I rarely have the luxury to do so. And honestly, had I been able to constantly get the result shown at ISO 800 and 1/400 seconds, I wouldn't bother upgrading at all. The problem is, as mentioned in the review, I had a few other shots at 1/500 seconds, all badly blurred, just like at 1/250 sec.
alcelc
alcelc Forum Pro • Posts: 19,003
Would use f/7.1 to get the best from 100-300 to compare be better?
Please forgive me if it would have already been discussed/mentioned along this long hot topic before.
IICR, the sweet spot of 100-300 should be around f/7.1. As your testing had been shot mostly wide open (not sure on 100-400 but would likely affect the IQ from 100-300), your sample on 100-300 might not be its best (sharpness) to compare.... And had you use e-shutter?
Albert
