Nx 50-150 is it really F4.2
Started Apr 12, 2016 | Discussions
Milondon15 Regular Member • Posts: 224
I have just bought the Samsung 50-150 for a great price but my excitement was slightly dampened after finding that F2.8 lens on APS-C is really equivalent to F4.2 full frame lens.  Is this true?
Samsung 50-150mm F2.8 S
Harleysoftail
Harleysoftail Contributing Member • Posts: 506
Re: Nx 50-150 is it really F4.2
This great article might help clarity things for you:
http://www.bobatkins.com/photography/tutorials/crop_sensor_cameras_and_lenses.html
If you read the paragraph under "Aperture" you will find the following answer "f2 is f2 is f2 and f8 is f8...period.
Hope this relieves your anxiety about your lens purchase because this is a GREAT lens.
 Harleysoftail's gear list:Harleysoftail's gear list
Samsung NX1 Samsung NX 60mm F2.8 Macro ED OIS SSA Samsung NX 12-24mm F4-5.6 ED Samsung 16-50mm F2.0-2.8 Topaz Adjust +5 more
Krazyheaven Regular Member • Posts: 411
I'm pretty sure 2.8f is still 2.8f. It's the same speed. The only change being the dof.
OP Milondon15 Regular Member • Posts: 224
Thanks for the article.
Makes me feel much better now.
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
5
That's the kind of 'terrorism' spread by the worshippers of FF. The article linked by harley should clarify everything.
btw, aperture is a property of the lens, NOT of the sensor/camera.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
Harleysoftail
Great....now get out there and enjoy that awesome lens!  I know you will be impressed.
ttbek Veteran Member • Posts: 4,869
Some misinformation in this thread.  It is not only the DOF that is different, but also the noise because there is less total light reaching the sensor.  An extensive coverage of the topic is here: josephjamesphotography.com/equivalence
So, yes, in some significant ways it does perform in a way similar to that of an f/4.2 lens on a FF camera, but exactly the same as if you used those FF f/2.8 lenses on an APS-C camera.  But using a Canon 70-200 on their APS-C (1.6x) is like a 112-320mm f/4.2 FF equivalent whereas the Samsung is like a 75-225mm f/4.2 In terms of DOF, but also photon shot noise if the FF and APS-C sensors being used have the same quantum efficiency.
Don't get me wrong, I'm no FF sycophant.  I may have a 5D, but it is a very old camera and my NX1 is far superior.   I am eyeing the 1dxII though, we'll see if it's worth the upgrade to shoot side by with the NX or not.  I prefer the NX system over anything else on the market, but physics is physics and while yes, the lens IS f/2.8, it does not act as an old film FF user would expect an f/2.8 lens to act (and for historical reasons that is some sort of de facto standard, we could just as easily calculate everything in relative terms to any other sensor size, say m4/3) in terms of angle of view, shot noise, and DOF.   Whether you're happy with the physics or not is up to you, I'm quite satisfied with f/2.8 on APS-C for the vast majority of cases.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Most of this article is very good.  I would quibble about the aperture bit though. He doesn't say anything wrong, but while the f/2.8 on APS-C and on FF have the same brightness, they have different noise levels (for final output images of the same size at the same viewing distance, which is the standard for comparison).  It's true that if your final output is proportionate to the sensor size then this doesn't matter though.   I guess I should also be careful if we are talking about the same framing or the same distance to the subject if we consider DOF.
arvidb New Member • Posts: 16
Your lens is an f/2.8 lens, and it gives the same exposure (sensor illumination) as an f/2.8 lens on FF (so you would use the same ISO and shutter speed settings). But it will give the same depth of field and (given similar sensor technology) same total image noise as a f/4.2 lens on FF. Why? Read on...
The "f-number" (focal ratio) of a lens is its focal length divided by its aperture:
N=f/D, where
N is focal ratio ("f-number") [dimensionless],
f is focal length [unit: mm], and
D is aperture [unit: mm].
Your APS-C lens' aperture varies between 50 mm/2.8 ≈ 18 mm and 150 mm/2.8 ≈ 54 mm over its zoom range.
For the same angle of view (AOV) on FF you would use a 75-225 mm lens. Given a focal ratio of 2.8, its aperture would vary between 27 and 80 mm over its zoom range.
Given the same subject distance and framing (AOV), the only thing determining how much light is gathered from the subject (and thus final image noise) is the size of the aperture (and this also determines the depth of field). To collect the SAME amount of light, you need the SAME aperture size, regardless of sensor size.
A lens with the same AOV and same light gathering capability as a 75-225/2.8 mm lens on FF would need the same aperture size but a shorter focal length: 50-150/1.9 (50/1.9 ≈ 26 mm, 150/1.9 ≈ 79 mm). It would be approximately a stop faster than the FF lens, and you would use one stop lower ISO on the APS-C camera than with the equivalent lens on the FF.
"One stop lower ISO? But then the APS-C image would be lower in noise!" No! Check the dpreview ISO comparisons: comparing contemporary cameras, the APS-C cameras have about the same noise as a FF camera at one step higher ISO! Edit: Link. Use Low light, Print resolution (otherwise you'll only be comparing sensor resolutions), and RAW. That's because ISO have nothing to do with noise, only with exposure, and at the same exposure (sensor illumination), the APS-C will collect a smaller amount of light since its area is smaller, and noise has everything to do with total amount of light collected. Note that sensor size does not determine noise - only lens aperture does, but you need a faster lens with a smaller sensor to collect the same amount of light from the same scene.
