70-300L with Kenko double stacked TCs
Started Apr 14, 2016 | Discussions
herion
herion Contributing Member • Posts: 756
Image quality is excellent! AF function seems to be a little iffy on the far end of the zoom range. You'd probably be safer with MF at that point, but at that magnification, getting a sharp image isn't that big a problem! Images are SOOC. Effective range is 300*1.6*1.4*1.4 = 940mm
 herion's gear list:herion's gear list
Canon EOS 30D Canon EOS 40D Canon EF-S 10-18mm F4.5–5.6 IS STM Tamron SP 45mm F1.8 Di VC USD Tamron SP 85mm F1.8 Di VC USD +2 more
Canon EF 70-300mm f/4-5.6L IS USM Kenko Teleplus Pro 300 AF 1.4x
ed rader Veteran Member • Posts: 9,068
Re: 70-300L with Kenko double stacked TCs
just because you can do something doesn't mean you should
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
herion
OP herion Contributing Member • Posts: 756
True, but great for moon shots and other odd stuff!
crashpc Veteran Member • Posts: 7,237
Please, post some more photos. I need to bookmark this and see it later on good LCD...
If it provides better image quality than all these compact bridge cameras, I don't see a problem for static shots...
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
herion
Will do!
