Major SD card problem after trip
Started Apr 7, 2016 | Discussions
J Craig H Regular Member • Posts: 185
Hello,
I just got back from a 3 week trip to Vietnam where I used the e-pl6 and 17 1.8 a lot.
The problem is that, now that I'm eager to transfer those 900 pictures to my computer, disaster appears to have struck. I used a Sandisk Extreme 16gb card - one of the red 30MB/sec ones from a few years ago, but it hasn't been used that much. I 'think' I formatted it before I used it but I really can't be sure. (I know, lesson learned - always be sure...) When the card filled up I changed it, and the shots were there at that point.
Now none of the pictures I took show up in Lightroom 6, only shots from 5 years ago that were taken with a different (Nikon) camera. When I inserted the card back into the camera it showed 'card full' and when I hit play it shows 'picture error'. I did an evaluation of the card using RescuePro Deluxe and it only shows the Nikon files. To double check I also tried a different recovery software ('z-a-recovery') - it shows those same pictures along with some FAT files (which I think just refer to the file structure?) and two 'RAW PPM' files of a few thousand KB each.
Basically it's as if those shots were never taken. What I don't understand is this: If the card had become corrupted or some similar error, wouldn't the damaged files at least be visible? Is it possible for them to vanish, apparently without trace, like this? I know I'm jet lagged but this just seems bizarre. I'm pretty certain I'm looking at the right card, and I've transferred all the other cards from my Nikon along with the 300 shots from the epl-6 after I changed cards. I'm happy to provide more detail as needed.
I don't really know what I can do at this point and would really appreciate any informed advice. I'm not a novice by any means, but not a hardware guy either and it's obviously mildly devastating to lose so many irreplaceable photos.
(Sorry in advance if I'm posting this on the wrong forum - I couldn't seem to see one that was more appropriate so went with the camera that took the shots.)
Thanks,
Craig
 J Craig H's gear list:J Craig H's gear list
Nikon D800E Fujifilm X-T3
Olympus PEN E-PL6
PurpleFringe Contributing Member • Posts: 663
Re: Major SD card problem after trip
Sandisk  has its own recovery software that's usable on Sandisk cards. Have you tried that?
 PurpleFringe's gear list:PurpleFringe's gear list
Fujifilm FinePix X100 Olympus PEN E-P1 Olympus E-M1 Olympus E-M1 II Panasonic Lumix G 20mm F1.7 ASPH +7 more
OP J Craig H Regular Member • Posts: 185
Yeah, thanks. That's the RescurePro one. Only showed the Nikon files.
Narcosynthesis Senior Member • Posts: 1,832
If it is showing as 'card full' then the data has been set aside for something, but the only option I can think of for recovering it is what you have already tried - running sme of the recovery software designed to recovered deleted or corrupted data - I know there are a few options out there, so it may be worth trying more than one version to see if it picks up anything differently.
How are you downloading the images? Are you doing it directly through the camera or through an external reader? and have you made any updates o any of your software recently (camera firmware/lightroom/computer)?
www.flickr.com/photos/narcosynthesis
www.illaname.deviantart.com
samtheman2014
samtheman2014 Veteran Member • Posts: 4,571
J Craig H wrote:
Hello,
Thanks,
Craig
Hope you sort it out Craig losing our photos from such a great trip is about as bad it gets for us photographers , have you tried Recuva the do a free version to try out. Best of luck
https://www.piriform.com/recuva
 samtheman2014's gear list:samtheman2014's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GH4 Sony a7R II Panasonic Lumix DMC-GX8 Nikon AF-S Nikkor 14-24mm f/2.8G ED +10 more
agott123
agott123 Senior Member • Posts: 2,579
Try TestDisk (nt)
Alex
Couldn't help but make me feel ashamed to live in a land
Where justice is a game. From Bob Dylan's 'Hurricane'
 agott123's gear list:agott123's gear list
Panasonic Lumix DMC-GF1 Olympus PEN E-P2 Olympus PEN E-PL1 Panasonic Lumix DMC-GH3 Olympus PEN E-P5 +21 more
Araldite Contributing Member • Posts: 829
look for a sub directory (Oly) in your nikon folder
 Araldite's gear list:Araldite's gear list
Fujifilm X-S10 Fujifilm 50-230mm Fujifilm 15-45mm F3.5-5.6 OIS PZ +2 more
Thanks, I'm downloading them through the slot in the back of my iMac. I would like to try it through the camera to see if there's any difference (?) but can't find the cable t the moment. I did update to LR 6 recently, but just tried it on LR5 and got the same result.
Thanks, Sam. Yeah, it's an awful feeling. I lost (in the old sense of the word) a load of photos from a trip to South Africa in 2010 and since then have been carrying my cards around in a red sock! This latest techno-snaffu is bringing back those bad times. I couldn't get recuva to work on a Mac and have to go to work soon but I might try it later on my windows laptop.
