andre2you wrote:
Hello All,
So, I really trying to work on my manual focus technique. Here's my issue, So, I'm taking video of Softball games from a distance (trying to get ready to take video of my daughter in the marching band) and I'm just not getting the shots crisply in focus. I'm using the 50-150 S lens w/focus assist and I'm looking thru the EVF. I use the red color and i get what I see as outlined in red but when I play the video back it's slightly out focus. I've tried this multiple times as I will talk during the focusing saying this is out of focus, out of focus and then when in focus I say ok this is in focus and at times during the out of focus statement its in focus and the when i'm saying it's in focus it's not. I hope that made sense? I assume many of you are using MF with the NX. I've really tried using autofocus but the NX as well as the Cannon 70D (which was worse) had issues with not staying focused. I would think that from say 100 yards away if your subject moves 30 feet you should pretty much stay close to focus. Do you have any suggestions? I intend to keep practicing until I can nail it.
There are many tools that can be helpful.
You should read the manual a few times maybe.
Some tips, one or two of these will maybe be helpful.
DMF (on)
Lens priority
Adjust the af setting so you can full press but it will not take photo until in focus.
Use a smaller aperture and higher ISO for larger DOF.
SAF with a small center spot.
If nothing works, try the scene modes maybe.
When it is green it is focused but it can be on the background ofcourse.
Use burst mode.
5x/8x focus aid
Make sure speed is enough so it is not motion blur or camera shake.
Turn OIS off.
good luck !
" Use the shutter button on the headset cord " - Leonardo Da Vinci
