Equipment For Great White Shark Cage Dive????
Started Apr 17, 2016 | Discussions
CG_Photography Regular Member • Posts: 259
Hello all, I need some advice...
We are doing a great white cage dive in South Africa soon. I am an experienced dry land photographer (see web site below), and a certified diver, but have not yet tried underwater photography. I am trying to decide between keeping the shark dive simple with the GoPros, or renting some underwater housing for my higher end Canon gear. What do you all recommend? Also, since the cage is near the surface, do I really need to rent and learn how to use underwater strobes, or will the surface light be adequate? We have rented the boat for the day so I will have adequate time in the cage, and will not have other people in at the same time.
Advice appreciated, thanks
 CG_Photography's gear list:CG_Photography's gear list
Canon EOS 5D Mark II Nikon D800 Canon EOS 5D Mark III Nikon D810 Canon EOS 5DS R +15 more
Mkfb8 Forum Member • Posts: 84
Re: Equipment For Great White Shark Cage Dive????
A GoPro will probably the easiest option which will also give you the time to enjoy this amazing experience without being to busy fiddling with gear.
 Mkfb8's gear list:Mkfb8's gear list
Olympus TG-860 Sony a6300 Sigma 105mm F2.8 EX DG OS HSM Sony E 30mm F3.5 Macro Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA +2 more
Sandeman684 Regular Member • Posts: 428
Indeed, especially when you are not used to UW-photography, it can be very challenging to get good images from a camera, even for experienced photographer. Also, when in the very shallow water like a shark cage it can be difficult to read the screen, and I would not advice to use the eyepiece with a great white circling around.
 Sandeman684's gear list:Sandeman684's gear list
Canon G1 X II Canon EOS Rebel T6s Canon PowerShot SX10 IS Canon PowerShot G10 Canon EF-S 18-55mm f/3.5-5.6 IS STM +2 more
ShatteredSky
ShatteredSky Senior Member • Posts: 2,065
I understand your dilemma. Had the same reflections about taking my stuff to Tenerife (wetsuit, flippers et takes up a lot of space). Thought to snorkel for my first time in the Atlantic without camera. I broke down and took everything. There was even a dive shop with a better wetsuit for the cold water locally.
But since I have already 6 years of snorkeling UW photography under my belt, you really might want to start with the simplest setup and enjoy the experience (like stated above). IF in a cage you do not need to care about your orientation so much (I have no clue), you still might want to rent a housing.
Regards
"Blue for the shattered sky"
 ShatteredSky's gear list:ShatteredSky's gear list
Olympus XZ-2 iHS Panasonic LX100 Olympus TG-5 Panasonic LX100 II Samsung NX300 +5 more
nafik Contributing Member • Posts: 922
Keep it as simple as possible. Forget DSLR or anything fancy. You will be quite overwhelmed (i promise) and dealing with camera (any) is the last thing you want to do.
Diving for over 25 years and shooting underwater for over 10 years. Handling camera underwater for me is the same as on land. Nevertheless while on an hour long 90 foot deep shark dive in Fiji (no cage) I was pretty nervous and excited screwing up a lot of shots (forgot this and forgot that).
GoPro or something like a cheap UW camera (Fuji XP ___) will do just fine. Keep in mind what these will be just snapshots for your memories and friends to see. Enjoy the experience. I do not think that the world is waiting for another image of a great white.
Just a bull shark...10 feet away
M.
Nice camera...now show me your pictures.
 nafik's gear list:nafik's gear list
Canon PowerShot S100 Canon PowerShot G7 X Nikon D7200 Nikon AF Nikkor 50mm f/1.4D Sigma 10-20mm F4-5.6 EX DC HSM +2 more
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
As someone who loves photography, above or below water, I'm going to say take more than one camera! Probably not at the same time, but if you have the boat for the day you may have plenty of opportunities to see shark, take videos of sharks and take stills of sharks. Why not take the opportunity?
Last year several of my friends went on a shark dive in Roatan (non-caged). Since I'd already done that, i did not go, but I loaned one of my cameras to a friend who is not a photographer and who'd never shot underwater before. The camera was a Canon s95 in a Canon housing. (Total cost new, under $500).
His shots are blue, because he was 70 feet down with no flash. You won't have that issue, though you will want sun. Just so you see what a first-timer can do with a point-n-shoot, have a look here: http://www.cjcphoto.net/roatan2015/misc/index23.html
The shark dive pics start at the bottom of that page.
I've got a Gopro, Canon point-n-shoots in Canon housings, a Sony RX100 II in a Nauticam housing (most other shots on the link above were taken with the Sony and dual strobes) and a Nikon D810 in a Nauticam housing.
I'd find a way to get that Gopro in the cage, perhaps clamped to a bar and at least somewhat showing you.   Use it for video, not stills.  (Sucks for stills).   On the other hand, I'd love to see a video taken with a Gopro on a selfie stick as a GWS is about to eat it!
For still shots, I'd get a Canon point-n-shoot with matching housing.   Best bang for the buck and pretty good quality.  Generally you can get a new camera and housing for $400-500.
Should you do this, you will likely be more interested in the shark than figuring out the camera, but here are some tips.
1. Always use a strap to tether the camera to your right wrist.  (Shutter button operated with right wrist).    Same with Gopro - tether it as a backup to avoid losing it.
2. If you use the flash, also use the included diffuser.   If in less than 15 feet of water in sunlight, you won't need the flash, except possibly for fill.  (Note: The Canon s120 will not pop up its flash automatically.  You have to move a switch on the side).
3. Whatever setting you have, you want a decent minimum shutter speed.   Don't let it drop to 1/30th.   I'd start with shutter priority and 1/200th or so.   Set this on the surface and (hopefully) check it once in the water to be sure it hasn't changed.   Review your shots between dives carefully to see if you need to adjust settings.
