XF60mm 2.4 as a Portrait Lens
Started Apr 12, 2016 | Discussions
Mike Carroccio
Mike Carroccio Contributing Member • Posts: 641
Re: XF60mm 2.4 as a Portrait Lens
That's what I do. I have two of the hoods for the 35 f1.4and use one of those on the 60.
Michael Carroccio
San Antonio, TX USA
http://michaelcarrocciophoto.us
 Mike Carroccio's gear list:Mike Carroccio's gear list
Fujifilm X-T4 Fujifilm X-E4 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +5 more
Hurwitz CHL Junior Member • Posts: 37
Flying Fijian wrote:
Hurwitz CHL wrote:
Schleiermacher wrote:
XF60/2.4 is a fine all-around lens. It is extremely sharp with beautiful rendering of colors. While not as fast as the 56/1.2, it is still quite usable as a portrait lens. I changed out the goofy large lens hood for a small square one that’s overpriced. I love the focal length and use it for everything from macro, to street, to landscape. I dropped mine recently which destroyed it. I replaced it, even though I own the 50/2, which has blazing fast autofocus. While the 60/2.4 is slower to focus, it is not an impediment to good general photography.
Hi, the overpriced square hood sounds interesting, is there a model number? thanks.
You could just use the xf 35mm f1.4 hood if you have that.
Omg it works, and looks cool. Thanks for the tip!
I use the 18mm f2 one, fit a bit tighter than normal, no vignette.
I also found out that when focus to the nearest, the focus barrel could hit the tip of the hood, causing the camera stop working, with a shut off warning. Totally doable with normal shooting distance. (don't know if the 35mm one has the same problem)
 Hurwitz CHL's gear list:Hurwitz CHL's gear list
Fujifilm X100T Fujifilm X-Pro1 Fujifilm X-T1 Fujifilm GFX 50R Fujifilm XF 18mm F2 R +5 more
Flying Fijian Senior Member • Posts: 1,623
No the 35mm f1.4 works perfectly...18mm f2 is a bit smaller.
 Flying Fijian's gear list:Flying Fijian's gear list
Ricoh GR III Fujifilm X-E3 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R +13 more
