60D Upgrade: 6D or 80D
Started Apr 7, 2016 | Discussions
Devliin New Member • Posts: 3
Sorry if this post is a bit wordy but I wanted to provide as much info as possible.
So I think I've finally reached a technological road block on my 60D that is causing me to consider upgrading. I exclusively shoot portraits and over the last 3 years I've increasingly found the 9 AF points of the 60D limiting when it comes to framing my subject. For that reason I've been considering upgrading to the 6D for the two extra AF points and obviously the image quality improvement that FF brings.
The release of the 80D has thrown a screwball into my plans.The 45 AF points & Digic 6 chip make it very attractive. The only things that matter to me are photo image quality ( I make a lot of normal size prints)  & usability, don't care about any of the video features. Which is a better upgrade option, a used 6D or new 80D?
Canon EOS 60D Canon EOS 6D Canon EOS 80D
Kelly M Jones Contributing Member • Posts: 747
Re: 60D Upgrade: 6D or 80D
"I've increasingly found the 9 AF points of the 60D limiting when it comes to framing my subject."
The 6D focus points covers a smaller part of the viewfinder than your 60D, so if you can work around that limitation on the 6D, then why can't you work around the same limitation on the 60D? What I'm trying to say is, if that's the main reason to switch away from your 60D, then the 6D will not be better in that respect. The IQ of the 6D, of course, will be much better.
The IQ of the 6D is outstanding, but if Bill Claff's measurements are correct, the dynamic range of the 80D at ISO100 will be better than the 80D at ISO 100. If you shoot mostly at ISO100, then the 80D might work well for you. However, if you shoot at anything ISO200 or higher, then the 6D is simply better with regard to noise, dynamic range and IQ.
The 80D focus system is really nice with great coverage in the viewfinder. The swivel screen can be very handy if you need to focus the camera from low or high, plus the touch screen makes it even easier to use.
My opinion would be to wait a little while to make sure there are no major issues with the 80D reported, then go with the 80D.
-Kelly
vlad2304 Regular Member • Posts: 399
Actually you can buy new Canon 6d now cheaper than 80D:
http://www.adorama.com/ICA6DKZ.html
I had the same dilemma but I chose 80D for 2 reasons:
1. It's lighter as a body and much lighter together with lenses.
2. It's a brand new model.
The last reason is important for me as if I buy 6D and in, say, 6 months there will be a new model,
I will loose my sleep.
I've tested a lot of RAW files from both models and have found that 80D quality completely satisfies me.
 vlad2304's gear list:vlad2304's gear list
Sigma dp2 Quattro
Dave
Dave Veteran Member • Posts: 6,312
What lenses do you have?
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +13 more
Sigma 17-50 OS HSM and Sigma 18-300mm F3.5-6.3 DC Macro OS HSM (C).
Sigma dp2 Quattro
k3shooter Forum Member • Posts: 83
If you have EF-S lenses, you may as well stick with a crop body.  Otherwise you start over from scratch.
I'm not sure how much better the AF is on the 6D compared to the 60D.  It's probably not a big difference.  The 80D should be a big step up.
Steve
 k3shooter's gear list:k3shooter's gear list
Olympus PEN E-P5 Olympus E-M5 II Pentax K-70 Sigma 17-50mm F2.8 EX DC OS HSM Panasonic Lumix G X Vario 35-100mm F2.8 OIS +2 more
Dave
Steve
Also interested to learn what lenses the OP has.
Mark B.
Mark B. Forum Pro • Posts: 30,026
Being as they are both DC lenses, you'll need to upgrade to FF lenses.  Both of these will vignette on the 6D.
Mark
Mark
Mark,
I first bought Canon 80D and then lenses.
Sigma dp2 Quattro
Christopher Regular Member • Posts: 441
Thanks for asking about this, as I am wrestling with the same choice, though coming from a 50D.  Main subjects are travel, macro, nature (though not really much fauna), theater, and a bit of sports (soccer).  I've gradually gravitated toward primes and have a 35L, 50 1.8, 85 1.8, Sigma 150 macro, and 70-200L 4 IS.  Have sometimes rented a 15mm fisheye for travel, and I may buy a wider lens (such as Rokinon 14mm or 16-35L 4 IS) in the near future.
