Thoughts on LG G5 wide-angle camera
Started Apr 9, 2016 | Discussions
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,920
So far I haven't been able to find out any details on the wide-angle camera on the LG G5. It's straight 4K/UHD 3840x2160 pixels, and LG claims a 135-degree angle of view. Pictures taken with it report a focal length of 1.53 mm.
If I back-calculate from that 1.53 mm focal length, a 135-degree angle of view translates into a 7.39 mm projected image. Assuming that LG's angle of view is measured on the diagonal (something they seem to like to do), that would give a sensor size of 6.44x3.62 mm. That's larger than the 1/2.6" main sensor, although the increased light-gathering of the larger sensor can't quite compensate for the f/2.4 lens versus with the main sensor's f/1.8. The sensor size also gives a pixel size of about 1.7 microns, compared with the 1.12 micron pixel size of the main and front cameras.
I've seen reports that the wide-angle camera has OIS, but experimentation suggests otherwise, as does the iFixit teardown. Not that OIS is as important with such a wide angle.
For whatever the above information is worth.
The open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
LG G5
WJMWJM Regular Member • Posts: 161
Re: Thoughts on LG G5 wide-angle camera
Doug, good to see at least one person noticed this wonderfull wide-angle news....:))
(seems it has pronounced fisheye/barrel-distortion in the horizontal axle, but that is nothing software could not solve (preferably inboard/Android
Started the below thread today, on the Casio forum; the Casio Tryx being the only comparable combination of compact & wide-angle thusfar, since many years:
http://www.dpreview.com/forums/post/57630454
That said: your attempt to re-calculated angle of view into focal length and/or sensor-size is a rather tricky one.
I once tried the same, owning said Tryx, with 21mm-equivalent wide-angle, 4.0mm optics, and a Samsung WB210, 21mm-equivalent, 3,8mm optics. Both 1/2.3" sensor.
(written few postings on that topic in the past, many moons ago, never got much feedback....;((
http://www.dpreview.com/forums/post/40548096
PS: see also my general wish for a combination of Casio's HDR-Art, Panasonic's/Olymus's infinite panorama, and wide-angle (lens will still affect the vertical angle in a panorama, so more is still better).
http://www.dpreview.com/articles/2817145452/panasonic-announces-lumix-dmc-fz70-60x-optical-zoom?comment=8852496912
