Micro adapter cards
Started Apr 19, 2016 | Questions
kansas red New Member • Posts: 4
Micro adapter cards
I was curious if anyone has used a MicroSD card in a 450D?
 kansas red's gear list:kansas red's gear list
Canon EOS 450D
Canon EOS 450D (EOS Rebel XSi / EOS Kiss X2)
brightcolours Forum Pro • Posts: 15,885
Re: Micro adapter cards
Should work just fine.
AdriaanMeijer
AdriaanMeijer Veteran Member • Posts: 3,047
All the time in my 600D
/All in my humble opionion of course!
/If I seem to talk nonsense or you can't understand me, it's probably my English
 AdriaanMeijer's gear list:AdriaanMeijer's gear list
Canon EOS 7D Canon EOS 600D Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm F4L IS USM Canon EF-S 18-55mm f/3.5-5.6 IS II +5 more
OP kansas red New Member • Posts: 4
Umm.... OK will thanks for so much for the information… Every time I put a micro card in my 450 D it tells me I cannot format it ?! Ok I will try again!
Canon EOS 450D
IAMAI Senior Member • Posts: 1,925
What  capacity is your Micro SD card? Is it higher than 32GB? Your camera will only take up to 32GB max. Anything higher is a different format.
A side note on the microSD to SD adapter. From my personal experience over the last 1.5 yearss with my adapters, they eventually stop working. I have had the cheap plastic welds on the adapters start breaking from repeated handling from the camera to the computer and back again resulting in erratic operation and on and off failure to work in the camera. I have also seen one develop corrosion as the thin gold plating wears off.
Other people suggested not using the cards to transfer data to the computer and use only a USB cord to the camera. Eventually that will also wear out. I would rather replace a cheap adapter than a USB connector in the camera.
AnthonyL Veteran Member • Posts: 3,686
Yes from time to time though not as the main card - it usually is in my phone.
If I suspect problems with a card I use the official formatter from https://www.sdcard.org/downloads/formatter_4/ as a starting point.
 AnthonyL's gear list:AnthonyL's gear list
Canon EOS 700D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +5 more
That is very helpful information thank you… My biggest obstacle is that I don't have a laptop or desktop I only have a galaxy tablet so I'm trying to figure out how to transfer my photos from my camera to the tablet the easiest way possible 🤔😐
Canon EOS 450D
Exit10 Senior Member • Posts: 2,264
Don't have a Galaxy to test - but isn't there a camera connection kit from Samsung specifically to allow this?
 Exit10's gear list:Exit10's gear list
Canon EOS Rebel T6i Fujifilm X-T3 Canon EF 200mm f/2.8L II USM Canon EF 24-105mm f/4L IS USM Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
Umm I will look into this!! Good idea thank you!!
Canon EOS 450D
