Insects + Spiders of Colombia + Ecuador
Started Apr 16, 2016 | Discussions
(unknown member) Forum Member • Posts: 50
8
A few creatures from a recent trip to NW South America. I was using an E-M1 with the 60mm macro and the 12-40 and 4-150 pro lenses. I was happy with the size and weight of the kit, however I did not get the same impression of bomb-proof quality I get with my Nikon gear. All three lenses occasionally suffered from condensation on internal elements, and the E-M1's rear dial started acting up and it failed to recognize the 40-150 a couple of times (the strap was connected to the left strap lug and to the tripod foot rotated to the right side of the lens, I think this was torquing the lens just enough for the contacts to not all connect.) All of these issues happened over the course of two months of heavy use, and for the majority of the time everything worked flawlessly.
Butterfly courting behaviour
I wasn't planning for this bee to fly into the frame, but I'm glad it did.
One of the many colourful species of bees in the Amazon
An interestingly patterned spider; looks like a goat's head to me.
I stumbled across this large weevil surveying its domain from the top of a flowering bromelaid.
A very well-armoured beetle.
An orchid-mimic spider; despite some major lens condensations issues I think this one cleaned up pretty good.
An assassin bug giving a mosquito a taste of its own medicine.
Thanks for looking,
Joshua
Olympus 40-150mm F2.8 Pro Olympus E-M1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
Re: Insects + Spiders of Colombia + Ecuador
first prize goes to the weevil pic, I love weevils
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Trevor Carpenter
First prize goes to the weevil pic, I love weevils
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
love the weevil too! But a set of excellent pix
Great set Joshua. I like them all, The butterfly pic is particularly well handled too. Extreme photographic conditions.
Intriguing and worrying about the condensation. Was it a feature of extreme humidity (I have had this happen occasionally here in PNG which is also in the wet tropics) or change of temperature between air conditioned and ambient hot?
And the belt otrquing the lenses? What is a belt doing attached to the camera lug and tripod foot and pulling against the lens? I am not getting that.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
(unknown member) Senior Member • Posts: 1,505
top notch field macro!
samtheman2014
samtheman2014 Veteran Member • Posts: 4,571
Thanks for looking,
Joshua
Beautifully gruesome pictures Joshua, it was all going so well butterflies and bees , then the creepier side of the creepy crawly gang appeared :-). Lovely shots, really well taken of critters that we do not have in my cooler part of the world. I especially like the image of the orchid-mimic spider
 samtheman2014's gear list:samtheman2014's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GH4 Sony a7R II Panasonic Lumix DMC-GX8 Nikon AF-S Nikkor 14-24mm f/2.8G ED +10 more
OP (unknown member) Forum Member • Posts: 50
Thanks Trevor,
I am also a fan of weevils, I couldn't believe my luck to find such a charismatic one perched so photogenically for me. I'm still trying to figure out which species all of these are. Unfortunately the forest they live in share a name with a certain mega e-commerce website which has so far foiled my online search attempts.
All the best,
Joshua
Re: love the weevil too! But a set of excellent pix
Thanks so much Geoffrey!
I think it must have been the extreme humidity. It would typically occur within an hour after heading outside. When I had my Nikon gear in southern China (similarly hot and humid) the outer surface of the front element would occasionally have condensation on it after leaving an air conditioned hotel, but it would disappear quickly. In South America I wasn't staying anywhere with air conditioning, and in most cases the only thing separating indoors from outdoors was a bug screen so the temperature and humidity difference couldn't have been that great, but it would take much longer for the condensation in the lens to disappear. Anyways, I'll be purchasing extended warranties (which come with a free cleaning) for these lenses just to be safe. Also, 99% of the time I live in a much, much dryer and cooler part of the world where hopefully this won't be an issue.
And I should have explained the strap issue better. I've got a camera strap with quick release clips so that it can be easily removed when not needed, leaving only small connector tabs attached to the camera. I have connector tabs on both of the E-M1's strap lugs as well as a third on the 40-150 pro tripod foot. When using the big lens I rotate the tripod foot so that it sticks out in front of the EM-1's grip and then switch the right end of the strap from the right strap lug to the tripod foot connector. This lets the camera hang comfortably at my side with the lens pointing down, and, I thought, supported the heavy lens a bit more directly. I guess this was putting too much strain on the lens mount and I'll have to figure out another strap solution.
Thanks Cangopluto! Amazing work with that telescope by the way.
Thanks Sam,
I apologize, I didn't intend to instill a false sense of security by putting the friendlier looking ones first, but I'm glad you made it to the end. That orchid-mimic is really special, just incredibly well adapted for such a specific niche, i couldn't believe it was even real when I found it. I'm really enjoying the 60mm macro for finding the unseen beauty (and sometimes horror) of the insect world. Back home the bugs are much smaller and more skittish than the giant, frame-filling, lazy things in the tropics; this summer is going to be a learning experience for me.
samtheman2014
Thanks Sam,
The mimic spider is truly exotic, I just got the 60mm macro myself, though I will probably be pointing it a flowers etc
Thanks Sam,
That's what I thought I would be using mine for too. Sooner or later something strange will buzz or crawl in front of it though. It really is an eye opening lens, enjoy.
samtheman2014
Thanks Sam,
Spring is just starting to sprout here Spring is great if you are quick you can get all the flora images you want before too many insects warm up