I have liked the cameras in the X0D series but have also noticed their limitations, especially in low light shooting like theater when there is very high contrast between the lights on performers' faces and the darker or unlit shadows around them.  Seems like the ability to push shadows in the 80D would be good for this, though the 6D is known as a low light champ.
chris1001 Regular Member • Posts: 112
Try and rent or borrow a 6D (fantastic IQ, I sold my 7DII almost straight away after "seeing the light"), once you've experience FF it's hard to go back to crop - unless you need the 1.6x for any other reason.
 chris1001's gear list:chris1001's gear list
Canon EOS R Canon EOS R5 Canon Extender EF 1.4x III Canon EF 100-400mm F4.5-5.6L IS II Canon RF 15-35mm F2.8L IS USM +3 more
Mark B.
Mark
Mark,
Why did you respond to Dave's question, which was aimed at the OP?  I didn't look at the username, I thought you were the OP.  The question was for the OP who was asking about upgrading to the 80D or 6D.
RedFox88 Forum Pro • Posts: 30,738
That may have been true 8 years ago, but not today. Unless your way of appreciating photos is at 100% or larger view on a large computer monitor.
I guess we all have our standards, and various degrees of OCD, I'm particularly fussy and am yet to find a crop sensor Canon that produces better IQ than my 6D.  All my monitors are 27".
Yes but in the end you need to ask is the difference really worth the extra expense, size, weight so that pictures look a little better when viewed closer than standard viewing distance. Show aps-c and 35mm pocs to the average person and they won't see a difference.
DannH Contributing Member • Posts: 689
I'm in a very similar position, currently shooting with a 60d but considering the 6d and 80d. The 80d offers lots of small advantages but I keep considering the 6d for the excellent IQ. Some people say it's not noticeable, but personally I can see the difference. For strictly portraits you would probably be better with the 6d but only if you can invest in good glass (which gets very expensive) and are aware that the perspective will be different from what your use to. That's one (there are several) thing holding me back from going to a 6d atm, to replace my 85 1.8 on FF id be looking at a a 135 f2 or 70-200 2.8 for portraits but that's almost the cost of the new body.
What lenses do you currently own/plan on buying if you get the 6d?
Dave
Mark B. wrote:
Mark
Mark,
NP with that, though I am wondering when/if the OP will return.
OP Devliin New Member • Posts: 3
Currently I shoot with the Canon 50mm 1.4 & Sigma 17-50mm 2.8 for portraits. I'm aware that I'll have to upgrade the glass if I go with the 6D. For the most part I don't have gear envy or "upgrade fever", i'm looking just looking for the best IQ and usability
I'm considering waiting until Adorama has the 80D available for rent to test it out side by side.
wire1 New Member • Posts: 1
I've used 60d and 80d, but 6d is in in very different league IMO.
The IQ on 6d is very noticeably higher on 80d. In fact, in good light or with good flash setup, you will see very little IQ difference going from 60d to 80d. Noise is lower.
The real difference is in AF, which is really advanced in 80d compared to 6d.
However, for portraits, to really focus on the eyes, you still need to slow down with 80d, otherwise your focus will be over the place, which kind of matches 6d work flow anyway.
For wild life, definitely 80d is the winner, AF system just rocks in many different ways, but for landscapes and portraits, I would go with 6d. Something about its IQ that's really special.
 wire1's gear list:wire1's gear list
Fujifilm X100S Canon EOS 60D Canon EOS 1100D Canon EOS 6D Canon EOS 80D +13 more
George Zip Senior Member • Posts: 1,633
I concur.
Full frame has a different quality that I can't really explain, but recently getting the 7DII I am really impressed how good the images are. For normal use ( internet and prints) I'm hard pressed to see really obvious differences.
I like both.
