NX30 / NX2000 AC wall chargers, info semi-urgently required
Started Apr 19, 2016 | Discussions
PhotonRustler New Member • Posts: 22
Hi all,
I recently bought NX30 and NX2000 bodies on auction, however they appear to be shipped with the wrong Samsung AC wall plugs i.e 'Travel Adapter'. The seller acknowledges this (he has about a dozen samsung devices and got confused) and is going to send the right ones, but he needs to know which they are. Can anyone give me the model numbers for the NX30 or NX2000 wall plugs? I am in the UK, if that makes a difference, although I don't think it does.
This is the one he sent with the NX30 (appears to be an Australian plug, camera was bought from Simply Electronics so is from HK originally):
MODEL: ETA0U80HBE
INPUT: 100-240V - 50-60Hz 0.15A
OUTPUT: 5.0V = 1.0A
USB cable: CB5MU05E
I would think it should really be 2.0A as it's an AC charger, correct?
The NX2000 shipped with the Galaxy Camera charger, which is clearly wrong!
On a side note, can anyone confirm what the safe/normal charging is for both these cameras, in terms of voltage / amps? It might help identify the plug needed.
Any advice is greatly appreciated.
 PhotonRustler's gear list:PhotonRustler's gear list
Sony Cyber-shot DSC-HX99 Samsung NX11 Samsung NX200 Samsung NX300 Samsung NX30 +10 more
Samsung NX2000 Samsung NX30
nofaping Junior Member • Posts: 44
Re: NX30 / NX2000 AC wall chargers, info semi-urgently required
Im charging my NX30 using S6E+ charger and USB cable =]
 nofaping's gear list:nofaping's gear list
Sony a7R II Sigma 24-105mm F4 DG OS HSM Sony FE 50mm F1.8 Irix 15mm F2.4 Sony FE 85mm F1.8 +3 more
OP PhotonRustler New Member • Posts: 22
That is most helpful. Hopefully though, someone will be even more helpful and tell me what the correct charger(s) are.
Viking0728 New Member • Posts: 23
PhotonRustler wrote:
Hi all,
MODEL: ETA0U80HBE
OUTPUT: 5.0V = 1.0A
USB cable: CB5MU05E
My NX30 Adapter is Model #ETA0U61JBE
5Volt 1Amp
 Viking0728's gear list:Viking0728's gear list
Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 10mm F3.5 Fisheye Samsung 16-50mm F3.5-5.6 power zoom +2 more
Thank you! Maybe they are only 1A, it must be the external chargers that are 2A. Probably an engineering choice, not wanting that much heat in the battery compartment. I think the 'ETA0U' bit is the charger type, the other is the AC pin layout,
Borami
Borami Contributing Member • Posts: 782
Hi all,
MODEL: ETA0U80HBE
OUTPUT: 5.0V = 1.0A
USB cable: CB5MU05E
5Volt 1Amp
I can confirm this. The same with my NX30. Probably any USB charger will charge the camera. My other 2A charger seems to charge a little faster, but the original charger is 1A.
borami
 Borami's gear list:Borami's gear list
Nikon 1 V3 Samsung NX1 Nikon 1 J5 Nikon Z50 Nikon AF-S DX Nikkor 35mm F1.8G +20 more
Kisaha Senior Member • Posts: 2,300
I am charging my cameras (the batteries inside the cameras actually) with whatever connects, including fast charging power banks recently. Some times I am working with an Asus ZenBank charging simultaniously (althought only with the NX1, I haven't tried this with any other NX, maybe I will try the NX500 later).
I can't help you with your question, I just described my experiences in case you really need to charge and you do not have your preferable way available.
ArendjeF Junior Member • Posts: 28
I am using an universal charger from Pixo
Example pixo charger
bourdieu_boy Regular Member • Posts: 150
I charge my NX2000 with a generic USB phone charger with no problems.
Thanks for the replies, I contacted Samsung and they said they couldn't help me with info for either camera! How very helpful.
MOD Taffy Veteran Member • Posts: 5,020
Well, I am in the UK and I only use a charger bought of Amazon, (A fast charger for a KIndle, with the Amazon name across the top), and a USB lead. I use this charger for all my devices, Samsung NX300, Samsung NX30, Sat. Nav. Kindle, Kobo, Easy Acc power bank, etc. Works great. See the link below:-
https://www.amazon.co.uk/Amazon-PowerFast-Accelerated-compatible-e-readers/dp/B006GWO6JW/ref=sr_1_5/279-9508362-2326601?ie=UTF8&qid=1461309575&sr=8-5&keywords=Kindle+chargers
Have a good day.
Regards, Allan.
Thanks, the seller has refunded me £20 due to the missing charger, so I'll buy an external charger (I don't like using internal charging due to the whole 'oh my camera just exploded' worry).
Kinger
Kinger Contributing Member • Posts: 549
I think you may worry too much.
 Kinger's gear list:Kinger's gear list
Canon EOS M5 Canon EOS M200 Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM +3 more
I am using non-oem batteries, so you never know.....
