Superzoom shootout including old Panasonic Leica 14-150
Apr 17, 2016
11
Last year I was searching for a good super zoom lens for traveling. But which one to choose? I think some of you might know the problem ...
What makes things more complicated is the fact that I am used to excellent image quality from my 12-40 and 40-150 PRO lenses. Soon after buying the first superzoom lens, I felt the desire to test another lens. At the end, I ended up having 3 lenses
Because I had access to three superzooms at the same time and made some detailed comparisons, I think I should post my results here. Last not least, the old FT Panasonic Leica lens is quite rare and there are not many reviews/comparisons at all.
This are the lenses I have:
- Panasonic 14-140 f3.5-5.6
- Olympus 14-150 f4-5.6 V1
- Panasonic Leica 14-150 f3.5-5.6
I also had the old Panasonic 14-140 f4-5.6 and the Tamron 14-150 in my hands but did not do any further testing because I was not happy with their tele respective wide angle performance.
During my testing adventure, I decided to do a side by side comparison shooting selected subjects from tripod. This made comparing the lenses much easier ...
I did around 20 different subjects (landscape, architecture, portrait, close up) and evaluated sharpness, contrast and bokeh quality.
Resulting on my long time usage and additionally resulting from the controlled test setup, my findings are like this:
Favorite: Panasonic Leica 14-150 :
- + Best sharpness and contrast all over the frame and at all focal length. Comes close to my Oly PRO lenses.
- + Good sharpness and contrast for close ups (like flowers)
- +- AF is a little bit slow on my EM1 like other old design DSLR lenses or the 20/1.7 pancake. On my EM5 its really slow but at least it is accurate and usable.
- - The focal length is reduced to around 120mm for shorter focal distances
- - The lens is bulky and heavy, 535gr plus FT-adapter
- - The zoom barrel is heavy and tends to creep if holding the lens downwards half zoomed out
Second: Panasonic 14-140 II:
- + Sharpness is good at wide and normal end and gets better at tele end
- + Usable contrast and sharpness for close up
- + Fast AF
- + Compact lens, shorter than the Oly lens but a little bit fatter
- +- OIS is not as good as IBIS
- - Prone to shutter shock, best used with EFC or electronic shutter
Third: Olympus 14-150
- + Good sharpness wide, even better up to 50mm
- + Fast AF
- + Compact lens but somewhat long when extended to 150mm
- - Soft images at 150mm
- - AF not always spot on at 150mm (camera has problems to find perfect focus?)
- - Soft close up photos, especially at tele end
I made an Excel matrix comparing the lenses and I made a statistic regarding sharpness:
Subjective rating from +++(excellent) to --- (really bad)
Oly 12-40 PRO, Oly 40-150 PRO, Panasonic Leica 14-150, Panasonic 14-140 II, Olympus 14-150 I
To give you some impression on the sharpness/contrast differences, here are some 100% snippets from 2 subjects (architecture + flower):
Architecture 100% crops from center
Architecture 100% crops from corner
Close up with similar magnification (0.2x) at 100%
Close up Bokeh and maximum magnification
Conclusion after one year of usage:
The Panasonic Leica lens might be perfect for people who want got to excellent IQ from a superzoom lens but and don't mind slow AF or some bulk.
The newer Panasonic mFT lens might be perfect for traveling light or for those that are happy with little less than perfect IQ for landscape or architecture but search for good telephoto resolution.
The Oly lens (which is optically similar to its weather-sealed mark II incarnation) is a good option for architecture or occasional portraits but I found it to be less attractive for tele or macro usage.
In my next post I will show a short size comparison of the three lenses ...
Christof
OM-D + Sam7.5, O25, O60, O75
O12-40, O40-150, P 14-140