This is true for micro four-thirds as well; they have about a two stop difference in noise compared to FF, but will again give the same amount of image noise given a fair comparison, i.e. with the same total amount of light.
shademaster Contributing Member • Posts: 803
Dear lord, please let us not start ANOTHER thread on equivalent aperture and FL
I'm sure the linked article is great. But f2 is not f2 is not f2. That's the whole point. In SOME WAYS your f/2.8 is f/2.8 is f/2.8, and in SOME WAYS it is "just like" or "very similar to" f/4.2 on full frame... otherwise people wouldn't have invented the term "equivalent aperture".
Here's the whole story in as short a nutshell as possible. (I didn't read the article)
+ Your 50-150 2.8 will be "the same as" a 75-225 f/4.2 on full frame in the following sense: the field of view and depth of field will be precisely the same. (That's why they are "equivalent").
+ It is "different" in the sense that the PHOTONS PER UNIT AREA PER UNIT TIME is different. (say, 50 f/2.8 on APS-C or 75 f/4.2 on FF). It is the f-number that tells you the photons per unit area per unit time. This is the info you need (photons per unit area per unit time) to compute the exposure properly.
+ So if you compare a 50-150 f/2.8 on APS-C to a 75-225 f/4.2 on FF, the FOV and DOF will be precisely the same, but you will need to expose longer or increase the ISO on FF since you are at f/4.2. For "equivalent sensor technology" for fixed exposure time (say 1/60 second) increasing the ISO on the FF will give essentially the same image with the same noise.
+ (OPTIONAL READING) Of course a 75-225 f/2.8 on full frame will have a narrower DOF and less noise for the same exposure time since you are back down to the same ISO you were using on APS-C but one doesn't always WANT narrower DOF (I can rarely get two human faces in focus on APS-C at anything more open than f/2.8 unless I have people glued into a chair).
DONE.
Please no more discussions of equivalence
anywhere
ever
Go get the Samsung lens if you aren't worried about extinction of the NX line.  Full frame is overrated (Sony wants you to buy buy buy!!!).
 shademaster's gear list:shademaster's gear list
Canon PowerShot S95 Samsung EX2F Panasonic LX100 Samsung NX300 Samsung NX 30mm F2 Pancake +3 more
HendeHoq Junior Member • Posts: 33
 HendeHoq's gear list:HendeHoq's gear list
Fujifilm FinePix Real 3D W3 Samsung NX300 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 20-50mm F3.5-5.6 ED +3 more
Re: Dear lord, please let us not start ANOTHER thread on equivalent aperture and FL
If only, but unfortunately some people don't accept physics and https://xkcd.com/386   ^_^
zipcode Regular Member • Posts: 312
I don't really think the whole ''light per pixel'' thing should be taken in consideration when talking about lenses in regard to sensor sizes, just dof differences and perspective etc.
I mean everywhere you read and everybody knows how ff has noise advantage etc. So that thing is already taken in consideration by default I would say. Saying your lenses are suddenly slower just makes it seem like an extra advantage of ff. Not to mention that not all technology in all sensors is the same. Is that canon 50 1.4 really 1.4 on both 5dmarkiii and 5dmark0?
viking79
viking79 Forum Pro • Posts: 14,157
Yes and No
Its full frame equivalent lens would be 75-225 f/4.2, yes, but it is still a 50-150mm f/2.8 lens, those physical properties never change.
The equivalent part comes into play if you were to use a 70-200mm f/4 lens on your 6D, shooting at 200mm f/4 ISO250 1/100 sec you would select 135mm f/2.8 and ISO100 1/100 sec to get exactly the same shot: framing, depth of field, image noise, and shutter speed (assuming similar sensor tech).
You will find that full frame offers more flexibility, but is not unilaterally better. There is always a trade off. For full frame you can trade depth of field for faster shutter speed, longer shutter speed for lower image noise, etc.
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Of course not. Your lens is equivalent to 550-1650mm f/31 lens in full frame. You do know that 8x10 is full frame? 36x24mm is small format photography...
I'm not old enough to know, so I'm really asking.  I see people say that sometimes, but was the "full frame" moniker actually ever commonly applied to large format?  My impression is that the term started being used with the first digital cameras that were 35mm since it was such a common format in film and the typical user of it was previously being forced to downsize to jump to digital.   I could be totally wrong though.
It's true that the sensors are usually not the same, but quite often in these comparisons the newer better tech sensor is actually in the APS-C body (Sony being the apparent exception since they're iterating their FF so fast).  I think it is important to mention the light though,  because it is why FF appears to be less noisy, not because of bigger pixels and whatnot (actually that matters, but not in the way the average Joe thinks it does).  Maybe we should try to make it more clear that it's not a slower lens per se, but a slower-ish (I don't like the terms fast and slow for lenses... I know why they are used but feel they're a bit misleading) lens/sensor combo and it's not different than their expectations probably were anyway for the combo?  Light per pixel isn't the issue, it's the total amount of light given the same final size comparison, pixels aren't needed to derive this at all.
It was more a joke, not to think about numbers but to shoot and enjoy oneself
I guess it depends on geography (language) as well, in Germany they (35mm - 135) were called kleinbildfilm (small image film). They were a revolution as they allowed compact cameras you could just carry with you (take a look at some of the more compact, for example, Konica models - they are tiny and yet 35mm).