Re: Try TestDisk (nt)
agott123 wrote:
Alex
Thanks, I'll try to look again, but TestDisk didn't seem to recognize the card.
Thanks, nothing unfortunately - once 'DCIM' folder with 730 Nikon images.
Tom Axford Forum Pro • Posts: 10,097
J Craig H wrote:
Hello,
It is very unlikely that you formatted the card if Lightroom found images from 5 years ago!
I think it is quite possible that you have mixed up your memory cards. It would be worth double checking all your other memory cards.
You can also run the Disk Utility program supplied with the Mac and use it to verify the "disk" and it should tell you if there are any problems caused by corruption. (Don't use it to repair the disk, however, as that may corrupt your images even more.)
daddyo Forum Pro • Posts: 12,670
Craig,
If the images on the card were visible for review in your camera before you pull the card out, it would seem that they are buried somewhere in the card memory. However, you may be facing a situation where you would need to send the card to a recovery service to retrieve them -- and that could be costly.
I know there is a highly regarded service in Germany that a number of professionals use, but can't recall the name.
The fact that the card allows the Nikon files to be accessed would indicate to me that the card is not corrupted, but that the Nikon files are simply 'blocking' access to the Olympus files.
I hope you can get the files back. For what it's worth, I've had pretty good success with "DiscDigger" in the past.
God Bless,
Greg
www.imagismphotos.com
www.mccroskery.zenfolio.com
www.pbase.com/daddyo
 daddyo's gear list:daddyo's gear list
Olympus 12-40mm F2.8 Pro
Jouko Senior Member • Posts: 1,985
Sorry to hear about your problems...
But as far as I can quess, you may find an other card somewhere in your luggage containing those photos. Or maybe on your desk or in another camera?
RescuePro does a good job usually - I have tried it a couple of times because of wrong time formatting... User error. But, if you can find those old Nikon files from that card, it means you have not formatted the card for a long time - or used it after formatting, if it was the RescuePro that found the files. It finds the last photos taken before formatting.
But, as you said, you have some timelag on, and maybe sleeping gives a clearer view on this matter.
Good night!
Jouko
'The best camera in the world is the one you have with you when you need it'
http://lehtokukka.smugmug.com/
http://jouko-lehto.artistwebsites.com/
http://joukolehto.blogspot.fi/ - Lenses for mFT-cameras
10
Well I'm more than delighted to report that I am an idiot!
I had the card in a plastic bag in a hidden pocket of trousers that I hadn't worn for the last 10 days of the trip. I was so sure I had moved that card in with the others, and I'd somehow marked an identical SD card as used so concluded that had to be it, but there you go.
There's a lesson in there somewhere - for now I'll go with 'get over your jetlag before you start transferring your photos'.
I really do appreciate people's thoughts and ideas on this.
Craig
BDavis Regular Member • Posts: 479
I am with you Tom on possibly mixing up a card.
Also the possibility if having missed a directory, for example, when the numbering goes over 9999, it makes a new directory.
Jet lag, lack of sleep, excitement from coming back from a job or trip, all these can cause one to overlook the simplest of things.
Check ALL your cards.
Phil Senior Member • Posts: 1,080
I know how you feel when you do something "stupid".  Lord I have been there.  A little advice:
I travel with a small laptop and download the images every night.  I do not use the same SD card until I get another backup off the laptop.  Once that is done, I do the full format of the card and put it back in the que.  I travel with two cameras and 8 SD cards.
One of my travel buddies lost his (probably a format) and I used Rescue Pro.  The only time I have ever used it.  It worked.
Phil
 Phil's gear list:Phil's gear list
Olympus E-M5 II Olympus E-M1 II Olympus E-M1 III
cerich
cerich Contributing Member • Posts: 580
Put card back in camera...see if camera sees them, if yes download from camera to pc
 cerich's gear list:cerich's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus PEN E-PL6 Olympus Air Olympus OM-D E-M10 II +33 more
(unknown member) Contributing Member • Posts: 611
That is first thing to come to mind because:
- You see years old pictures in card, but none of the taken
- Recovery software can't find any taken pictures, just the old pictures
If there would be bad error, you couldn't even access the card as it wouldn't be recognized what so ever. If there would be damaged pictures, likely just the last or second last picture would be corrupted. And if just the most common error, card looks empty but everything is there and you get them with recovery software (that is the case 95.9999% of the times (rest is couple files corrupted))
- Never fill the card full. Always leave it 80% full. So swap cards often.
But, it is possible that the card partition data blocks has been corrupted and card is using an backup partition data blocks that overwrote everything. That would explain the directory structure but not missing files from taken, as those are written over everything legacy. And you can read the card content overriding the filesystem itself and then mapping data from the stream back to files.
  1. Multiple cards
  2. Swap often cards (like every 50-100 shots if shooting rarely, otherwise like 1/6th of the card capacity)
  3. Backup cards when possible to two mobile drives with SD reader
  4. Format in the camera after backup
  5. Number the cards and have them in secure places.