4. Set your LCD brightness to the max so you can see the screen underwater.   However, trust your histogram then, not the LCD for brightness as it can make everything look overexposed.
5. Go into the water with a fully-charged battery...
6. If you have only one camera, and it's a point-n-shoot, remember to take some videos as well as stills.
I can see the point of not trying to do photography on the first cage dive as it may be quite overwhelming.  But if it IS that exciting, wouldn't you want to have some shots from the experience?   You could perhaps let another diver use the camera while you get oriented, if more than one diver is in the cage.
Phoenix Arizona Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
OP CG_Photography Regular Member • Posts: 259
You sir, look like a guy who likes to enjoy life enjoyed your website.
Thanks all for the good advice so far; I am still interested in other opinions. Does everyone agree that if I did rent a housing, strobes are unnecessary at shallow depth?
tobyone
tobyone Regular Member • Posts: 379
Olympus TG-4 with wide angle adapter, forget stobes.The water will have a lot of flack with Backscatter issue using stobes. I have had realizability issues with the GoPro 4 black..
Toby Armstrong
PHXAZCRAIG
Strobes - first, if in a cage, I'd think dual strobes on arms would really get in the way.   And why have dual strobes if not putting them on arms?
Second, IF the sun is out, you won't need strobes.    But you could always try some shots with the camera's strobe on, through a diffuser.    Should bring out detail in the shadows.
This shot was taken in shallow water with a Canon s95 in a Canon housing, no strobe:
If you don't have sun, you'll want a camera with good high ISO performance.
www.cjcphoto.net
seansrs33 Regular Member • Posts: 203
You will not need strobes and secondly there are is no room in the cage for the strobes. UW Strobes especially when doing WA have to be spread out. In UW photography you have to position the strobes so you minimize the amount of backscatter. I have done two trips to Guadalupe Island in Mexico. You are in the cage with others. We would be in the cage 1 hour and out one hour. Here is are a couple of links to the photos from both of my trips:
http://www.seansydnorphotography.com/p804059299
http://www.seansydnorphotography.com/p668020807
Also if you rent a housing, you should also get some type of insurance. If you have never used an underwater housing before and you do not put things on correctly you can get a flood. Even the most experience UW photographers have a flood at some time in their career.
roccoriley Regular Member • Posts: 250
If you have a Canon SLR and a good wide angle lens, especially the 14mm, I would suggest that you borrow or rent a housing with a dome port and a single strobe.
Since you will have the cage all day you will have the opportunity to take a lot of photos. The extra wide lens will be great at the distance you will be working if the boat operator is chumming the water. If you have the sun overhead or in your face you will need the strobe for detail when the shark approaches the cage.
Before you go on the trip practice installing the camera in the housing and operating it and see if you can dive in a pool to check everything out underwater and take some test photos.
When you get into the water the first thing to do is turn the housing around and look inside it carefully to see if there is any leakage. If there is, just send it back up to the surface. If you close the housing carefully and keep the o ring properly greased you will not have leakage.
Worst case: If operating the housed Canon gets to be too much (unlikely) just drop the housing on the floor of the cage and enjoy the experience.
With a housing you will have the opportunity for some great photos.
DiverDown2 Regular Member • Posts: 252
I have done Great White cage diving in Guadalupe Mexico. If not stormy you will not need a strobe you are less than 10ft. deep. I would go with the GoPro and enjoy, you will be amazed!!!!!!!!!!!!
Each time they approach the size is like a Small Whale so Enjoy.
I spent 22 hours in the water over 3 days. and only came out to warm is the hot tube with hot chocolate.
Chrixxer New Member • Posts: 2
I'm about to take this trip. Bringing a Sony ⍺6000 (with a generic waterproof housing) and a GoPro Hero 3+. Thinking about getting a mask with an integrated GoPro mount (my current mask is >20 years old...). Will I need a magenta or red filter? (I think there are some cages that are down around 40' but I don't remember where I saw that.)
Thanks!
kelpdiver Veteran Member • Posts: 5,564
Thanks!
where are you taking the trip?
The Guadalupe guys have been making the cage openings smaller, as there was a number of incidents with sharks in the cage in 2016.  Consequence- there are a lot of bars.   You can readily get close to the opening so your view isn't obstructed, but a mount above your mask or attached to your reg may not be.    And your ability to track them as they go- inferior.   Much more capable with hand mount, but obviously not when using the Sony.
No red filter for the surface cage, but could be a choice for the submerged tank.   You do give up some light though - keep that in mind.
We're on the Nautilus Explorer at Guadalupe Island. For the Sony I have a 19mm 2.8 prime lens (Sigma) that fits the housing, and I'll be shooting raw. For the GoPro - well, it's really optional, and if it's as you say, may be a waste of time and effort? I can bring either a 3+ Black or a 3+ Silver; the Black can shoot in Protune, so it may be the better option. Just kinda liked the idea of a "fire and forget" video recorder I could leave running hands-free. (I have an extended battery pack that gives me about 3 hours on a charge, and the extended housing to fit it.)
PHXAZCRAIG
To be honest, while I love seeing shark pics, I think a more interesting pic would be to see the diver as well as a shark.   Can you clamp your Gopro to the cage such that it captures the inside of the cage and part of the outside?   I would like to see the diver reacting to a close shark approach probably more than the shark's approach alone.
So - Gopro to catch the scene, stills camera to catch the sharks.
www.cjcphoto.net
You will love the trip, and the Nautilus Explorer is the one to go with.
If you do the 40' submerged cage a Video Light or Strobe will help, the other Cages you do Ambient light.
Enjoy!!!!!!!!!!!!!!!!!!!
P.S. If Beto or Lowell is the captain you will love them.
