17-40, 16-35 2.8II or 16-35 IS 4 on 1d IV
Started Apr 12, 2016 | Discussions
powerear New Member • Posts: 3
Hello,
I just bought a used EOS 1d IV.
I already have a 17-40 4L from my 1d II. The new cam has 16 MP instead of 8 MP so I wonder if I should buy a "better", sharper lens.
The 1D IV has a crop of 1.3.
The 17-40 is known for it´s lack of sharpness on the edges on full frame cameras. On my old 1D II I noticed also a lack of sharpness, but more or less over the full frame compared to my 70-200 2.8 II IS.
The 16-35 f4 shows in tests quite a good sharpness overall, also on the edges on a full frame cam.
The 16-35 2.8 II is again less sharp on the edges on an full frame. But on the 1d IV with crop?
I did not find any tests on a 1.3 crop camera of this lens.
From my point of view a 2.8 on a wide lens should be preferred over f4 with IS. But the sharpness is more important for me.
Is it worth to buy a 16-35 f4IS or a 16-35 2.8II in exchange of the 17-40?
Tim
Canon EF 16-35mm F2.8L II USM Canon EOS-1D Sony FE 70-200mm F2.8 GM OSS
StevenSHH
StevenSHH Contributing Member • Posts: 609
Re: 17-40, 16-35 2.8II or 16-35 IS 4 on 1d IV
EF 16-35mm f/4L IS USM does have IS, good for handheld shots where tripod/monopod not allowed.
EF 16-35mm f/2.8 II is better for low light situation, 17-40 f/L is not bad if for landscape if stop down a bit.
Why don't you take a few test shots with tripod and show us? May be the result will surprised yourself.
*I am assuming you shoot mostly landscape.
Enjoy 1D IV !
 StevenSHH's gear list:StevenSHH's gear list
Canon EOS M6 II Canon EF 24-70mm F4L IS USM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 32mm F1.4
Tapeman Contributing Member • Posts: 672
The often discussed weakness of Canon's 16-35 f/2.8L II is the edges.
I have used that lens on my 1D IV and am quite happy with it.
I now however, use it more on my 5DsR, but it is not so bad that I am likely to change to Canon's f/4 version.
If I were starting over I would get the f/4 version as it is widely considered to be a fabulous lens.
hotdog321
hotdog321 Forum Pro • Posts: 21,141
It would be nice if Canon made a 16-35 f/2.8L IS that was as sharp as the 16-35 f/4L IS, but they don't
I've used the 1.3 crop 1D series bodies with the 16-35 f/2.8 and it works O.K., but the f/4L version is just so darn good that I've relegated my old f/2.8 lens to backup duty in a drawer.
In all honesty, I really haven't missed the f/2.8 speed, even when shooting in truly awful light. The IS on the new 16-35 f/4L IS is so solid that I handhold in and even shoot "Hail Marys" under low light. Boring example from last week:
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
CameraCarl Veteran Member • Posts: 9,204
Sports Shooter
Sports Shooter Senior Member • Posts: 1,648
why? are you shooting a lot in low light?
 Sports Shooter's gear list:Sports Shooter's gear list
Canon EOS-1D Mark IV Canon EOS-1D X Mark II Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF 70-200mm F2.8L IS II USM +14 more
ed rader Veteran Member • Posts: 9,068
16-35L f4 IS = best on planet....
16-35L f2.8 II = soft in corners and softish wide open.  I have years of experiences with both lenses as well as the 17-40L.  I choose BOP :^).
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
kevindar
kevindar Veteran Member • Posts: 4,625
Have owned all 3. but on full frame.
1.  try your 17-40L on the 1d4 and see if you are happy with it.  if you are, then nothing else matters
2. I very much doubt that you will see much of difference between these lenses on 1d4, except the 16-35 f4 has better flare resistance.  the 16-35II is an excellent lens, except in the side of the frame and corner, all of which will lie outside of your sensor.  same with 17-40
3,  If I absolutely knew that I will never switch to a full frame, I would chose the f2.8 over the f4 lens, as I find the extra stop of light more useful that the IS (as long as prices are similar).  24-70 2.8II goes for average of 1800, while the f4IS variant goes for 800. yet most prefer the 2.8II. but thats my personal peference
4. Finally, for being future proof reason, you cant go wrong with f4L IS, if you fee compelled to upgrade.  it really shines in terms of corner to corner sharpness on a full frame sensor.
 kevindar's gear list:kevindar's gear list
Canon EF 85mm F1.2L II USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Sony a7R II Sony a6300 +25 more
OP powerear New Member • Posts: 3
Thanks for your replies. Today I am going to visit calumet to take some test shots.
I testest a bit with my existing 17-40 f4 and I find the corners with the crop of 1.3 not very sharp on f4. On FullFrame this will be even worse.
On my old 1d II this was not the big issue, but on the 16 MP Mark IV and bigger prints this might be a problem.
But another question regarding the 1D IV focus system:
The cam uses a higher number of cross sensors mit 2.8 and also with some of the f4 lenses. Including 17-40f4.
As the 16-35 f4IS is relatively new on the market this lens is not on the list of supported lenses. Does the cam support this lens with 39? cross type sensors as well?
How to test this?
clager Contributing Member • Posts: 824
No brainer!  16-35 f4. best Canon wide ever!
 clager's gear list:clager's gear list
Leica S2 Canon EOS-1D X Canon EOS 5D Mark III +1 more
Leon Wittwer Forum Pro • Posts: 13,559
I have both the 16-35 f/2.8 II and the 16-35 f/4 and the f/4 is significantly better on my 1D4.  The f/2.8 does have some softness as you approach the edges.  The IS on the f/4 comes in handy too.
Oceanmist New Member • Posts: 18
I had the 16-35f4is and I liked how easy it was to shoot with. I had to send it back due to a lot of flare. Even if I wasn't shooting directly towards the sun it will still flare. My 17-40 handles that much better. Its not as sharp in the edges as the f4IS but stopped down its good enough on my 6d.
Tillman Kleinhans Regular Member • Posts: 373
I've used the 17-40L on both the 1D2 and 1D4 (1D3 also) and it was OK on both.  I bought the 16-35 f4L IS to improve sharpness etc and it is a far better lens than the 17-40L in all aspects.  I also use it on a FF body (5D2) and it is easily noticeably superior on that body than the 17-40L.
Tillman Kleinhans ARPS EFIAP/b DPAGB
http://www.tkimages.co.uk
Marj, my wife and best friend, says my passions are obsessions.
